Can someone explain me why f=ma ?
In summary, Newton's second law states that the force applied to an object is directly proportional to the resulting acceleration, and the direction of the acceleration is in the same direction as the force. This law is based on empirical observations and is not a definition. Newton's third law, while often considered a definition of forces, also contains actual physics and describes the interaction between two objects. Overall, Newton's laws of motion are complex and can be interpreted in different ways, but they provide a foundation for understanding the
vansh123
hey guys i had a doubt can someone please explain me why force=mass x acceleration?
That's how the concept of force is defined. If you apply larger amounts of net force on an object, you'll find that the acceleration increases linearly and the property that decides how quickly the acceleration increases is the mass.
A quicky my teacher once said:
" I don't like the way the original equation is written because it brings up misconceptions to many new students, instead think of it this way, f/m=a. A force acting on a body will cause it to accelerate". Then you only also have to remember one of the laws of Newton: that a body will stay at rest (or uniform motion in a straight line) as long as no net force is applied to the body. And when suddenly we have a net force, we have an acceleration.
Not an expert in this subject but maybe that will help.
Best Regards
Robin Andersson
There's a fun quote by Arthur Eddington which touches on this:
Every body continues in its state of rest or uniform motion in a straight line, except insofar as it doesn't.
F=ma is sometimes looked at as a definition (especially by mathematicians), where it constitutes the definition of force based on measurable quantities mass and acceleration. But according to Thornton and Marion, really when Newton stated this, he meant something physical. I think what Newton really meant, more specifically, was that from an inertial reference frame, objects continue in straight lines unless acted upon by a net force--but the concept of an inertial reference frame isn't defined when you begin to state Newton's laws--so it's kind of a built-in assumption that's hard to avoid. That's why the mathematicians just ignore the physical meaning and take it as a definition.
Usually Newton's first law is considered to be a definition of inertial frames and Newton's second law is considered to be a definition of forces. Once those terms are defined, then Newton's third law is the one that contains the actual physics.
I beg to differ, DaleSpam. Newton's third law applies only to interactions between two (or more) bodies--if that law contained all the actual physics, then how is it possible that there is a whole class of problems that deal with a single particle under the influence of some "external" force or field? For example, a particle on a spring (SHO), a massive particle in an external gravitational field, and a charged particle in an EM field all are nontrivial physical problems which can be solved using only the first two laws--not the third.
Sure, but in all of those cases there is something besides Newtons three laws defining the physics, the force law. You mentioned Hookes law, Newtons law of gravitation, and Maxwells equations. Newtons first two laws are still generally considered to be definitions in the scenarios you mentioned.
Well, Hooke's law isn't exactly a physical law of the universe--it just is a force function. You could treat Newton's gravitational force law as just some random "given" force with a certain functional form, and likewise, you could ignore Maxwell's equations and simply give the Lorentz force law. If you want some even more trivial examples, you could have F=constant, F(t)=at+b, F(x) = cos(x), or whatever. They all are just given "external" forces. All problems of this form do not require the third law.
Agreed, but again, the physics is not contained in the first two laws, they are simply definitions. The physics is contained in whatever force law you propose or in the third law.
All problems involving only the first two laws are simply problems designed to help students learn the definitions.
Well, I believe we are still at odds here. I think the problems which involve only the first two laws do contain actual physics--they tell you how a particle actually moves under the influence of a force. And though many of the examples I gave do seem like problems you'd only give to help students learn the definitions, I think the simple harmonic oscillator and a particle under the Lorentz force law are quite a bit beyond just learning the definitions. They give nontrivial predictions on trajectories.
Even in well-respected textbooks, you'll find admissions that the scenario is not as clear-cut as what you've argued. There are alternate ways of answering the question, and they amount to different perspectives on these laws.
Thornton and Marion's "Classical Dynamics of Particles and Systems," Fifth Edition, treats this question with a few paragraphs (pp.49-50), and it includes this footnote on page 50.
The reasoning presented here, viz., that the First and Second Laws are actually definitions and that the Third Law contains the physics, is not the only possible interpretation. Lindsay and Margenau (Li36), for example, present the first two Laws as physical laws and then derive the Third Law as a consequence.
Your view is certainly a valid way of looking at things, but it is not the only possible way.
I'm sure the answer is that it's an empirical law. If you apply double the force, you observe the object accelerates twice as much. Do this experiment in enough ways and it's soon fairly convincing that F=ma and not m/a or ma^2 or something weird.
This is not how Newton gave them. See http://en.wikisource.org/wiki/The_M...l_Philosophy_(1846)/Axioms,_or_Laws_of_Motion
"LAW II.
The alteration of motion is ever proportional to the motive force impressed; and is made in the direction of the right line in which that force is impressed.
If any force generates a motion, a double force will generate double the motion, a triple force triple the motion, whether that force be impressed altogether and at once, or gradually and successively. And this motion (being always directed the same way with the generating force), if the body moved before, is added to or subducted from the former motion, according as they directly conspire with or are directly contrary to each other; or obliquely joined, when they are oblique, so as to produce a new motion compounded from the determination of both."
Definitions were given before the laws:
http://en.wikisource.org/wiki/The_Mathematical_Principles_of_Natural_Philosophy_(1846)/Definitions
"DEFINITION IV.
An impressed force is an action exerted upon a body, in order to change its state, either of rest, or of moving uniformly forward in a right line."
It can also be seen that his definition of force refers to inertial frames, but perhaps not entirely satisfactorily (the translator may be to blame, though).
This repeats Newton's own words almost verbatim! In the scholium that follows the Laws, he refers to multiple experiments, particularly by Galileo, that had established these laws.
Correct, it is not how Newton gave them. It is how modern physicists interpret them with the advantage of several hundred years of hindsight.
Excellent, then it seems we are not at odds.
Which is why I qualified my statements with the word "usually".
Btw, the reason I prefer the usual approach over alternatives is the difficulty in defining what a force is without using f=ma. It can be done, usually via an experimental prototype force, but force prototypes are not very reproducible.
Actually, it is an 'observation' .. not really a definition: and the observation is simply : what features of an object are directly proportional to the 'force needed to move it'... and what features, if any, are found to be INVERSEly proportional to that force ...
So, experiment shows that only two items affect the ability of a force in a friction-less vacuum to move any object <mass> ... and both of them are DIRECTLY proportional to the force required ...
Ie, if the MASS is bigger, the force must be bigger <other things being eqaual> .. and if the required motion is to start, then the force also is directly <NOT: 'inversely'> proportional to how fast the mass is made to move up to any velocity <ie, it's 'accelleration'>
Mathematicly, we state such a condition this way:
In english: for a given force, giving it a velocity is DIRECTLY proportional to the mass of the object, and also Directly proportional to how much you choose to accellerate it. ...
In math: F <the force required> = M <the mass> TIMES any other 'directly propportional' item .. in this case, 'A' , how much we choose to make it go faster... with a 'Constant of Proportionality' < 'K'>
conveniently chosen to be '1' , or:
F = kMA , where k = 1 for our chosen units
If there were any 'INVERSELY Proportional entity, say <some 'vacuum-like' theoretical thing called 'Z' which would HELP accellerate, then the formula would be:
F = kMA <times> 1/Z , or: F=kMA/Z
because the BIGGER Z is, the SMALLER F can be ... ie, they are INVERSELY proportional.
This is how many relationships are described ... another example woujld be 'Ohm's Law' where:
E = I x R .. I'll leave that to yu to sort out ;)
and remeber: I MUST = E/R , atain from the observation.
<simply dividing both sides of a known 'equality by the same item, in this case: 'R' ..
E / R = (I x R) /R ..and the R's cancel out on the right side..
Hope this helps ...
j.a. , mech-eng, m.d.
MikeyW said:
I'm sure the answer is that it's an empirical law. If you apply double the force, you observe the object accelerates twice as much. [... ]
The problem is: How do we know that we've doubled the force? How else do we measure the force except using [itex]F = kma[/itex] itself? In other words, we're brought back to regarding [itex]F = kma[/itex] as true by definition.
I've just been a bit of a devil's advocate, though, because things aren't quite as simple as I've made out. For example, if we use two identical, equally stretched springs, pulling in the same direction on an object, instead of just one of the springs, we find twice the acceleration (if resistive forces are negligible). It's hard to quarrel with the idea that doubling the springs must double the force (so giving us an independent way of knowing that we've doubled the force), but I've known people who believe that it's making an unacceptable assumption.
Yes, this is exactly what I meant by "an experimental prototype force".
hey thanks guys for your help
i had solved so many questiond on Newtons laws of motion but i didnt get the correct meaning of his second law
I find it exceptionally beautiful that even the most basic laws of physics have such nuanced philosophical interpretations. The arguments presented here really show how hollow "definitions" can be, and how ambiguous "empirical laws" can be.
Personally, I look at Newtons laws as instructions for how to construct other equations based on observations.
The third law is just a statement of the conservation of momentum, nothing much to see there.
You have to take note that, although a law might be named after someone, the law that we write down nowadays can be drastically different from the one originall derived.
Originally, Newton defined force as the rate of change of momentum.
This way he essentially described a model for how the universe could function.
Every particle has a momentum vector assigned to it (Newton used the words motion and momentum interchangingly), it's time derivative is equal to the outside interactions which he calls force.
Position, velocity and acceleration can be defined from this.
To summarize, I see Newtons first and second laws as describing the arena in which all of classical mechanics takes part in, given the initial conditions and outside forces, solve for the trajectory of the particle.
DaleSpam doesn't know what he is talking about. Newton's 2nd law is an empirical relation between force and acceleration, it is not a definition although some people do use it as an operational definition of mass. I can measure force and acceleration seperately and Newton's 2nd law tells me the mathematical connection between the two. Newton's 1st law is just a special case of Newton's 2nd law. Newton's 3rd law tell's us something about the forces that two objects exert on each other when they interact - that those forces are equal in magnitude and point in opposite directions.
Experimental prototypes of force are not nearly as reliable as measurements of acceleration or experimental prototypes of mass. So generally it is preferable to take Newton's 2nd as a definition of force, since you can get more accurate results that way than by using an experimental prototype force. Your rather rude assertions notwithstanding.
it merely means that there is a relationship between the effect that the Higgs field has on a mass is directly proportional to a force applied to it and indirectly proportional to the accelleration the mass might experience due to a force, and that the 'constant of proportionality' is equal to " 1 "
Does this help? I'm curious as to what other replies you might have received ... Kindly let me know!
Newton observed, as did Galileo (which is why we refer to the principle as Galilean Relativity), that the laws of physics are the same in a boat moving at constant speed on calm seas as they are on land. In other words, the laws of motion are the same for bodies in all inertial reference frames (frames of reference of a body undergoing no change in motion).
If acceleration was not proportional to force (and inversely proportional to mass) two very important principles would be violated: 1. the additive nature of forces and mass and 2. Galilean relativity.
AM
1. What is the meaning of f=ma?
The equation f=ma is known as Newton's second law of motion. It states that the force (f) applied to an object is equal to the mass (m) of the object multiplied by its acceleration (a).
2. Why is f=ma important?
F=ma is important because it helps us understand the relationship between force, mass, and acceleration. It is a fundamental equation in physics and is used to explain the motion of objects.
3. How is f=ma used in real life?
F=ma is used in various real-life situations, such as calculating the force needed to launch a rocket, determining the acceleration of a car, or understanding the impact of gravity on objects.
4. Can you give an example of f=ma in action?
One example of f=ma in action is when a hockey player hits a puck with their stick. The force applied by the stick (f) is equal to the mass of the puck (m) multiplied by its acceleration (a), causing it to move forward.
5. What are the units for f=ma?
The units for f=ma are Newtons (N) for force, kilograms (kg) for mass, and meters per second squared (m/s²) for acceleration.
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Classical Physics
