Net force on a Merecedes convertible
The net force on a Mercedes convertible traveling at a steady speed of 110 km/hr is zero, as the forces acting on the vehicle are balanced. This principle is illustrated through the example of a book sliding at constant velocity, where the force of friction equals the applied force, resulting in no net force. The discussion emphasizes the importance of understanding Newton's Laws, particularly the first law, which states that an object will remain at rest or in uniform motion unless acted upon by a net external force.
  • Newton's First Law of Motion
  • Understanding of force and friction concepts
  • Basic knowledge of tension in ropes
  • Familiarity with constant velocity scenarios
  • Study Newton's Laws of Motion in detail
  • Explore the concept of net force and equilibrium
  • Learn about frictional forces and their calculations
  • Investigate tension in systems with multiple objects
Students of physics, automotive engineers, and anyone interested in understanding the principles of motion and forces in real-world applications.
92EG6
this is really into stuff and i fell really dumb that i can't figure this stuff out...
What is the net force on a Merecedes convertible traveling along a straight road at a steady speed of 110 km/hr? Answer in N
Where do i start?
If it takes 1 N to push horizontally on your book to make it slide at a constant velocity, how much force of friction acts on the book? Answer in N
If the book keeps moving at that constant speed i figured that i would be 0 but i was wrong... what am i doing wrong?
Three identical blocks are pulled on a horizontal frictionless surface. If tension in the rope held by the hand is T = 60 N, what is the tension in the other ropes?
Where do i start?
Thanks
The engine is generating a force which is making the car move forward. When you are traveling at a constant speed in your car it means that the drag forces are equal to the force generated by the engine.
In short, just like with the book the forces in one direction are balanced by the forces in the other. This is why the book moves at constant speed! The forces are balanced.
Something will only change its speed or velocity if there is a NET or overall force.
I strongly recommend you read Newtons Laws. In particular the first! This will explain this and much more.
:smile:
thanks that helped
  • · Replies 28 ·
  • · Replies 22 ·
  • · Replies 22 ·
