A very puzzling problem
  • Thread starter BudsPro+
In summary, when Material X, at a higher temperature than Mercury, is brought into contact with Mercury, heat energy is transferred from Material X to Mercury until they reach thermal equilibrium. The final temperature, θN, will be the same regardless of the heat capacities of the two substances. This is because the amount of heat needed to change the temperature of the thermometer is too small to make a noticeable difference in the final temperature of the substance in the beaker. Therefore, the temperature reading given by a liquid-in-glass thermometer may not be the exact temperature of the body being measured, but it will be the temperature of the body at thermal equilibrium.
BudsPro+
Material X,which is at a higher temperature, and Mercury are brought into contact for some time to allow heat transfer to take place.
CX : Heat capacity of Material X
θX : Temperature of Material X (At first)
CM : Heat capacity of Mercury
θM : Temperature of Mercury (At first)
θX is greater than θM. [ θX > θM ]
So heat energy is transferred from Material X to Mercury.
θN : Final temperature of both Material X and Mercury after heat transfer is complete. [ At thermal equilibrium. ]
Assumption: There is no heat loss to surroundings.
Heat gained by mercury = Heat lost by Material X
δQM = - δQX
CMδθM = - CXδθX
CMN – θM) = - CXN – θX)
θNCM – θMCM = θXCX - θNCX
θNCM + θNCX = θXCX + θMCM
θN = [ θXCX + θMCM ] / [ CX + CM ]
Therefore if we take X to be of different materials or even of different masses, the final temperature of the mercury , θN , should vary because the heat capacity of X , CX , changes. However this is not the case as if, for example, we place 2 mercury-in-glass thermometers in Ethanol at 50oC and Water at 50oC, both thermometers show a reading of 50oC.
Note: The Ethanol and the Water have different heat capacities.
I would like to see what you think about this problem. I really cannot understand, according to the above formula, why the thermometers show the same reading for the Ethanol and the Water. Any 2 other substances could have been taken but Ethanol and Water are simpler. Could someone please give me a good explanation about this?
  • Therm.doc
Yes, the final temperature will depend on the mass and heat capacity of the substance.
I don't understand the point you are trying to make. Can you restate it?
Regardless of the heat capacities of the two substances, sooner or later they will reach thermal equilibrium which means they have the same temperature. That final will be different for different substances, of course.
what I mean is that if for example, we take mercury(20 degrees celcius, in fact room temperature) & in contact with water(50 degreees celcius) and on the other side we take the same mercury at room temperature but in contact with Ethanol at 50 degrees celcius, the final temperature reached in the 2 cases will be different. So why do the 2 thermometers(which contain mercury at 20 degrees celsius), placed in separate beakers of Water at 50 degrees and Ethanol at 50 degrees, show the same reading of 50 degrees celcius. The reading should have been different. Don't you think so?
Ah... now I see what you're saying. Technically, you are correct. But assume that the amount of mercury is small enough that the amount of heat needed to increase the thermometer's temperature is too small to make a measurable difference in the final temperature of the substance in the beaker.
Yeahh thx. I have tried it and it works for small masses of mercury though there is still a little difference in the reading ( of about 0.5 degrees celcius). So would you agree if I say that the temperature reading given by a liquid-in-glass thermometer is not the true temperature of the body being measured ?
Once they have reached thermal equilibrium, the measured temperature will be the 'true' temperature of the body. But it won't necessarily be the temperature of the body before the thermometer was introduced.
Related to A very puzzling problem
1. What is the nature of the problem?
The problem is a puzzling one, meaning that it is difficult to understand or solve. It may involve complex systems or phenomena that are not easily explained.
2. How did the problem arise?
The exact cause of the problem is not yet known. It may have developed gradually over time or it could be the result of a sudden event or change in the environment.
3. What are the potential implications of the problem?
The problem could have wide-ranging consequences, depending on its severity and how it is addressed. It could impact human health, the environment, or have economic implications.
4. What research has been done on the problem?
Scientists have been studying the problem extensively in order to better understand its causes and potential solutions. This may involve conducting experiments, collecting data, and analyzing existing research.
5. What steps are being taken to solve the problem?
There are ongoing efforts to address the problem, which may include implementing new policies, developing technologies, or conducting further research. However, finding a solution may take time and collaboration among scientists and other experts.
11K
