Having problem showing the vectors point in the same dir. its a 0 Vector?
The discussion revolves around a problem involving vectors, specifically the relationship between two vectors and their directions. The original poster is tasked with demonstrating that two vectors are in the same direction, with a particular focus on the zero vector and unit vectors derived from given distances.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the original problem's requirements, including the need to convert distances into unit vectors. There are attempts to clarify the relationship between the vectors and the zero vector, as well as the implications of proving that the vectors are parallel.
The conversation is ongoing, with various participants offering hints and suggestions for approaching the problem. Some guidance has been provided regarding the formulation of unit vectors and the algebra involved, but there is no explicit consensus on the correct interpretation or solution path.
Participants express confusion over the definitions and relationships of the vectors involved, particularly concerning the zero vector and the distances d1 and d2. There are indications of missing information and assumptions that are being questioned throughout the discussion.
mr_coffee
Hello everyone, I'm really stuck on this problem, the algebra is killing me. The professor said Show that the two vectors are in the same direction, but the fact is, its the zero vector he said. So it points to nothing or points everywhere. He told us to convert the diagram into Unit vectors. So I first found the distance d1 and d2. Then found the midpoint. I then attempted to find the Unit vectors by taking the (1/|A|) <x,y,z> but its getting really messy, and I'm stuck, any help would be great! Click the link for the picture:
http://www.imagehosting.us/index.php?action=show&ident=653183
"The professor said Show that the two vectors are in the same direction, but the fact is, its the zero vector he said."
Do you realize that that sentence makes no sense? You start of by talking about two and then say "it's the zero vector". What is "it"? What is the relation between the original two vectors and that "zero vector"?
". He told us to convert the diagram into Unit vectors. So I first found the distance d1 and d2. Then found the midpoint. I then attempted to find the Unit vectors by taking the (1/|A|) <x,y,z> but its getting really messy, and I'm stuck, any help would be great! Click the link for the picture!"
This makes no sense without knowing what d1 and d2 or, for that matter, what it is you are trying to do. I finally got the picture to enlarge but it doesn't say what you are trying to do! What is the question??
It sounds to me that you are being asked to prove that vectors D1 and D2 are parallel. Perhaps he asked you to demonstrate that their cross-product is zero?
Its weird how this question became, sorry for the confusion. The orginal question was the following: (a) prove that the midpoint of the line segment from P1(x1,y1,z1) to P2(x2,y2,z2) is ([x1+x2]/2,[y1+y2]/2,[z1+z2]/2). So from this, he drew that picture I have posted, he labed the total length of the vector d1, he labled the midpoint d2 as shown in the drawing. So he found the distance of d1 and d2 as shown in the drawing. He then Stopped and said, now show that the vectors are pointing in the same direction. And someone said well its the 0 vector, and he didn't disagree with him, but he said why is it the 0 vector? So maybe it isn't hte 0 vector at all. So he then said, put that in Unit Vector form as a hint. The equation of a unit vector is the following: u = (1/|a|)*a = a/|a|; So he then said, bascially all you have to do is the following: 1/d1 * V1 and 1/d2 * U2. V1 is d1 and U2 = d2. and V1 and U2 are vectors. Does that help you any Doc?
From any vector you can create a unit vector in the same direction, using the formula given. ([itex]\hat{a} = \vec{a}/{|a|}[/itex]). So, for each vector, D1 and D2, find the corresponding unit vector. Of course, these unit vectors will be identical, proving that the vectors are parallel. (Of course, this is overkill... but a good exercise.)
I don't understand how I'm suppose to simplfy what i have though, I understand the concept i just have no idea how to simplfy the algebra
Here's a hint:
[tex]x_2 - \frac{(x_2 + x_1)}{2} = \frac{(x_2 - x_1)}{2}[/tex]
You made a huge mistake:
[tex]\sqrt{a^2 + b^2} \ \ne \ a + b[/tex]
(Test this with a few numbers to realize the problem. For example, let a = 3, b = 4.)
Thanks for the help Doc. Can u see if I proved it or do i have to do more? Here is my work:
http://img238.imageshack.us/img238/7470/calciiii2mv.jpg
You are almost there. (You have the algebra part right) But the vectors are the differences in the coordinates. For example, the vector "d1" should be:
[tex]\vec{d_1} = (x_2 - x_1)\hat{i} + (y_2 - y_1)\hat{j} + (z_2 - z_1)\hat{k}[/tex]
Isn't my d1 the same as the one you just posted, mine is just under a square root sign and I didn't write the unit vectors besdies the differences, is that all your saying I need to do? or are you saying I need to try to simplfy it so d1 looks exactly like yours? I hope not because i have no idea how to get ride of that square root sign :bugeye:
As far as I can tell, you seem to take your unit vector representing "d1" to be:
[tex]\hat{d_1} = (1/d_1)[ (x_1)\hat{i} + (y_1)\hat{j} + (z_1)\hat{k}][/tex]
And the one representing "d2" to be:
[tex]\hat{d_2} = (1/d_2)[ (x_2)\hat{i} + (y_2)\hat{j} + (z_2)\hat{k}][/tex]
Not true. Good luck proving these vectors to be equal! (They're not.)
The real "d1" unit vector should be:
[tex]\hat{d_1} = (1/d_1) [(x_2 - x_1)\hat{i} + (y_2 - y_1)\hat{j} + (z_2 - z_1)\hat{k}][/tex]
And the real "d2" unit vector should be:
[tex]\hat{d_2} = (1/d_2) [((x_2 + x_1)/2 - x_1)\hat{i} + ((y_2 + y_1)/2 - y_1)\hat{j} + ((z_2 + z_1)/2 - z_1)\hat{k}][/tex]
These are the unit vectors that you should prove are equal. (Using the same algebraic manipulations that you've been doing.)
THanks again Doc:smile: , I totally forgot I had to make them into vector form. Does this prove it?
http://img209.imageshack.us/img209/7140/blee9el.jpg
I think you are using [itex]\vec{v}[/itex] and [itex]\vec{u}[/itex] to represent the unit vectors that I called [itex]\hat{d_1}[/itex] and [itex]\hat{d_2}[/itex]. If so, your job is to show that [itex]\vec{v} = \vec{u}[/itex].
That means you need to show that your fourth equation (for [itex]\vec{u}[/itex]) is identical to your second equation (for [itex]\vec{v}[/itex]). Since your fourth equation still is in terms of d2, while your second equation is in terms of d1, you aren't done yet.
hm...I showed that d1 = 4*d2, doesn't that make d1 == d2? so having d1 under V and d2 under U shouldn't make a difference or isn't that the way its going to work?
For one thing, d1 = 2*d2. (You forgot a square root in your work from post #10.) And when doing a proof, you just can't leave out the last step!
ahh good call, sorry my bad. I'm not very good at math, I came to this conclusion, luckly I'm almost done :) Thanks for the help as usual Doc!
why would d1 = 2*d2? If i have d2 = 2*sqrt(junk); wouldn't d2/2 = sqrt(junk), so d1 = d2/2 ?
Sure... if!
so d1 = d2/2 ?
Where did this come from?
Review your work in post #10.
thanks, so now if i wanted to use d2 in an expression, would I bring that 1/2 on the left side so it would be 2*d2 = sqrt((x2-x1)^2 + (y2-y1)^2 +(z2-z1)^2);
So when I use it in this expression:
1/d2 * [(x2-x1)/2 i + (y2-y1)/2 j + (z2-z1)/2) k];
1/(2*d2) * [(x2-x1)/2 i + (y2-y1)/2 j + (z2-z1)/2) k];
see what I'm asking?
There's nothing wrong with doing that since it's a perfectly legitimate mathematical move. (But I don't see why you would.)
Realize that in going from line 1 to line 2 you replaced d2 by 2*d2. What makes you think you can get away with that? (And what does that have to do with what you asked above?)
Assuming you are still working on the given problem, what you need to be doing is expressing both unit vectors in terms of d1. (That way you'll be able to prove them equal.)
Not yet. :wink:
14K
15K
