Ecliptic Plane's relation to Galactic Plane
In summary, the orientation of the ecliptic plane of our solar system in relation to the plane of the galaxy is aligned within 5.5 degrees, according to one source. However, another source states that the orbital planes are 63 degrees apart. It is not certain which is correct. The solar system does not have a fixed distance above the mid-plane of the galactic disk and its motion is not a simple ellipse due to various perturbations such as vertical oscillation and encounters with giant molecular clouds. The estimated "orbit" of our solar system around the galaxy is approximately 225-250 million years.
Glenn
Hi,
What is the orientation of the ecliptic plane of our solar system in relation to the plane of the galaxy?
One source I found said they were aligned to within 5.5 degrees. http://www.Earth'sky.com/2000/es000304.html
Another source I found stated that the orbital planes were 63 degrees apart. http://www.essex1.com/people/stauffer/MLS/solarsys.html
Does anyone know for sure?
Also, are all of the orbital parameters of our solar system around the galactic core known?
Thanks,
Glenn
Astronomy news on Phys.org
Originally posted by Glenn
Hi,
Thanks,
Glenn
The nearest bright star to the North Galactic Pole is Arcturus, in the constellation Bootes. I haven't made a measurement, but this is far more than 5.5 degrees; sounds like the 63 degrees is about right.
http://www.site.uottawa.ca:4321/astronomy/index.html#galacticcoordinatecomponent says:
"North galactic pole is a part of Coma Berenices
has galactic latitude 90 degrees
is opposite of south galactic pole
has acronym NGP
has definition A point in the constellation Coma Berenices where we look perpendicular to and above the Galactic Plane. The nearest bright star to the North Galactic Pole is Arcturus, in the neighboring constellation Bootes."
Labguy
From your first link:
Astronomical theories predict that the plane of the solar system should lie in the plane of the galaxy. And it does. The solar system is tipped by only about 5.5 degrees out of the galactic plane.
I don't know who these guys are, but I don't think either of those statements is correct.
- Warren
not 5.5 degrees!
Here are two short pages with explanations and formulae:
http://www.ess.sunysb.edu/fwalter/PHY515/coords.html
http://scienceworld.wolfram.com/astronomy/GalacticCoordinates.html
An all-sky summary of the IRAS (infrared astronomy satellite) observations:
http://coolcosmos.ipac.caltech.edu/image_galleries/IRAS/allsky.html
This is an Aitoff projection, in galactic coordinates. See the blue band running across the middle, at an angle of ~60o? That's the ecliptic plane, blue because the fine particles which lie in the ecliptic plane (and give us the zodiacal light) are hot compared with the dust etc which gives rise to the galactic emission.
I'm not sure what you're asking Glenn. We know the distance to the galactic centre, the distance above the mid-plane of the disk, the time it takes to make one revolution, ... the eccentricity isn't well known though.
Do we know the inclination? Is there an inclination or does our solar system maintain a fixed distance above the mid-plane of the galactic disk?
Basically I am asking if the solar system actually "orbits" the center of the galaxy?
Thanks,
Glenn
not that kind of orbit!
AFAIK, the motion isn't a simple ellipse.
For example, there is a 'vertical' oscillation, about the mid-plane of the disk. I don't remember what the period of this oscillation is, but it's unlikely to be a simple fraction of the rotation period. The amplitude is modest, only a few tens of parsecs, IIRC.
Then there are encounters with giant molecular clouds, which don't necessarily orbit the centre of the galaxy in the same way the Sun does.
Lately nearby galaxies in the process of being canabalised by the Milky Way have been discovered (Saggitarius, Carina); the extent to which they affect the orbit of the Sun is, as yet, unknown.
There are a bunch of interactions (pertubations) as you say, but most sites quote a 225 to 250 million year "orbit" for our solar system around the galaxy. That's a long time, but still very short on the time scale of galactic collisions.
http://www.chron.com/content/interactive/space/astronomy/news/1999/ds/990602.html
states 226 million years.
Labguy
FAQ: Ecliptic Plane's relation to Galactic Plane
What is the Ecliptic Plane?
The Ecliptic Plane is the imaginary plane that represents the Earth's orbit around the Sun. It is also the plane in which the Sun and all the planets in our solar system appear to move when viewed from Earth.
What is the Galactic Plane?
The Galactic Plane is the central plane of our Milky Way galaxy, where the majority of its stars, gas, and dust are concentrated. It is also sometimes referred to as the "Galactic Equator".
How are the Ecliptic Plane and Galactic Plane related?
The Ecliptic Plane and Galactic Plane are not aligned with each other. They are inclined at an angle of approximately 60 degrees. This means that the two planes intersect at two points, creating an X-shape. This intersection is known as the "Galactic Nodes".
What is the significance of the Ecliptic Plane's relation to the Galactic Plane?
The intersection of the Ecliptic Plane and the Galactic Plane has important implications for astronomy and astrophysics. It affects the distribution and motion of celestial objects, as well as the way we view and study them from Earth.
How does the Ecliptic Plane's relation to the Galactic Plane affect the Earth?
The intersection of the two planes also has an impact on Earth's climate and seasons. This is because the Earth's orbit around the Sun is tilted relative to the Galactic Plane, causing changes in the amount of sunlight received by different parts of the Earth throughout the year.
