Relativity Question: Light Moving at 2 Speeds at Once?
  • Thread starter Thread starter Chiko
The discussion revolves around a question related to the principles of relativity, specifically concerning the behavior of light in different reference frames. The original poster presents a scenario involving two observers, one on a spaceship and another on the ground, and questions how the speed of light is perceived by each observer when the spaceship is moving at the speed of light.
  • Participants explore the implications of special relativity, particularly the constancy of the speed of light and how it differs from classical velocity addition. Questions arise about the validity of applying classical concepts to relativistic scenarios.
Some participants provide insights into time dilation and length contraction, suggesting these concepts may clarify the original poster's confusion. Others express their own uncertainties and seek further understanding of the principles involved, indicating a collaborative exploration of the topic.
There is mention of the limitations of applying classical physics to relativistic speeds, and participants acknowledge the complexity of the concepts being discussed, particularly for those new to physics.
Chiko
Hey, i asked my physics teacher this, but he wasent interested in explaining it to me :mad:
Person A is on a boat moving at 10km/h
Person B is on the ground standing still
Person C is walking foward on the boat at 2km/h
Person C in relation to PA is moving at 2km/h
and PC in relation to PB is moving at 12km/h
I understand this concept, but my book said that it does not apply at speeds near the speed of light. So here's my question:
Person A is on a spaceship (pretend, for simplicity reasons) cruizing at the Speed of light.
Person B in standing still on the ground.
PA turns on a flashlight pointing foward.
The light in relation to PA moves foward at the speed of light.
But in relation to PB the light would move at a speed of 2 times the speed of light, right?
However, my teacher told me that in relation to both people the light would be moving at the same rate. Which would mean that the light is traveling at 2 speeds at once (SoL in relation to PA and 2SoL in relation to PB - because the spaceship is cruizing at SoL). This highly confuses me, please explain?
Thanks in Advance
Chiko
This is a basic problem in relativity. To understand it with no math, you have to remember that relativity also "generates" (the word isn't correct because the effect would also exist if we hadnt discovered SR !) time dilatation and length contraction.
Where you think there should be different speeds, there is only one, and this is easily explained when you remeber those effects : the distance light has to travel is in fact a bit shorter and time is dillated.
Moreover, the well-knnown formula v(total) = v1 + v2 to add velocities is false in SR. vtotal = (v1 + v2) / (1 + (v1 * v2)/c²)
Sorry if my message is a bit confusing but it's 1.30am in France and i am quite tired :(
PS : Be careful, you cannot travel at the speed of light, and you cannot use SR in frameworks going at the speed of light.
Excuse me?
Let's say the spaceship is going past the person at .99C, than the light from the flashlight is passing the spaceship at the speed of light. The light from the flashlight is moving away from the "stationary" person at the speed of light also. That's why there is time dialation.
Time dilation huh? I am thinking this question is over the head of a just starting physics one student, hehe. Cause I am still totally lost. Because I am relating the speed the light is traveling to the speed person C traveled in the first problem - just they have different speeds. But time dilation and such thrown into the mixture would change stuff i assume.
Ill read over this a few times and see if i can make sense - Wish me luck! ^.~
Chiko
If you shine a flashlight on earth, you can measure it to be going exactly what we think it would go. If you do the same on a the moon, you would see it is the exact same velocity as it was on earth, yet the moon is not stationariy relative to the earth. If you understand the concept that the speed of light will always be going the same exact velocity relative to anything, you may be closer at understanding a lot of things.
Or, if you are drifting in space, you may feel as if you were stationary. You shine a flashlight and you measure it to be exactly what it is on earth. Yet, relative to certain stars, you could be going extremely fast.
Think for a second about the reason this is true. It does seem intuitively obvious because the low speeds we constantly deal with in every day life do behave this way, but is there any real reason to believe this is the way the universe should behave? Is it a priori (something you know independent of experience) or a posteriori (something you know because of experience)? It may be hard to accept, but it turns out that the Galilean addition of velocities law ([itex]v_{AC}=v_{AB}+v_{BC}[/itex]) is not independent from experience. We know we can add velocities only because it works so well in every day activities.
However, Einstein showed us that the Galilean equation for the addition of velocities is only an approximation. The way relative velocities truly compare in our universe is similar but not quite Galilean:
[tex]v_{AC}=\frac{v_{AB}+v_{BC}}{1+\frac{v_{AB}v_{BC}}{c^2}}[/tex]
Using this equation we can see that if observer C is moving 2 km/h relative to observer B ([itex]v_{BC}=2 km/h[/itex]) and observer B is moving 10 km/h relative to observer A ([itex]v_{AB}=10 km/h[/itex]) then observer C is moving extremely close to 12 km/h relative to observer A ([itex]v_{AC}{\approx}12 km/h[/itex]) since the speed of light is so large ([itex]c=1,079,252,848.8 km/h[/itex]), but as [itex]v_{AB}[/itex] or [itex]v_{BC}[/itex] gets closer and closer to [itex]c[/itex], the more the Galilean answer starts to deviate from the relativistic addition of velocities. And as you can see, if you fill in either [itex]v_{AB}=c[/itex] or [itex]v_{BC}=c[/itex] then [itex]v_{AC}[/itex] will always equal c.
Thats quite interesting! I am sooo glad i finally got into the world of physics. I am closer to understanding this, but not quite there yet (maybe because the equations i don't know yet... ill look up those and read about them sometime soon.) Thanks for all the imput!
-Chiko
just curious, why was this moved to the homework section? it didnt sound like homework to me.. :confused:
  • · Replies 26 ·
  • · Replies 50 ·
  • · Replies 51 ·
  • · Replies 19 ·
  • · Replies 18 ·
