Gravitation: Looks easy at first
  • Thread starter squiffy
  • Tags
    Gravitation
In summary, the problem of two masses of 1 kilogram each being 1 metre apart and reaching each other from their attractive gravitational forces can be solved by considering the kinetic energy at the start and end of the system. This approach yields a result of approximately 37 hours. Alternatively, assuming the rate of change of acceleration is constant can give an approximation of 24.05 hours, but this may not be a valid assumption.
squiffy
Hi, all. I have a problem I wish to solve. It's not from a textbook, I thought of it myself.
If two masses of 1 kilogram each are 1 metre apart in space, how long will it take for them to reach each other from their attractive gravitational forces?
Remember that the force (and hence the acceleration) acting on each mass increases as the distance between them decreases, (by F=Gm1m2/r^2).
Assume that no friction or other gravitational forces act on the masses.
Thanks.
Well, assume each sphere must travel half the distance, and the acceleration is given by g = Gm/d2, where d is the separation of CM's.
So if x is the separation distance, each sphere must travel x/2 and the separation d = x + 2r, where r is the radius of the spheres, assuming they are the same size.
Since the acceleration isn't constant, then you could find the average acceleration (by using calculus - integrate and divide) and use that to find the time.
Or I'm not sure if you can do this (I'd use cal) but you can say that:
[tex]
a = \frac{Gm}{d^2} [/tex]
[tex]
d = \frac{Gmt^2}{2d^2} [/tex]
[tex]
d = \sqrt[3]{\frac{Gmt^2}{2}}
[/tex]
for d you want 2r. Put that in and solve for t.
Ok, let me show you what I did before posting here.
[tex]
F = \frac{{Gm_1 m_2 }}{{r^2 }}
[/tex]
But [tex]
m_1 = 1, m_2 = 1
[/tex]
and [tex]
F = ma
[/tex]
So:
[tex]
a = \frac{G}{{r^2 }}
[/tex]
Now, r is the distance between the two masses, so taking the initial position of the first mass as the origin, r can be expressed as:
[tex]
r = d_2 - d_1
[/tex]
But, [tex]
d_2 = 1 - d_1
[/tex]
So:[tex]
r = 1 - 2d_1
[/tex]
And therefore: [tex]
a = \frac{G}{{(1 - 2d)^2 }}
[/tex]
Integrate twice to get:
[tex]
d = \frac{G}{{2(1 - 2d)^2 }}t^2
[/tex]
Now, total distance traveled (D) can be expressed as the integral of distance (s) from 0 to a certain time (t) with respect to time.
[tex]
\int_0^t s \,dt = D
[/tex]
We already know that D = 1/2. It's the distance one of the masses travels before colliding with the other mass. So we get the integral:
[tex]
\int_0^t s \,dt = \frac{1}{2}
[/tex]
However, the problem arises when I try and rearrange this to have d in terms of t:
[tex]
d(1 - 2d)^2 = \frac{G}{2}t^2
[/tex]
It's obviously a cubic, which makes it difficult to rearrange.
Do I need to rearrange it to integrate it? Is there a simpler method of doing this?
Thanks.
The problem with this is that the acceleration equation is an instantaneous equation. We know the acceleration necesarily depends on time because as the two objects get closer the force between them gets larger and therefore the acceleration increases too. The time dependence comes merely from the distance between the two particles. You can model this by saying da/dt (that is the rate of change of acceleration) is a constant and integrating thrice to obtain how r(t) changes with time. The only problem then comes in solving what da/dt is. I suspect you could put r(t) into the instantaneous acceleration equation then you have two unknowns (da/dt and t) and two equations. I'll have a bash at it later on and see what i get because I'm busy right now but your question caught my attention.
Good luck solving it!
Hmm, on second thoughts what I've done is completely wrong.
When I integrated this:
[tex]
[/tex]
I accidently assumed that d was constant, which it isn't. It's a function of t, so it has to be integrated itself.
So the big problem is finding d in terms of t.
Any ideas?
Like i say if you assume the rate of change of acceleration is constant then r(t)= (1/6)(da/dt)t^3 plus some arbitrary constants. Its a very difficult problem to solve but very intriguing.
So has anybody actually solved this yet?
[tex]
\int_0^t s \,dt = D
[/tex]
No, its either
[tex]\int{ds}[/tex]
or
[tex]\int{v} {dt}[/tex].
To spiffy:
Due to the symmetry, it is easiest to analyze the problem from the perspective of one of the masses. The force acting on it is from the equation governing gravitation. And the acceleration is simply that divided by mass. Now as for the kinematics analysis:
Create an axis in the middle between the two masses. Create two vectors r1 and r2 from this center to the masses. Also, create a starting point where mass 1 originally is such that [tex] s = 1-r_1, ds = -dr_1[/tex]. You can then apply the integral formula:
[tex] \frac{d^2s}{dt^2} = a [/tex]
and solve for s accordingly where [tex] a = \frac{Gm_2}{(r_1+r_2)^2}[/tex], and also due to symmetry [tex]r_1 = r_2[/tex].
mezarashi:
How do you propose to solve the problem that the acceleration changes with time?
Kurdt said:
mezarashi:
The general equation
[tex] \frac{d^2s}{dt^2} = a(r_1) [/tex]
is applicable to non-constant acceleration. By using the change of variables [tex] r_1 \longrightarrow s [/tex], we can then solve the differential equation.
[tex]a = \frac{G}{{r^2 }}[/tex]
Be careful there.
Remember F = G (m1m2)/r2 and using F = ma, then a = G mi/r2, where r = distance between CM's.
Also look at what mezarashi and dx have written.
In an equation, pay attention to units, e.g. (1 - 2d) would only be valid if 1 has dimensions of length, assuming d is some distance (length).
Also in these types of problems, be aware of the diffence between position and displacement (distance). Displacement (Distance) = difference detween two positions.
Well, I gave the problem to my physics teacher.
He solved it by considering the kinetic energy at the start and end of the system.
It gave a value of about 37 hours.
I tried it by assuming the rate of change of acceleration was a constant, which gave an alright approximation (24.05 hrs), but that seems to be a bad assumption to make in light of the other solution.
Problems involving changing forces and changing acceleration can be solved! It's nothing mysterious, but the mathematics is more 'involved'. Take for example the case of the spring. You attach a mass m to a spring which experiences a constantly changing force F = -kx which is a function of position, the same way your gravitational scenario was. Using Newton's second law, can you find how long it will take for the mass to go up and come back down to its same position again (asking for a time, similar to your situation)?
Solving this, you will find out how the period formula [tex]T = 2\pi \sqrt{\frac{m}{k}}[/tex] came about.
Related to Gravitation: Looks easy at first
1. What is gravitation?
Gravitation is a force of attraction between objects with mass. It is responsible for the motion of planets, stars, and other celestial bodies in the universe.
2. What is the formula for calculating gravitational force?
The formula for calculating gravitational force between two objects is F = (G * m1 * m2) / d^2, where G is the gravitational constant, m1 and m2 are the masses of the two objects, and d is the distance between them.
3. How does the strength of gravity change with distance?
The strength of gravity decreases with distance. This is known as the inverse-square law, which means that as the distance between two objects doubles, the gravitational force between them decreases by a factor of four.
4. What is the difference between mass and weight in relation to gravitation?
Mass is a measure of the amount of matter an object contains, while weight is a measure of the force of gravity acting on an object. Mass is constant regardless of location, while weight can change depending on the strength of gravity.
5. How does Einstein's theory of general relativity relate to gravitation?
Einstein's theory of general relativity explains gravitation as the curvature of spacetime caused by the presence of mass. This theory is used to explain the motion of large objects, such as planets, in the universe.
9K
