jhjensen
- 3
Are logarithms the only functions for which f(xy) = f(x) + f(y)?
is No unless you add some condition like continuity or differentiability.Are logarithms the only functions for which f(xy) = f(x) + f(y)?
Indeed. Consider the function g(x)=f(e^x). It satisfies the functional equation g(x+y) = g(x) + g(y) (i.e., g is additive) and determines f on the positive reals, hence on all the reals (why?). It's a pretty well-known fact that simple additional requirements, such as continuity, will force an additive function to be linear (i.e. to be of the form g(x)=cx for some constant c). However, in the absence of such requirements, one can in fact find http://planetmath.org/encyclopedia/ThereExistAdditiveFunctionsWhichAreNotLinear.html . These functions are fairly pathological. In particular, they aren't continuous. So, if we take one such example for our g, then the resulting f won't be a logarithm.Stephen Tashi said:Those answers assume differntiability. Perhaps the technical answer to the question:
Presumably by "logarithms" the OP meant functions of the form f(x) = c log|x| for some constant c. (This is at least consistent with CompuChip and sachav's posts.) You get the zero function when you take c=0.Stephen Tashi said:I just noticed that the differentiable constant function f(x) = 0 also works.
A logarithm is a mathematical function that represents the inverse of an exponential function. It tells you what power you need to raise a base number to in order to get a certain result.
Logarithms and exponential functions are inverse operations of each other. This means that the logarithm of a number is the exponent you need to raise the base to in order to get that number.
The property is known as the product rule of logarithms. It states that the logarithm of a product is equal to the sum of the logarithms of the individual factors.
No, this property only holds for logarithmic functions. It does not hold for other types of functions such as linear or quadratic functions.
The product rule of logarithms allows us to simplify and solve equations involving logarithmic functions. It can be used to combine multiple logarithmic terms into a single logarithm, making it easier to solve for the variable.
