Simple Voltaic Cell: Alessando Volta's Electrolytic Cell
  • Thread starter sankalpmittal
  • Tags
    Cell
In summary, Volta's voltaic cell worked by taking an electrolytic cell filled with dilute sulphuric acid and connecting it to a bulb or galvanometer using insulated copper wire. He assumed that the copper electrode had a positive charge and the zinc electrode had a negative charge, which was chosen for terminology purposes during the early experiments with electricity. However, there is no mention of Volta using a bulb or galvanometer in his experiments, as these were not invented until much later. The electromotive force of the cell was calculated to be 1.10 V, which is similar to the potential difference of a resistor. While some textbooks may mention using a bulb or galvanometer, there is no solid evidence to support this
sankalpmittal
785
27
In my reference textbook , it was written that while making a simple voltaic cell , Alessando Volta took an electrolytic cell made of glass ad partially filled it by dilute sulphuric acid acting as an electrolyte. Then he took a bulb (or any other resistor) or galvanometer of 1.08 V and connected it by means of insulated copper wire to two electrodes inside electrolyte - one electrode made of copper and other made of zinc. Then he "assumed in his own time" that copper electrode acquired positive charge while zinc electrode acquired negative charge.
voltaic-cell.jpe
My question is that firstly how can a voltaic cell work without connecting it to battery or cell ? Secondly how can he assume copper electrode to be positive and zinc electrode to be negative ? Why is it so ?
Here is a video that explains the cell.
As the video states a chemical reaction occurs at the copper and at the zinc electrodes, giving an electromotive force between the electrodes.
The voltaic cell works as a cell. Your 1.5 volt dry cell is a voltaic cell working under the same principle but using different materials.
It is a cell ( battery ) so you do not need to connect anything else.
Take note that this is when the first experiments of electricity were being carried out, so he had to produce some terminology to decribe what was happening and he chose positive and negative, He could have just as well said the zinc and copper acquired square and round charges, or pink and blue charges. Apparantly the terms positive and negative are the terms we still use today.
Is this really said so in your textbook? Do you have a reference?
I mean, do they say that Volta took a bulb or galvanometer of 1.08 V(olts)?
The light bulb was not invented until almost 100 years after Volta invented his cell.
And also there were no galvanometers (electromagnetic effect discovered later) and no one (I suppose) was measuring tension in Volts, yet.
Maybe is just your mixture of information from various references?
256bits said:
Take note that this is when the first experiments of electricity were being carried out, so he had to produce some terminology to describe what was happening and he chose positive and negative, He could have just as well said the zinc and copper acquired square and round charges, or pink and blue charges. Apparantly the terms positive and negative are the terms we still use today.
I know this but why did he not say just the opposite that copper electrode is negatively charged and zinc electrode is positive. In my textbook it was also written that ionization potential of zinc is -0.76 V and of copper is +0.34 V . As -0.76 V<+0.34 V so zinc more readily donates electrons. That is why zinc is made negatively charged electrode as "-" charge on electrode means that it has excess of electrons so it donates them or it oxidizes ions. Am I correct ?
Sure ! It was written in my textbook and I cannot find any reference. And in my textbook it was also written that electromotive force in voltaic cell was 0.34-(-0.76) = 1.10 V which was more or less same as potential difference of resistor.
http://hyperphysics.phy-astr.gsu.edu/hbase/chemical/electrochem.html site says nothing of the sort which my textbook say.
Edit : This thread https://www.physicsforums.com/showthread.php?t=43836 explains a little bit of what I'm asking.
I did not question the information about the electromotive force of the cell. I was just curios if they really say that Volta took a light bulb and connected it to his cell, for example.
By reference, I mean "what textbook?". Is it a high school text?
Yup , its a high school text of class 9th. I have just passed class 10th. I was just going through it again especially on the things which I failed to understand at that time. It was the book written by an Indian author -V.K. Sally , Goel publications. (saw no need to type this.)
There are somethings which I cannot understand like magnetism , voltaic cell etc..
I googled a lot and the sites hell further confuse the things. They say that zinc electrode is positive and copper one is negative which is opposite of what my textbook say ! Now two things (which carry extremely opposite views) cannot be correct simultaneously. Can they be ?
This is way too confusing for me ! Can someone clarify please ?
http://hyperphysics.phy-astr.gsu.edu...ectrochem.html site says nothing of the sort which my textbook say.
The 'hyperphysics' site says the copper electrode is positive, the zinc electrode is negative, and the cell potential is 1.10 volt. The picture of the cell shows electron flow from the zinc to copper, which is in opposite direction to standard current flow which is from positive to negative or from the copper to zinc electrode.
Can you show links to some of these sites?
Wikipedia agrees with what you say is in your book, regarding the polarity. (Cu is positive).
The difference may have to do with the conventional direction of the current.
Actually, the "positive" and "negative" terminology came from Benjamin Franklin, about fifty years before Volta's battery. He theorized that after rubbing certain objects together, one object becomes "positively charged" (has an excess of "electric fluid") and the other becomes "negatively charged" (has a deficit of "electric fluid"). He couldn't actually see the "electric fluid" flowing, so he had to guess which objects were positive and which were negative, making them consistent with whether they attracted or repelled each other. Other scientists adopted his terminology, and surely Volta labeled the terminals of his battery correspondingly, according to whether they attracted or repelled positively or negatively charged objects.
Yes , I found that but it confuses things which my textbook say and also which I studied since very long time. According to my knowledge "cathode" is negatively charged electrode and here is where , the reduction occurs. So it is reducing electrode as it reduces positive ions to metals with itself being oxidized. Similarly "anode" is positively charged electrode where oxidation occurs. It oxidizes negative ions to neutral atoms with itself being reduced.
Also sometimes anode itself ionizes if its reactive such as copper (according to textbook.)
From hyperphysics : Zn(s) -> Zn2+(aq) + 2e-
The zinc "half-reaction" is classified as oxidation since it loses electrons. The terminal at which oxidation occurs is called the "anode". For a battery, this is the negative terminal.
The copper "half-reaction" is classified as reduction since it gains electrons. The terminal at which reduction occurs is called the "cathode". For a battery, this is the positive terminal.
Cu2+(aq) + 2e- -> Cu(s)
This seems to say opposite of what the textbook say ! Can someone explain ?
http://www.d-ddm.mb.edus.si/ec/voltaic_cell.htm
http://group.chem.iastate.edu/Green...der/flashfiles/electroChem/voltaicCell20.html
http://www.chem.wisc.edu/deptfiles/genchem/netorial/ROttosen/tutorial/modules/electrochemistry/03voltaic_cells/18_31.htm
http://dl.clackamas.cc.or.us/ch105-09/voltaic.htm
Did he rub zinc with copper ? Zinc has more loosely bound free electrons than copper. So according to this zinc must be positive electrode and copper negative one. But just the opposite is happening in the "textbook" describing the first simple voltaic cell.
Do you people want me to quote whole of the description from my textbook ?
FAQ: Simple Voltaic Cell: Alessando Volta's Electrolytic Cell
What is a Simple Voltaic Cell?
A simple Voltaic cell is an electrochemical cell that converts chemical energy into electrical energy. It consists of two different metal electrodes, typically copper and zinc, immersed in an electrolyte solution.
Who is Alessandro Volta and what is his contribution to the development of the Simple Voltaic Cell?
Alessandro Volta was an Italian physicist and chemist who is credited with inventing the first electric battery, also known as the Voltaic pile. His discovery of the chemical reactions between two dissimilar metals led to the development of the Simple Voltaic Cell.
How does a Simple Voltaic Cell work?
A simple Voltaic cell works by converting the chemical energy of the reaction between the two metals and the electrolyte solution into electrical energy. This is achieved through the transfer of electrons from the anode (negative electrode) to the cathode (positive electrode) through an external circuit.
What are the main components of a Simple Voltaic Cell?
The main components of a Simple Voltaic cell include two metal electrodes, an electrolyte solution, and an external circuit. The metal electrodes, typically copper and zinc, are connected by a wire that allows the flow of electrons. The electrolyte solution, usually a salt or acid, acts as a medium for the transfer of ions between the electrodes.
What are the applications of a Simple Voltaic Cell?
Simple Voltaic cells have various applications, including powering small electronic devices, such as calculators and watches, and as a backup power source in case of power outages. They are also used in scientific experiments and in the production of electricity in remote areas.
