Scientists cover the mirror with a stratum that doesn't hold water
  • Level: High School
  • Thread starter Thread starter sitokinin
    Mirror Water
2 replies · 3K views
sitokinin
I'm a high school student.
I heard that scientists cover the mirror with a stratum that doesn't hold water. Thus when you get out of the shower, you can see your reflection into the mirror in a smooth way.
I've been searching this structure. I want to indicate my ideas with composing them. How does the atoms in this system line? Could you suggest me a website or a direct person to find what the system's strucure is?
As far as I know (which is very little) the idea is simply to first aplly a thin coat of an oil followed by a similar coat of some detergent. The detergent molecules have hydrophilic and hydrophobic ends. The hydrophobic ends bond well with the oil layer, making the hydrrophilic ends stick out. When a water droplet forms on the mirror, the hydrophilic ends stick to the surface of the droplet reducing its surface tension. This causes the water to bead up, rather than form a fine foggy dispersion or layer.
It's not much different from a car wax, I imagine. The only significant difference is that you might want the thickness of the layers to be not much larger than the wavelength of light (less than 0.5 microns thick).
Hmm... I wonder that do the scientists line these atoms just top of the mirrors surface or they line them with an orderly regulation?
