311.1.5.19 parametric equation of the line through a parallel to b.
In summary, the parametric equation of the line through point a=(-2,0) and parallel to b=(-5,3) is x=a+tb, where t is a real number and the corresponding values of x and y can be found by plugging in different values for t. This method is also known as the point-slope formula.
karush
MHB
3,269
$\tiny{311.1.5.19}$
find the parametric equation of the line through a parallel to b.
$a=\left[\begin{array}{rr}
-2\\0
\end{array}\right],
\, b=\left[\begin{array}{rr}
-5\\3
\end{array}\right]$
ok I know this like a line from 0,0 to -5,3 and $m=dfrac{-5}{3}$
so we could get line eq with point slope formula
but this is be done by parametric eq
this was book section I tried to follow..
anyway...
$x=a+tb=
-2\\0
\end{array}\right]+t
-5\\3
\end{array}\right]$
maybe:cool:
Didn't you check this yourself?
When t= 0, \(\displaystyle \begin{bmatrix}-2 \\0 \end{bmatrix}+ 0\begin{bmatrix}-5 \\ 3\end{bmatrix}=\begin{bmatrix}-2 \\0 \end{bmatrix}\) so it goes through the right point, a= (-2, 0).
When t= 1, \(\displaystyle \begin{bmatrix}-2 \\0 \end{bmatrix}+ 1\begin{bmatrix}-5 \\ 3\end{bmatrix}=\begin{bmatrix}-7 \\3 \end{bmatrix}\) so it also goes through (-7, 3).
And the vector from (-2, 0) to (-7, 3) is \(\displaystyle \begin{bmatrix}-7- (-2) \\ 3- 0\end{bmatrix}=\begin{bmatrix}-5 \\ 3 \end{bmatrix}\) as desired.
Related to 311.1.5.19 parametric equation of the line through a parallel to b.
1. What is a parametric equation?
A parametric equation is a set of equations that express the coordinates of a point in terms of one or more parameters. In other words, it is a way of representing a relationship between variables in a mathematical form.
2. How is the parametric equation of a line through a parallel to b determined?
The parametric equation of a line through a parallel to b is determined by using the slope-intercept form of a line, y = mx + b. The slope (m) and y-intercept (b) of the line parallel to b are used to create the parametric equations for x and y.
3. What is the purpose of using a parametric equation for a line?
A parametric equation allows us to easily represent and manipulate the relationship between variables in a line. It also allows us to easily find specific points on the line, such as the x- and y-intercepts, without having to graph the entire line.
4. Can a parametric equation of a line through a parallel to b be used in any situation?
Yes, a parametric equation can be used in any situation where a line is parallel to another line. It is a general form that can be applied to any set of parallel lines.
5. How does the parametric equation of a line through a parallel to b differ from the standard equation of a line?
The parametric equation of a line through a parallel to b includes parameters (such as t or s) that represent the relationship between the variables x and y. In contrast, the standard equation of a line is in the form y = mx + b and does not include parameters.
  • Linear and Abstract Algebra
