Using excel to determine equation.
  • Thread starter denian
  • Tags
    Excel
In summary, to obtain the equation of the curve from Excel, you can use the "add trend" line option and choose the line that best fits your data or use the LINEST command for linear data. You can also extrapolate the data by "drag filling" the column with a constant change in x value.
denian
641
i already enter the data, and then obtain the curve graph for the data.
how can i obtain the equation of the curve from excel?
Computer science news on Phys.org
and another question, i have data from day 1 to day 21. how can i get the extimated value for day 30 with excel?
any help will be appreciated.
After charting your data select the "add trend" line option. You are given the choice of several different line fits, choose the one that is defined by the under lying math of your data... Or chose the one that is a close match to the trend in your data. In the trendlines options there is a check box for displaying the equation on the chart.
If your data is linear, you can also use the LINEST command to compute the slope and intercept of the best fit line. This is the same as choosing a linear fit trend line, except the slope and intercept are more easily used to extrapolate (this the official name of extending a trend line beyond your data set.
You can also extrapolate by selecting your data and "drag fill" the column until you get beyond the x value you need. For this to work you need a constant [itex] \Delta [/itex]x in your data.
thank you.
FAQ: Using excel to determine equation.
What is the purpose of using Excel to determine an equation?
The purpose of using Excel to determine an equation is to analyze and interpret data in a more efficient and organized manner. Excel allows for easy input and manipulation of data, making it easier to find patterns and relationships between variables, and ultimately determine an equation that accurately describes the data.
Can Excel be used for any type of equation?
Yes, Excel can be used to determine equations for various types of data, including linear, quadratic, exponential, and logarithmic equations. It also allows for multiple variables and complex equations to be analyzed and determined.
How does Excel calculate an equation?
Excel uses the least squares method to calculate an equation. This involves finding the line or curve of best fit that minimizes the distance between the data points and the line/curve. Excel uses a mathematical algorithm to determine the coefficients of the equation that best fits the data.
Are there any limitations to using Excel to determine an equation?
While Excel is a powerful tool for data analysis, it does have some limitations when it comes to determining equations. It may not be able to accurately determine an equation if the data is too scattered or if there are outliers present. In these cases, it is important to use your own judgment and adjust the data accordingly.
Can Excel determine the uncertainty or error in the equation?
Yes, Excel has built-in functions that can calculate the uncertainty or error in an equation. These functions include STEYX for linear equations and TREND for exponential and polynomial equations. It is important to use these functions to assess the accuracy of the determined equation.
