What exactly is integration and differentiation?
In summary: Approximate the "top" with a bunch of tiny rectangles. The total area will be the sum of the tiny rectangle areas, called rectangles = Rs. Area = R1 + R2 + R3 + ... + Rn. The height of each tiny rectangle is called DeltaY or Dy. The width of each tiny rectangle is called DeltaX or Dx. The area of each tiny rectangle is y * Dx.So, the total area is: Area = y1*Dx + y2*Dx + y3*Dx + ... + yn*Dx. We can write this in sigma notation as: Area = Σ(y*Dx), from i = 1 to n.
studentxlol
40
in a non mathematical sense?
My maths isn't very good which is why I need some simple explanation of what they are.
What does integration do? What is its purpose and how does its purpose apply to the natural world? I know differentiation is the opposite process but what is it exactly?
Where did it come from?
Mathematics news on Phys.org
Integration of a real-valued function finds the area between the function and the x-axis, and differentiation finds the slope of a real-valued function at specific points.
These operations are amazingly opposite operations, in the sense that
the derivative wrt x of the integral of a function f from any constant to x is equal to f(x).
Study elementary calculus to see how these things can be applied to physics. You're not going to get a good understanding of it if you don't know how to do it yourself.
differentiation is a way of telling "how fast something is changing". one example of this is the speedometer in a car. it is measuring "how fast your positon is changing in the direction you're travelling".
now, normally, we think of speed as distance/time.
but what about "instantaneous speed"? how do you tell how fast you're going "right now"?
the distance/time formula does us no good, we just get 0/0 = ?
but...there IS a way, and it's kind of clever.
suppose you're driving at a steady 60 miles an hour. then d/t should be 60, no matter how small "t" is. in other words:
d/t = 60t/t...and we just "cancel the t's".
that is the basic idea behind finding a limit, we see if (d(x+t)-d(x))/t is "well-behaved" (that is, we can approximate it better and better) even when t is very, very small.
functions (like our distance = d(x)) that DO behave well under such circumstances, are called differentiable, which means that we can tell "where they're headed right NOW". not all functions are well-behaved, but many of the useful ones are.
integration is sort of the "mirror process", given how fast things are changing "right now", can we tell what the effect of that change will be? that is, given how our speed varies over time, can we figure out our position? and, again for some, but not all functions, we can (if we know where we were, when we started). such functions for which we can "anti-differentiate" are called integrable.
it turns out that we gain a bonus, that integration is also closely tied to what we call "length" (in one dimension), "area" (in two dimensions) and "volume" (in three dimensions). for higher dimensions (which are hard to imagine), the term "content" is often used.
in the real world (i.e, in science and technology), we can use these features of "nice" functions to predict how things will behave. this is very useful. without calculus, we never would have made it to the moon and back (or made it very far in understanding electricty and magnetism).
calculus arose from studying phenomenon that changed "smoothly" over time, gradually, or fluidly. like a billiard ball, rolling along the surface of a table (perhaps with a little spin), rather than like a flashing light that suddenly blinks off and on. in fact, it was the search for a way to capture this idea of smoothness, or continual change, that led us to unify rational and irrational numbers in one big happy family (fractions are too "grainy" to capture the fluid behavior we were after), the real numbers (and their complicated big brother, the aptly-named(?) complex numbers).
none of this is terribly precise, but hopefully you get the idea.
Here's a link to 5 40 minute videos I watched when I first started learning calculus. I was very glad I watched these. They don't attempt to teach any practical form of calculus at all, but rather to give a big picture overview of what is going on.
http://ocw.mit.edu/high-school/courses/highlights-of-calculus/highlights-of-calculus-5-videos/"
You're driving your car. Your position is a function of time ... at time zero you're home; at time 1 hour you're 50 miles down the freeway; at time 2 hours you're 100 miles down the freeway.
Your speedometer gives your instantaneous speed ... that's the first derivative of your position function.
The total distance traveled is the integral of your position function.
It's that simple.
(edit) A little more.
Say you drive at a varying speed. At any moment, your speedometer tells you how fast you're going at that instant. If you keep track of your speedometer, can you figure out how far you've gone? Well, you could do this: Every minute, look at your speedometer and use "distance = rate times time" to see how far you went in the past minute. That's not completely accurate because your speed varied during that minute ... but your minute-by-minute sample isn't too far from the true total distance.
So you divide up your trip into 1-minute segments, add up all the "distance = rate times time" calculations, and you have an estimate of the total distance travelled.
Now you could get a better estimate by sampling your speedometer ever 10 seconds and doing the same "sum of the distance = rate times time" calculations. And you could do even better by sampling every second.
If you followed that, then you understand the fundamental theorem of calculus, which says you can determine the total distance traveled by doing "sum of distance = rate times time" over smaller and smaller sample intervals.
studentxlol said:
[integration]..in a non mathematical sense?
Welcome student, :smile:
geometry gives you an idea of integration "also in a math sense" . Imagine, draw a rectangle: base = x and height = y = k. Math, geometry tells you that: Area = B x h,
A rectangle = x * y
now imagine, draw a "rectangle" with an irregular top: base = x , height = y is not k but equals x² . Calculus [integration] tells you that
Area "rectangle" = x³/ 3
a great invention
This is the highly non rigorous explanation but it is a good start to understand
how simple the ideas really are underneath all of the equations, proofs and theorems.
Calculus is the Mathematics of Change
Integration is Multiplication, when one of the multiplicands is changing
Differentiation is the Instantaneous Slope of the tangent line to the function at a given point.
Instantaneous Slope = Average Slope between two points on the function
as the 2 points get closer and closer together in the Limit as delta x=>0.
delta x = the distance between the two x values of the points = x2 - x1.======================
Now for your questions...
It allows you to multiply in complex situations to solve difficult problems
Math is the language of the natural world.
Calculus is just one part of that language.
English, German, Spanish, etc. are hopelessly inaccurate and verbose to
describe the complex phenomena of science. Thus we invented Math.
That Differentiation and Integration are Inverse [opposite] Functions
is the Fundamental Theorem of Calculus.
This is a theological question for which Science and Mathematics have
no comment.
FAQ: What exactly is integration and differentiation?
What is integration?
Integration is a mathematical process of finding the area under a curve. It involves finding the antiderivative of a function, also known as the indefinite integral.
What is differentiation?
Differentiation is a mathematical process of finding the rate of change or slope of a function at a specific point. It involves finding the derivative of a function, also known as the instantaneous rate of change.
What is the relationship between integration and differentiation?
Integration and differentiation are inverse operations of each other. This means that the derivative of a function is the integrand of its integral. In simpler terms, finding the derivative of a function is like "undoing" the integration process.
What are the practical applications of integration and differentiation?
Integration and differentiation have a wide range of applications in various fields such as physics, engineering, economics, and statistics. For example, integration is used to calculate the area under a velocity-time graph to determine displacement, while differentiation is used to find the maximum or minimum value of a function.
What are the different methods for integration and differentiation?
There are various methods for integration and differentiation, including the power rule, product rule, chain rule, and integration by substitution. These methods are used to solve different types of functions and equations and require knowledge of algebra, trigonometry, and calculus.
