Exploring Surface Terms: Understanding the Meaning Behind the Term 'Surface Term
In summary, a surface term is a term that results from integration over the boundary of a region, while a bulk or volume term results from integration over the entire region. This concept is often used in physics and mathematics, and can be related to conservation laws and Stokes' theorem. It is commonly seen in the context of integration by parts, where it is referred to as the "surface term". The notation for surface terms may vary, but can be represented using HTML entities or Unicode characters.
Ratzinger
291
what is meant by the term 'surface term'?
thank you
Mathematics news on Phys.org
I have no idea! Could you give us some context- the complete sentence or even paragraph where you saw it?
Well, I remember reading it in a quantum field textbook (Zee?), but don't know more where exactly. The first two google pages give things like "a Ginzburg-Landau model with a surface term" or "Chern-Simons Integral as a surface term". So it seems to be physics language.
I thought it is a household (mathematical) term, because I remember the author used it without further explaining.
Have to note that my math and physics skills are not too advanced, can deal with upper undergraduate physics texts, but have hard times with more. (Especially when they throw in terms and equations from out of nowhere.)
Usually a surface term is a term that results from integration over the boundry of some region. Them a bulk or volume term results from integrating over the region. Surface and boundry terms are related by stokes theorem and by conservation laws. A common example is a surface term equal to the flux of some quantity through the boundry of a surface equals the rate of change in the amount of the quantity inside the surface. It might help to think of the 1-D situation
[tex]\frac{d}{dt}\int_{a(t)}^{b(t)} f(x,t) dt=\int_{a(t)}^{b(t)} \frac{\partial}{\partial t}f(x,t)dx+f(x,t)\frac{\partial x}{\partial t}\displaystyle{|_{x=a(t)}^{x=b(t)}}[/tex]
So in 1-D integrals are bulk terms and differences are surface terms. Often in applications the bulk terms are integrals over 3-D regions and surface terms are integrals over 2-D boundries of 3-D regions.
thanks lurflurf...why aren't you science adviser or homework helper yet?
I've seen it used in the context of integration by parts:
ab u dv = uv|ab - ∫ab v du
in which case the first term on the right is called the "surface term".
This is off the subject, but -- PBRMEASAP, how did you make the math notation without tex?
right click on the eq and view source.
Does that mean I need to type character string &-#-8-7-4-7 (without the dashes) to make the ∫ sign?
hmm. I painted and viewed the selection source again but it seems like he copy/pasted the integral sign from somewhere else. the rest is html. oh well, tex is better looking and easier anyway.
& int ; [ sub ] a [ /sub ] [ sup ] b [ /sup ]
without the spaces gives ∫ab.
I haven't figured out how to make the superscript go directly over the subscript. You can also make greek letters:
& alpha ;
& beta ;
& gamma ;
gives
α, β, γ, etc.
You can't really do that without an appropriate stylesheet, since they are separate characters in a standard font. MathML has appropriate styles for this, but is not exactly commonly used. The complete list of standard HTML 4 entities can be found here. A complete list of all possible Unicode hex characters (entered by &#x followed by the hex code) can be found at Unicode's charts site. Note that while most fonts implement some subsets of the Unicode character set, not all characters are encoded in the most common fonts (so the less common characters are likely to be rendered as the empty box on others' browsers).
FAQ: Exploring Surface Terms: Understanding the Meaning Behind the Term 'Surface Term
What is the definition of surface terms?
Surface terms refer to specific words or phrases that are used to describe the physical features and characteristics of an object or material. These terms are often used in scientific research and can include descriptors such as texture, color, shape, and composition.
Why is it important to understand surface terms?
Understanding surface terms is crucial in the field of science as it allows researchers to accurately describe and communicate their findings. It also helps in identifying and differentiating between various materials and objects, which is essential in many scientific experiments and investigations.
How are surface terms used in different scientific disciplines?
Surface terms are used in a wide range of scientific disciplines, including biology, chemistry, physics, and geology. In biology, surface terms are used to describe the external features of organisms, while in chemistry, they are used to describe the physical and chemical properties of substances. In physics, surface terms are used to describe the surface tension and properties of liquids, and in geology, they are used to describe the characteristics of rocks and minerals.
What are some common misconceptions about surface terms?
One common misconception about surface terms is that they are subjective and can vary from person to person. However, surface terms are based on objective measurements and can be accurately defined and described. Another misconception is that surface terms only refer to the outermost layer of an object, but they can also describe the properties and features of the entire surface, including any layers beneath the surface.
How can we ensure consistency in the use of surface terms?
To ensure consistency in the use of surface terms, it is important to establish clear and standardized definitions for each term. This can be achieved through collaboration and communication among scientists, as well as referencing established scientific databases and resources. It is also crucial to use precise and accurate measurements when describing surface terms to avoid any confusion or discrepancies.
