242.8.7.64 int (x^4+1)/(x^3+9x) dx
  • MHB
  • Thread starter karush
  • Tags
    Dx
And finally:In summary, $I_{64}=\frac{\ln\left|x\right|}{9}-\frac{41\ln\left(x^2+9\right)}{9}+\frac{x^2}{2}=\frac{1}{9}\int\frac{1}{x}\, dx-\frac{82}{9}\int\frac{x}{x^2+9}\, dx+\int x\, dx$.
karush
MHB
3,269
$\text{206.8.7.64}$
$\text{Given and evaluation}$
$$\displaystyle
I_{64}=\int \frac{x^4+1}{x^3+9x} \, dx
=\dfrac{\ln\left(\left|x\right|\right)}{9}-\dfrac{41\ln\left(x^2+9\right)}{9}+\dfrac{x^2}{2}$$
$\text{expand (via TI)}$
$$I_{64}= \frac{1}{9}\int\frac{1 }{x} \, dx
-\frac{82}{9}\int\frac{x}{(x^2+9)}\, dx
+\int x \, dx $$
$\text{OK I can see how the integral was evaluted }$
$\text{just don't see how the expansion was done?}$
I would write:
\(\displaystyle \frac{x^4+1}{x^3+9x}=\frac{x^4+9x^2+1-9x^2}{x^3+9x}=\frac{x(x^3+9x)+1-9x^2}{x^3+9x}=x-\frac{9x^2-1}{x^3+9x}\)
Now, using partial fractions:
\(\displaystyle \frac{9x^2-1}{x^3+9x}=\frac{A}{x}+\frac{Bx+C}{x^2+9}\)
\(\displaystyle 9x^2-1=A(x^2+9)+(Bx+C)x=(A+B)x^2+Cx+9A\)
Equating coefficients, we obtain:
\(\displaystyle A+B=9\)
\(\displaystyle C=0\)
\(\displaystyle 9A=-1\implies A=-\frac{1}{9}\implies B=\frac{82}{9}\)
Hence:
\(\displaystyle \frac{9x^2-1}{x^3+9x}=-\frac{1}{9x}+\frac{82x}{9(x^2+9)}\)
Putting it all together:
\(\displaystyle \frac{x^4+1}{x^3+9x}=x+\frac{1}{9x}-\frac{82x}{9(x^2+9)}\)
Related to 242.8.7.64 int (x^4+1)/(x^3+9x) dx
What is the significance of the numbers in "242.8.7.64 int (x^4+1)/(x^3+9x) dx"?
The numbers in this expression are not significant in themselves, but rather represent the coefficients and variables used in a mathematical integration problem.
What is the meaning of "int" in this expression?
"Int" is short for integration, which is a mathematical process used to find the area under a curve.
What is the purpose of "(x^4+1)/(x^3+9x)" in this expression?
This fraction represents the function being integrated, which is a common practice in integration problems.
What does "dx" signify in this expression?
"dx" represents the variable of integration, which is used to indicate which variable is being integrated in the given function.
How would you solve this integration problem?
To solve this problem, you would use the appropriate integration techniques, such as substitution or integration by parts, to simplify the expression and find the antiderivative. Then, you would solve for any given limits of integration to find the final numerical answer.
  • Calculus
  • Calculus
  • Calculus
  • Calculus
