Rate of planets flowing into stars: Discussion
In summary: This equation describing the rate of planets migrating into a star is very interesting. It is interesting to see how the rate of planets migrating into the star depends on the period of the star. It is also interesting to see how the rate of planets migrating into the star changes depending on the power index of the planet distribution.
astrostuart
I just posted a question to ask for help on the Calculus & Analysis section to determine how fast planets go into stars. I should give a little background, in addition to pointing you to my latest two short papers: http://arxiv.org/abs/1301.4229 and http://arxiv.org/abs/1211.1984
I have already done this problem numerically in those two papers, but for the full Journal paper, I want to show as much of this as I can analytically. I will be able to do my calculations much faster with analytical equations as well.
I am taking the distribution of planets found using Kepler data, and using the equations for tidal migration, calculating the rate of planets migrating into the star as a function of the tidal dissipation value Q.
I am also looking how the occurrence distribution changes as a function of time.
There are several more interesting questions I'll be pursuing, including a correlation between the Fe in the star and the eccentricity of the planet. I'm hoping to get more discussion.
Hope you head over to the other post.
Thanks!
Stuart
Hong Kong and Sedona, Arizona
Astronomy news on Phys.org
I have a tentative solution to my question, how fast are planets migrating inwards, posted at https://www.physicsforums.com/showthread.php?p=4240604#post4240604
I've posted my math in the calculus section, because it is hardcore calculus help that I want, but I sure would be grateful if some of you wanting to do some theoretical exoplanet astrophysics headed on over and looked at my math.
I "end" with still more to do.
Thanks
Stuart
I'm retired and not able to help any substantive way. I was impressed by your writing style: clear cogent, well organized. If I had a friend I was in touch with in the appropriate astrophysics department I could honestly recommend that he or she check out your papers. But besides encouragement and wishing you the best of luck there is little I can do.
It's great you are attending all these conferences and presenting your work.
Hi stuart, and a belated welcome to PF! Planetary evolution is complicated, as I'm sure you are aware. Hot jupiters are a source of unending amazement to me, if for no reason other than apparently crowding out terrestrial-like planets. But, numerical studies suggest these behemoths can easily migrate to far greater distances over time - which implies, IMO, no simple conclusions can be drawn from whatever orbit we perceive an exoplanet to presently occupy.
First presentation of the rate of planets migrating into the star:
Eureka! I found it!
The rate of migration of planets into the star
Posted 2014 Mar 05​
Here is the first public presentation of the equation giving the rate of planets going into the star!:
[tex]\frac{dN}{dt}=
- \frac{27}{4}
\frac{ \left( 2 \pi \right)^{13/3} R^5_{\ast} M_p}{G^{5/3} M_{\ast}^{8/3}
Q^{\prime}_{\ast}}
k P^{\alpha - 13/3} [/tex]
Here,
[itex]M_{\ast}[/itex] and [itex]M_p[/itex], and [itex]R_{\ast}[/itex] and [itex]R_{p}[/itex] are the masses and radii of the star and planet, respectively, and [itex]Q^{\prime}_{\ast}[/itex] is a measure of the strength of the dissipation of energy by tides on the star called the ``tidal quality factor.''
The distribution of planets is determined by [itex]k[/itex] and [itex]α[/itex] in the expression describing the exponential distribution of planets in the falloff, or, separately, the distribution beyond the falloff:
[tex]\frac{dN}{d\log[P]}= k P^{\alpha }[/tex]
so that α is the power index of the planet distribution, and k the normalization.
I have simplified this distribution from the combined form I used in previous posts.
The first important point is how the dependence of the rate on the period P drops out when α equals 13/3, which means that if the power index is found to be 13/3, then this indicates that the distribution is shaped by planets tidally migrating into the star. The power index found by Howard et al. (2012) for giant and medium radii planets, as found by Kepler, in the falloff region is in fact a little above 4.0 (Using the approximation in the Howard equation for the distribution which has two regions each following a power law, that for small P, α = β+γ).
The other important result is that a calculation of this rate using the Howard+ (2012) results is an inward flow of less than [itex]10^{-12}[/itex] giant planets/star/yr when calculated for [itex]Q^{\prime}_{\ast}[/itex] of [itex]10^{7}[/itex], or less than one planet per 1000 stars per giga year. This means that in the 10 Gyr lifetime of a star like the sun, that supplying this migration flow would take a 1% reduction in the occurrence of giant planets further out. Not only is this easily sustainable, but so would be the larger flows required by [itex]Q^{\prime}_{\ast}[/itex] of even as strong as [itex]10^{6}[/itex]. (Stronger tidal dissipation is indicated by a lower number.)
I conclude that the planets in the falloff region have not been there since the formation of the planets, but in fact are part of planet migration. There is no need to say that the presence of these planets indicates that tides in the star must be as weak as [itex]Q^{\prime}_{\ast}[/itex] of [itex]10^{7}[/itex]. This bears on many mysteries about the shortest period planets. The planets in the falloff may also more newly arrived than planets beyond the falloff, which means we should look to see if such planets are more likely to be inflated.
This also bears on whether the correlations of iron abundance with planet and star parameters could be due to planet pollution of the stars. The most massive giant planets will produce transient events, and the majority of these planets will likely produce ``bloatar'' type objects such as found by Spezzi et al.
This would be the first measurement of the rate of planet migration. I am writing this up for my blog (astrostuart.blogspot.com, give me a day or so) and will submit my paper, but for the paper would enjoy discussing this as a means of having an audience to help me write the paper.
Stuart F. Taylor
Welcome to the forum, Astrostuart. I seem to recall reading an older article that you had written. If I recall correctly it had to do with shock wave effects on plasma. However my memory could be faulty on that as it was over a year ago when I read it.
FAQ: Rate of planets flowing into stars: Discussion
What is the rate of planets flowing into stars?
The rate of planets flowing into stars is not a common phenomenon. It is believed that planets are formed from the leftover materials of a star's formation, and they do not flow into stars. However, there have been a few documented cases of planets being consumed by their host stars due to extreme gravitational forces.
How do planets form in the first place?
Planets form from the leftover materials of a star's formation. As a star is formed, gas and dust particles orbit around it and eventually clump together to form planets. The exact process of planet formation is still not fully understood and is an active area of research in astronomy.
Is the rate of planets flowing into stars a cause for concern?
No, the rate of planets flowing into stars is not a cause for concern. As mentioned earlier, it is not a common occurrence and is a natural part of the formation and evolution of planetary systems. There is no evidence to suggest that this process poses any danger to our own solar system or others.
Can we observe the rate of planets flowing into stars?
Yes, we can observe the rate of planets flowing into stars through various methods. One way is by studying the spectra of stars, which can reveal the chemical composition and any changes that may occur due to the consumption of planets. Another way is by using telescopes to directly observe the interaction between a planet and its host star.
How does the rate of planets flowing into stars affect the habitability of a planet?
The rate of planets flowing into stars does not directly affect the habitability of a planet. However, it can indirectly impact a planet's habitability if it leads to significant changes in the star's composition and behavior, such as increased radiation or changes in temperature. But as mentioned earlier, this is not a common occurrence and does not pose a significant threat to most planetary systems.
