Higgsinos: An Old Theory Revisited - Possibility of Higgsinium Creation?
  • Thread starter SkepticJ
  • Tags
    Stuck
In summary, the article from 1986 discusses the concept of Higgsinos and their potential role in fusion energy. However, with the development of the Minimal Supersymmetric Standard Model, the idea of Higgsinos has changed and they are now believed to be part of neutralinos. Making a "higgsinium" under this current theory would still be possible, but it would require a large particle accelerator and the resulting particles would be unstable. This makes the use of Higgsinos for fusion energy highly unlikely.
SkepticJ
244
The following is an old article from 1986: http://www.frc.ri.cmu.edu/~hpm/project.archive/general.articles/1986/dense.ltx
I've been told that Supersymmetry theory has changed a bit since the article was written. Under the new theory + - higgsinos are stuck together and they in turn are part of neutralinos. Not being a particle physicist myself and only as smart as what I understand on wikipedia.com ; I ask do you know if making higgsinium could still be possible under the current theory, if there really are higgsinos and all those other still hypothetical particles?
Well, if we assume that the Minimal Supersymmetric Standard Model is correct (a very big assumption!) then Higgsinos will be there. The charged ones will interfere quantum mechanically with themselves and the charged winos to give charginos, and the neutral ones will interfere along with the zino and photino to form neutralinos.
Let's assume this mixing is very small, so the two charged Higgsinos remain more-or-less unchanged.
As for making a 'higgsinium', I suppose it would be possible, although to create a +/- Higgsino pair at the same time would require a huge particle accelerator, since they would have very large mass (probably at least twice the Z mass- each!). If you could get the things into a bound state, it would appear as a resonance in detector cross-sections, not a new particle leaving the detector, as both the higgsinos would be extremely unstable.
They certainly wouldn't hang around long enough to use them to promote fusion like the article suggests.
Thank you for sharing this old article about Higgsinos and the possibility of Higgsinium creation. It is interesting to see how scientific theories and understanding can evolve and change over time. As you mentioned, the theory of Supersymmetry has indeed undergone some revisions since this article was written in 1986.
In the current theory, Higgsinos are still a part of Supersymmetry, but they are now believed to be combined with other particles called neutralinos. These neutralinos are also hypothetical particles and their existence has not yet been proven. Therefore, the creation of Higgsinium, which would require the existence of Higgsinos and neutralinos, is still a topic of speculation and research.
It is important to note that the concept of Higgsinium itself is also still a theoretical construct and has not been observed or confirmed in any experiments. While the Higgs boson has been discovered, the existence of Higgsinium and its properties are still a subject of study and investigation.
In summary, while the current theory of Supersymmetry does include Higgsinos, the creation of Higgsinium is still a possibility that requires further research and evidence. As with any scientific theory, it is always evolving and subject to change as we learn more about the universe and its particles.
FAQ: Higgsinos: An Old Theory Revisited - Possibility of Higgsinium Creation?
What are Higgsinos?
Higgsinos are hypothetical particles that are predicted by the Standard Model of particle physics. They are a type of supersymmetric particle that is thought to interact with the Higgs field, which gives particles mass.
How do Higgsinos get stuck together?
Higgsinos are thought to interact with each other through the Higgs field, which results in them becoming "stuck" or bound together. This interaction is similar to how other particles, such as electrons and protons, are bound together by the electromagnetic force.
What is the significance of Higgsinos being stuck together?
If Higgsinos do exist and are stuck together, it could provide evidence for the existence of supersymmetry, which is a theory that suggests there is a deeper symmetry between particles and forces in the universe. This could help explain some unanswered questions in physics, such as why particles have different masses.
Can Higgsinos be unstuck?
It is currently unknown whether Higgsinos can be unstuck or separated from each other. This would depend on the strength of the interaction between them and the Higgs field. Further research and experimentation is needed to determine if this is possible.
How are scientists studying Higgsinos being stuck together?
Scientists are using powerful particle accelerators, such as the Large Hadron Collider, to try and create and observe Higgsinos. They are also using data from these experiments to search for any evidence of Higgsino interactions and to better understand their properties and behavior.
