How do partial derivatives relate to the definition of a derivative?
In summary: Ok so for this example, is it the definition of the derivative to consider y to be a constant?In summary, partial derivatives are geometrically the intersection of a plane and a surface. They are useful in general form as they make studying the derivative, and thus properties of a function easier.
courtrigrad
1,236
I am sort of skipping around at my own pace in Courant's Calculus book and came across partial derivatives. Are they geometrically the intersection of a plane and a surface? Why do we keep only one variable changing and the other variables fixed? Is it basically the definition of the derivative? For example
[tex] \frac{\partial y}{\partial x} [/tex] when [tex] f(x,y) = \sqrt{x^{2} + y^{2}} [/tex] Ok so would I consider y to be a constant when we want to find [tex] f_{x} [/tex] and vice versa for [tex] f_{y} [/tex]? Ok so this is what I did:
[tex] f_{x} = \frac{1}{2}\sqrt{x^2+y^2}2x [/tex]. But the answer is:
[tex] f_{x} = \frac{x}{\sqrt{x^2+y^2}} [/tex] and the same is true for [tex] f_{y} = \frac{y}{\sqrt{x^2+y^2}} [/tex] except the variables are reversed.
Any help is appreciated!
Thanks
Did you mean df/dx and not dy/dx? When you evaluate the partial derivative wrt a particular variable, you keep the others constant as you said.
Your answer is wrong as you've not differentiated with the chain rule properly:
d/dx [(x^2 + y^2)^1/2)] = (1/2)[(x^2 + y^2)^(-1/2)].2x = x/(x^2 + y^2)^1/2 as required.
whoops I must have not noticed that I typed LaTex wrong.
Thanks a lot for your answer :smile:
Please use the notation of Lagrange properly.
[tex] f'_{x}=:\frac{\partial f}{\partial x} [/tex]
,where the last is C.G.Jacobi's notation.
Daniel.
I'm sure you can think of many multivariable functions where you are only interested in what happens when one particular variable is varied (Ie., gas laws, economics, etc.). In addition, partials are useful in general form as they make studying the derivative, and thus properties of a function easier, as the derivative can be written in terms of the partial derivatives of f.
courtigrad:
The simplest way of looking upon a partial derivative of a function f, is that it measures the rate of change of f along a RESTRICTED neigbourhood of your evaluation point.
That is, [tex]\frac{\partial{f}}{\partial{x}}\mid_{(\vec{x}=(x_{0},y_{0}))[/tex] is found by by restricting your attention to f's behaviour along the line [tex]y=y_{0}[/tex] (where "y" is obviously a constant!)
The one variable analogue of the partial derivative, is to limit your attention to f's behaviour on a resticted neighbourhood (for example, by evaluating the rate of change on the rational sequences converging to your point, not bothering about f's behaviour on sequences converging to your point where the elements of the sequences are irrational).
FAQ: How do partial derivatives relate to the definition of a derivative?
What is a partial derivative?
A partial derivative is a mathematical concept that measures the rate of change of a function with respect to one of its variables, while holding all other variables constant. It is denoted by ∂ and is used in multivariable calculus to analyze how a function changes in response to small changes in its input variables.
Why are partial derivatives important?
Partial derivatives are important because they allow us to study the behavior of a function in multiple dimensions. This is useful in fields such as physics, economics, and engineering, where many real-world problems involve functions with multiple variables. Partial derivatives also play a crucial role in gradient descent algorithms, which are used in machine learning and optimization problems.
How do you find a partial derivative?
To find a partial derivative, you need to take the derivative of a function with respect to one of its variables while treating all other variables as constants. This can be done using the standard methods of differentiation, such as the power rule, product rule, and chain rule. The resulting derivative will be a new function that represents the rate of change of the original function with respect to the chosen variable.
What is the difference between a partial derivative and a total derivative?
The main difference between a partial derivative and a total derivative is that a partial derivative measures the rate of change of a function with respect to one variable, while a total derivative measures the overall rate of change of a function as all of its variables change. In other words, a partial derivative is a local measure, while a total derivative is a global measure.
What are some real-world applications of partial derivatives?
Partial derivatives have many real-world applications, including determining the maximum or minimum values of a function, optimizing processes in engineering and economics, solving optimization problems in machine learning, and analyzing the behavior of systems in physics. They are also used in the study of fluid mechanics, thermodynamics, and other areas of science and engineering.
