Scuba Diver Bubble: Diameter at Surface?
A spherical air bubble originating from a scuba diver at a depth of 18 m with a diameter of 1 cm will expand to a diameter of 1.4 cm upon reaching the surface, assuming constant temperature. The calculation involves hydrostatic pressure, defined by the formula p = po + density * g * h, where po is atmospheric pressure, density is the water's density, g is the acceleration due to gravity, and h is the depth. The discussion emphasizes the importance of understanding pressure conversion in relation to depth in water.
  • Understanding of hydrostatic pressure principles
  • Knowledge of the ideal gas law
  • Familiarity with basic physics concepts related to buoyancy
  • Ability to perform calculations involving density and pressure
  • Study the ideal gas law and its applications in scuba diving
  • Learn about the effects of pressure on gas volume in fluids
  • Research hydrostatic pressure calculations in different fluid densities
  • Explore the relationship between depth and pressure in various aquatic environments
Scuba divers, physics students, and anyone interested in understanding the behavior of gases under pressure in aquatic environments.
pkossak
A spherical air bubble originating from a scuba diver at a depth of 18 m has a
diameter of 1 cm. What will the bubble's diameter be when it reaches the
surface? (Assume constant temp)
a. 0.7 cm b. 1 cm c. 1.4 cm d. 1.7 cm
I know this problem shouldn't be all that difficult, but I'm not sure how to convert the depth into pressure. I would think they would say whether or not the water was sea water, so I was wondering if there was another way to figure this out other than through using density. Maybe I am over analyzing and that part was simply left out, but I just wanted to be sure. Thanks again help.
yes i believe you are making it harder than it really is.
hydrostatic pressure is defined by
p = density * height of liquid
try this and see if it helps
Thanks for the help. I ended up using p = po + density*g*h and got the answer I was looking for.
  • · Replies 25 ·
  • · Replies 33 ·
10K
  • · Replies 16 ·
