Can you explain why we see a reflection when looking into glass?
In summary, light travels from an optically less dense medium to a more dense medium, which means that there is no chance that at any angle, the light will hit the glass surface to be totally internally reflected. However, glass reflects light, which is why you see a reflection of yourself when you look into it.
ilipad
As light travels from air into glass, it travels from an optically less dense medium to a more dense medium. This means there is no chance that at any angle, the light will hit the glass surface to be totally internally reflected since one of the requirements for total internal reflection is for a ray to travel from a more dense to a less dense medium.
However, how come you see a reflection of yourself when you look into glass?
Im pretty sure there's an explanation for this but it has been puzzling me for a while.
Science news on Phys.org
You see your reflection in glass because glass reflects light. Ordinary window glass reflects about 4% of the light incedent upon it.
http://physics-animations.com/Physics/English/rays_txt.htm
You will notice that your reflection in a window is not as clear as the view beyond the window ... unless it is dark on the other side.
Technically, there are two reflections - one from each surface.
It is possible to treat glass with a thin film so that there is no reflection - or just manufacture the glass very carefully so that the reflection from the back surface destructively interferes with the reflection from the front adding to nothing.
Any material reflects light.
As simple as that!
Try your rough cellphone cover, viewing at a really small angle with the surface. Doesn't it reflect the wall behind?
Whenever a wave encounters the transition between two media with different wave speeds then there will be some reflection (sound / light/ ocean / waves on strings etc. etc.).
Total internal reflection is a special case of reflection. Or, to put it differently, not all reflections are total internal reflections.
"Total internal reflection" means what it says: total. If you don't have total reflection, you still have partial reflection. The reflectivity of dielectrics depends on angle of incidence, so that angles closer to grazing are more strongly reflected. This is described by the http://en.wikipedia.org/wiki/Fresnel_equations"
The thing about TIR is that it really is TOTAL. There is no mechanism for a wave to propagate energy onwards through the less dense medium. There is actually some energy on the other side of the boundary but the wave (evanescent wave) only hangs around against the surface and doesn't actually carry energy away.
TIR has to involve an oblique incidence, btw, it never works 'head on' to the surface.
Any material may reflect light, but you won't always get a reflection at all wavelengths. You've seen Newton's Rings right? Thin film interference?
These are special cases of course, and they can be tricky to set up, however - knowing about them helps for the more advanced stuff.
Probably time to hear from OP?
FAQ: Can you explain why we see a reflection when looking into glass?
What is glass?
Glass is a solid, transparent material that is made from a combination of sand, soda ash, and limestone. It is often used in windows, bottles, and other household items.
Can light pass through glass?
Yes, light can pass through glass. Glass is transparent, which means that light can pass through it easily without being scattered or absorbed.
Can glass reflect light?
Yes, glass can reflect light. When light hits a glass surface at an angle, some of the light is reflected, while the rest passes through. This is why we can see our reflection in glass surfaces.
Why does glass reflect light?
Glass reflects light because of its smooth and polished surface. When light hits this surface, it bounces off at an angle, creating a reflection.
What colors can glass reflect?
Glass can reflect all colors of light, but it may appear to reflect certain colors more strongly depending on the angle of the light and the composition of the glass. This is why some glass surfaces may appear to have a colored tint when viewed from different angles.
