Do Photons Oscillate in Electromagnetic Waves?
  • Thread starter Thread starter karen_lorr
    Photons
The discussion centers on the nature of electromagnetic (EM) waves and photons, exploring whether photons oscillate within these waves. It clarifies that while light is indeed a wave, it travels in straight lines and consists of oscillating electric and magnetic fields, not particles moving in a wavy path. The oscillation is linked to the energy of the wave, with photons being quantized packets of this energy. The conversation also touches on how disturbances in the EM field are generated by moving charges, and how these waves propagate through space. Overall, the thread emphasizes the wave-particle duality of light and the complexities of understanding EM theory.
karen_lorr
OK I understand it’s a silly question but I have been thinking about this all day.
Say you have an EM wave moving out from its source in a transverse wave formation. Where does the oscillation come from? And (another silly question) is the oscillation affected by mass?
In my simplistic way I like to think about it like this:
In the light source atoms are oscillating as they emit particles and energy. This means that some particles will be emitted at the top of the oscillation and othersat different points. This creates a steam with a wavelike formation of particles being emitted.
I may be way off with that by the way?
But what happens next?
Does the oscillation continue until the photons bumps into something? Are they affected by the rest of wave in a repulsive way (so forcing movement away from the centre)?
So can anyone explain “why” the wave forms and "why" it doesn’t deteriorate over time as, sometimes, this is a VERY long time?
Thank you
Science news on Phys.org
First it may help to understand WHAT is oscillating. The electric and magnetic fields are oscillating from + to - and back. Did you know that?
There is no "wavy motion" of light, it travels in straight lines.
Edit: Just to be clear, light itself IS a wave. It is not little particles bouncing off of things. The photon is simply the result of the laws of the universe requiring the energy of an EM wave be absorbed or emitted in little packets or chunks that we call photons. In SOME cases it is possible to consider light in the particle sense, but not all.
I was always taught that light moves in transvers waves - is this not correct. - and that the wave consisted of photons (packets of energy).
Are you saying that em is just energising one photon twhich then passes this onto the next and so on (like an electric current down a cable). If this is case why do they teach that light moves in transverse wave.
Sorry but a little lost with this - I have wiki'ed this no end
The real ones oscillate. The virtual ones don't. The oscillation frequency is proportional to their energy.
If you thought of them as semi classical balls or waves you'd conclude that their physical (longitudinal) extent is given by the narrowness of their energy spectrum. But this can't really be the case for the typical photon unless it's part of an infinite plane wave.
If you connect a highly directed antenna to an RF generator that pushes out a single broadband RF quantum, the probability of finding it at a certain place far away will exactly obey the antenna pattern as measured with many quanta.
Such a photon cannot be localized either in space or time (it's not a ball or point particle until and unless its measured by a receiver and you can't say it left the antenna at this instant and not that instant unless the energy is sufficiently indefinite), it interferes with itself especially around the antenna.
Balls and point particles don't help visualize this much.
OK thanks.
I have not been in a class room for over 35 years and am simply trying to understand things as a hobby. So I really do appreciate and answer you have time to give.
Back to my thoughts. Looking your answer it seems you are saying that at a quantum level there is no oscillations but it helps to visualize it as such.
I am along the right lines here?
No, that is true. The electric and magnetic fields have a vector and these are oriented at 90 degrees to each other and to the direction of propagation, so it is a transverse wave. What I am saying is that the light does not travel in a wavy path. If you drop a pebble into a pond the wavefront of the expanding wave cannot be said to be wavy in the direction it travels. (Because it travels out while the oscillations of the water go up and down.) This is just an analogy, but it is similar to an EM wave. From a point source, the wavefront propagates out in a spherical shape, just like the water wave propagates outward in a circular shape on the surface of the water.
No, the EM wave is literally a wave, a disturbance in the EM field. It merely interacts in packets called photons. By this I mean that pretty much all the rules we use to describe how an EM wave propagates follow wave rules, but when we go to detect the EM wave we find that in certain experiments we are only able to explain how it works if we think of the wave as being composed of little particles. Hence the wave-particle duality in quantum mechanics.
Hi Drakkith
Thank you that makes sense.
I will do some more reading and than come back with some more silly questions :redface:
Thank you for helping (it's really quite fun all this)
Karen
if I connect an alternate current source or RF generator to an antenna how does the electromagnetic field "exit" from the antenna? is that field mainteined by photons and how can they move from the + to - in the air?
thank you!
thank you!
The electrons in the antenna move back and forth, which generates a disturbance in the EM field that propagates outward from the source. It is the acceleration of charges that generates disturbances in the EM field. Once the wave has been generated it "self generates" by the alternating fields. The changing magnetic field induces a changing electric field, which itself induces a changing magnetic field. (I think at least. This discussion is quickly reaching the limit of my knowledge of EM theory)
I like Drakkith's water wave analogy...
If you want to see some nuts and bolts of photons discussed try this on for size:
How big are photons:
https://www.physicsforums.com/showthread.php?p=3642038#post3642038
To get you started:
don't have the source:
The electromagnetic field is a quantum field, and the photon is a single quantum excitation of that field. Just as for all particles in quantum mechanics, a photon does not have a unique shape, rather it is a wave packet with a finite size and frequency spread. Even a 'pure' frequency photon such as Hydrogen alpha has a certain line width and a certain spatial extent, related by the uncertainty principle. The size and shape of a photon depends on the circumstances which created it.
And one step further is the emission or absorption of a photon from an orbital electron:
I think I posted this previously:
In an atom it's not the [bound] electron by itself that absorbs the energy of an incoming photon, or emits one, but the whole atom...that is, it's related to the degrees of freedom of the system. One thing that makes it somewhat odd from a quantum mechanics perspective is that it's apparently an instantaneous, discontinuous energy transition for a bound electron. This puts it at the very heart of QM. Bound electrons are confined in some way... such as an electron in an atom or a "particle" in a box or an electron stuck in a negative square potential well...so the wave function [of the electron] has the form of standing waves...it is quantized as it is limited to certain discrete energy levels. It behaves as a wave (distribution) rather than as a classically envisioned "particle".
It's emits a purer and purer 'photon' the longer it has existed!
when an alternate current flow in a coil, will it generate a magnetic or electromagnetic field?
The magnetic and electric fields are different aspects of the Electromagnetic field. Generally if you are talking solely about one aspect of the EM field you would just say magnetic or electric.
  • · Replies 26 ·
  • · Replies 16 ·
  • · Replies 29 ·
  • · Replies 43 ·
