205.8.4.30. Int 24/(144x^2+1)^2 dx
  • MHB
  • Thread starter karush
  • Tags
    Dx
In summary, $I_30=2\int \frac{12}{((12x)^2+1)^2}\,dx$ where $\sec^2(\theta)=12\tan\left({\theta}\right)+\dfrac{12x}{144x^2+1}+C$
karush
MHB
3,269
206.8.4.30. Int 24/(144x^2+1)^2 dx
206.8.4.30
$\displaystyle
I_30=\int \frac{24}{(144x^2+1)^2}=
\arctan\left(12x\right)+\dfrac{12x}{144x^2+1}+C$
So $x=12\tan\left({u}\right) \therefore du=12\sec^2 (u)du$
By the answer assume a trig subst.
Didn't want to try reduction formula:
Continue or is there better?
I would first write the integral as:
\(\displaystyle I_{30}=2\int\frac{12}{((12x)^2+1)^2}\,dx\)
Now, let:
\(\displaystyle 12x=\tan(\theta)\implies 12\,dx=\sec^2(\theta)\,d\theta\)
and apply the Pythagorean identity:
\(\displaystyle \tan^2(\alpha)+1=\sec^2(\alpha)\)
and you now have:
\(\displaystyle I_{30}=2\int\frac{\sec^2(\theta)}{\sec^4(\theta)}\,d\theta=2\int\cos^2(\theta)\,d\theta=\int \cos(2\theta)+1\,d\theta\)
Now all that's left is to complete the integration and back-substitute for $\theta$. :)
After fixing typos and plagiarizing..
$$\displaystyle
I_{30}=\int \frac{24}{(144x^2+1)^2} \, dx =
\arctan\left(12x\right)+\dfrac{12x}{144x^2+1}+C$$
rewrte
$$\displaystyle
I_{30}=2\int \frac{12}{((12x)^2+1)^2} \, dx $$
trig subst
$$12x=\tan\left({\theta}\right)
\therefore 12dx=\sec^2 (\theta)d\theta$$
$$\displaystyle I_{30}=2\int\frac{\sec^2(\theta)}{\sec^4(\theta)}\,d\theta=2\int\cos^2(\theta)\,d\theta=\int \cos(2\theta)+1\,d\theta$$
back subst $\theta=\arctan{(12x)}$
How do you back subst this ??
Isn't it $\cos\left({2\theta}\right)-1$
A double-angle identity for cosine is:
\(\displaystyle \cos(2\alpha)=2\cos^2(\alpha)-1\)
Now, when you integrate, you will get:
\(\displaystyle I_{30}=\frac{1}{2}\sin(2\theta)+\theta+C\)
Apply the double-angle identity for sine, and various other identities:
\(\displaystyle I_{30}=\sin(\theta)\cos(\theta)+\theta+C=\tan(\theta)\cos^2(\theta)+\theta+C=\frac{\tan(\theta)}{\sec^2(\theta)}+\theta+C=\frac{\tan(\theta)}{\tan^2(\theta)+1}+\theta+C\)
Now, back-substitute for $\theta$:
\(\displaystyle I_{30}=\frac{12x}{(12x)^2+1}+\arctan(12x)+C\)
$$\displaystyle
rewrte
$$\displaystyle
trig subst
=\tan(\theta)\cos^2(\theta)+\theta+C \\
=\frac{\tan(\theta)}{\tan^2(\theta)+1}+\theta+C$$
$$\displaystyle I_{30}=\frac{12x}{(12x)^2+1}+\arctan(12x)+C$$
Related to 205.8.4.30. Int 24/(144x^2+1)^2 dx
1. What is the significance of "205.8.4.30. Int 24/(144x^2+1)^2 dx" in scientific research?
The expression "205.8.4.30. Int 24/(144x^2+1)^2 dx" is a mathematical integral that is commonly used in various fields of science, such as physics, chemistry, and engineering. It represents a calculation of the area under a curve, which is a fundamental concept in many scientific studies.
2. How is "205.8.4.30. Int 24/(144x^2+1)^2 dx" derived?
The expression "205.8.4.30. Int 24/(144x^2+1)^2 dx" is derived from the general form of the integral of a rational function, where the numerator is a constant and the denominator is a polynomial. In this case, the specific values of 205.8, 4, and 30 are used as parameters in the equation.
3. What are the applications of "205.8.4.30. Int 24/(144x^2+1)^2 dx" in scientific studies?
The integral "205.8.4.30. Int 24/(144x^2+1)^2 dx" has various applications in scientific research, such as in the calculation of electric fields, gravitational forces, and fluid dynamics. It is also used in the determination of probabilities and in the analysis of data from experiments.
4. Can "205.8.4.30. Int 24/(144x^2+1)^2 dx" be solved analytically or numerically?
It depends on the specific values of the parameters and the function inside the integral. In some cases, "205.8.4.30. Int 24/(144x^2+1)^2 dx" can be solved analytically using techniques such as substitution or integration by parts. However, if an analytical solution is not possible, numerical methods can be used to approximate the value of the integral.
5. Are there any limitations or assumptions associated with "205.8.4.30. Int 24/(144x^2+1)^2 dx"?
As with any mathematical expression, there may be limitations or assumptions associated with "205.8.4.30. Int 24/(144x^2+1)^2 dx" depending on its context of use. For example, the function inside the integral may need to be continuous or have certain properties for the integral to be valid. Additionally, the values of the parameters may also have limitations or assumptions in certain applications.
  • Calculus
  • Calculus
  • Calculus
  • Calculus
  • Calculus
