Equation measuring heat with temperature change, time and specific heat
In summary, the heat flow (J/s) from the surrounding ambient into your substance is proportional to the difference between temperature of ambient and temperature of substance and inversely proportional to the thermal resistance at the interface.
jc.int
hello,
If I had a substance (k) and heated it from Temperature1 to Temperature2, for z seconds, is there any (simple) equation that would give me the temperature (x) of this substance at the end? (knowing, of course, the substance's specific heat(C))
I found that:
Q(energy exchanged during the process)= C*(T2-T1)
thereby:
T2=Q/C + T1
BUT TIME (z) is never mentionned
Does anyone know any equation that would include time (z)?
Science news on Phys.org
I thought you said you heated the substance from T1 to T2...therefore the temperature at the end is T2 :-)
Anyway, I don't think time matters...
well, I mean that if a put a 10ºC/50ºF substance outdoors where the temperature is about 30ºC/86ºF, how can I find the temperature of the substance 10 minutes after, knowing the substance specific heat & heat capacity.
thanks
Jaimie
Oh, that's much better explained, now...not that that makes me know the answer :-)
In any case, along with finding out Q=C*(T2-T1), where I presume C is the heat capacity of the substance and include its total mass (specific heat x mass)...you should have found out that the heat flow Q is
Q = (T - T)/R
In words, the heat flow (J/s) from the surrounding ambient into your substance is proportional to the difference between temperature of ambient and temperature of substance and inversely proportional to the thermal resistance at the interface.
The thermal resistance at the interface is a result of the heat transfer coefficient, h, and the amount of surface area, A, exposed to the ambient:
R = 1/(hA)
Needless to say, you have a transient problem at hand (as opposed to a steady state solution) in which you need to calculate the amount of heat being transferred to your substance at some temperature during a time step dt, at time t, then you need to increase your substance's temperature and calculate the amount of heat that will be transfer in the next dt, etc.
In other words, the amount of heat being transferred will keep getting less and less as the substance temperature continues to increase.
You easily model this in a spreadsheet, without getting into mathematics or differential equations...just simple time-stepping.
I don't have it at hand but I think it is simply an exponential profile, where eventually, the substance reaches the ambient's temperature, of course.Hope this helps.
thank you very much for you answer :D
I'm afraid I still have a doubt: what does T∞ and T represent? (sorry but I'm still at high school)
I explained that in english right below the formula, please read.
ohh, I'm really sorry, :(,
thanks again for your time and your answer
I still have another (and I hope this time it is the last one) question:
Is there any simple way to get h (heat transfer coefficient)?
I've seen that it is quite complicated: http://goo.gl/Ol6Qj
FAQ: Equation measuring heat with temperature change, time and specific heat
1. What is the equation for measuring heat with temperature change, time, and specific heat?
The equation is Q = m * c * ΔT, where Q is the amount of heat transferred, m is the mass of the object, c is the specific heat of the material, and ΔT is the change in temperature.
2. How is this equation derived?
This equation is derived from the first law of thermodynamics, which states that the change in internal energy of a system is equal to the heat added to the system minus the work done by the system.
3. What is the unit of measurement for specific heat?
The unit for specific heat is Joules per kilogram per degree Celsius (J/kg°C) or calories per gram per degree Celsius (cal/g°C).
4. Why is specific heat important in this equation?
Specific heat is important because it represents the amount of heat required to raise the temperature of a material by one degree Celsius. It is a unique property of each material and is necessary for accurately calculating the amount of heat transferred.
5. Can this equation be used for any material?
Yes, this equation can be used for any material as long as the material's specific heat is known. However, it is important to note that the specific heat may vary depending on the temperature and phase of the material.
