A photo of the computer screen -- what causes vertical lines
In summary, vertical lines on a computer screen can be caused by several factors such as a faulty graphics card, loose or damaged cables, or a failing LCD panel. These lines can also be a result of outdated or corrupted display drivers, or a hardware issue with the monitor itself. To troubleshoot and fix this issue, it is important to identify the specific cause and then take appropriate steps such as updating drivers, checking connections, or replacing hardware components.
Vrbic
407
https://www.dropbox.com/s/be52pax3jezv3cb/IMG_20170128_170143.jpg?dl=0 https://www.dropbox.com/s/be52pax3jezv3cb/IMG_20170128_170143.jpg?dl=0 I have question what causes vertical lines on the photo of the screen of my laptop?
But I would like to find out it alone. Could someone lead me?
I know the screen works with some frequency and it "blinks". Something around 75Hz I guess. But why it makes such vertical lines...I don't have any idea. Maybe problem is I don't know how works camera in my phone. Please advise.
Thank you for your posts.
Picture is here: https://www.dropbox.com/s/be52pax3jezv3cb/IMG_20170128_170143.jpg?dl=0
Computer science news on Phys.org
Interesting question. Lines are horizontal when my phone is horizontal--vertical lines when phone is vertical. Investigate how your laptop updates its screen image AND investigate how your camera digitally processes an image.
Does it happen only with laptop ? did you try that on TV or other screen ?
Vrbic said:
Investigation in progress :)
Summary:
It is very interesting. Asus and LCD TV don't have any lines. And old tube television in portrait mode produces oblique lines :-D Landscape photo of old TV produces horizontal lines...don't understand anything :-)
Any idea, why sometimes there are lines and sometime not? What can be different in these screens?
Try changing the refresh rate of the monitor.
Then click the pictures.
Buffu said:
Did you try clicking pictures with another camera ?
No doesn't matter. Do you have any idea what is happaning with my camera?
The effect is related to the camera. I tested a Note 4 camera with a CRT monitor. The camera is sensitive to refresh rate and brightness. At 60 hz or 120 hz, at normal brightness I don't see lines, but if I dim the brightness somewhat, I see thick moving darker lines, but if I continue to dim below some threshold, I don't see lines. At 70hz or 85hz, there are always lines present. I see moving darker lines that change speed and generally get thicker as the image on the CRT monitor gets dimmer. At normal brightness levels, the lines are thin similar to the images posted earlier. On a very dim setting the darker lines are so thick that the effect is like thin brighter lines. At 70hz / 85 hz, normal brightness: if the camera is horizontal (landscape) I see horizontal lines; if the camera is vertical (portrait), I see angled lines; if the camera is held about 30 degrees counter-clockwise from vertical, I see vertical lines on the camera.
The Note 4 uses a IMX240 EmorRS CMOS sensor.
http://en.wikipedia.org/wiki/Exmor#List_of_Exmor_RS_sensors
The CMOS sensors have an effective scan rate, which causes the artifacts you see with moving objects, or objects like a CRT monitor where the phosphors fade until refreshed by the sweeping beam. This website includes a video animation of the effective scanning across then down rows, comparing CMOS versus CCD sensors.
http://www.popphoto.com/clever-animated-videos-explain-how-cmos-and-ccd-camera-sensors-work
More info:
http://electronics.howstuffworks.com/cameras-photography/digital/question362.htm
http://www.teledynedalsa.com/imaging/knowledge-center/appnotes/ccd-vs-cmos
Likes Buffu, Vrbic and jim mcnamara
More info:
Great. Thank you, I will study your links :)
I think you are getting this kind of effect from the refresh rate of the screen.
My guess is that the screen changes in brightness during each refresh for a moment, and the scan-rate of the camera is catching that.
Could you be more specific please? What is name of this effect. Honestly, I'm not sure what is exactly happening at your picture. Could you send some link with description of this effect or something like that?
The effect is seen in many different systems. A good example would be an old fashioned (mechanical) strobe tuner for a guitar.
See
The "lines" you see is because the two systems (your laptop and your camera) are "out of tune" (not synchronized).
Likes Vrbic
Likes Vrbic
Thank you all! I hope I understand ;-)
Related to A photo of the computer screen -- what causes vertical lines
1. What causes vertical lines on a computer screen?
Vertical lines on a computer screen can be caused by a variety of factors, including hardware issues, software glitches, or even physical damage to the screen.
2. How can I fix vertical lines on my computer screen?
The best way to fix vertical lines on a computer screen will depend on the underlying cause. Some common solutions include updating graphics drivers, adjusting display settings, or repairing or replacing damaged hardware.
3. Can low-quality cables or adapters cause vertical lines on a computer screen?
Yes, low-quality cables or adapters can cause vertical lines on a computer screen. It is important to use high-quality cables and adapters that are compatible with your device to avoid any potential issues.
4. Are vertical lines on a computer screen a sign of a serious problem?
In most cases, vertical lines on a computer screen are not a sign of a serious problem and can be fixed with simple troubleshooting steps. However, if the lines are persistent and accompanied by other issues, it could indicate a more serious hardware problem.
5. How can I prevent vertical lines from appearing on my computer screen?
To prevent vertical lines from appearing on your computer screen, it is important to keep your device and its components clean and well-maintained. Additionally, avoid using incompatible or low-quality cables or adapters and make sure to update your software regularly to avoid any potential glitches.
  • Computing and Technology
  • Mechanics
