Addition of alkali before extraction
In summary, the question is about the order of adding alkali in the preparation of p-Toluidine. The reason for adding alkali before extraction is to saturate the solution and allow for the formation of two layers when ether is added. The pH of the crude material is acidic, but Toluidine is an aromatic base which would not be soluble in ether or hexane in acidic conditions.
Taryn
63
This is just a general question that I hope someone can answer.
Why do we add alkali before extraction rather than afterwards?
This is in the experiment I recently did, which was the preparation of p-Toluidine?
This was my main thought... that it helps to saturate the solution so that when ether is added the two layers form?
Any help on this question would be really helpful, just having a little bit of trouble finding something on the net.
Chemistry news on Phys.org
I assume that the pH of the crude material was acidic? Toluidine is an aromatic base. What will happen at acidic pH to this? In this form (acidic solution) do you think that it would be soluble in ether or hexane?
Adding alkali before extraction is a common practice in organic chemistry. This is because alkali, such as sodium hydroxide or potassium hydroxide, helps to increase the pH of the solution. This change in pH can have several benefits for the extraction process.
Firstly, the increase in pH can help to deprotonate acidic functional groups present in the solution. This makes them more soluble in the aqueous phase, making it easier to separate them from the organic phase during extraction.
Secondly, the addition of alkali can also help to form salts with acidic compounds. These salts are more polar and water-soluble, making them easier to extract into the aqueous phase.
In the specific case of preparing p-Toluidine, adding alkali before extraction can help to convert the amine functional group into its conjugate base form. This form is more polar and can be easily extracted into the aqueous phase.
Additionally, as you mentioned, adding alkali can also help to saturate the solution and create a clear separation between the organic and aqueous layers. This is important for a successful extraction.
Overall, adding alkali before extraction can improve the efficiency and effectiveness of the extraction process, making it a common practice in organic chemistry experiments.
Related to Addition of alkali before extraction
1. What is the purpose of adding alkali before extraction?
The addition of alkali before extraction is done to increase the solubility of organic compounds in the aqueous phase. This helps in separating the organic compounds from the mixture more efficiently.
2. How does alkali affect the extraction process?
Alkali increases the pH of the aqueous phase, making it more basic. This leads to the deprotonation of the acidic functional groups in the organic compounds, making them more water-soluble and easier to extract.
3. Which type of alkali is commonly used in extraction?
Sodium hydroxide (NaOH) or sodium bicarbonate (NaHCO3) are commonly used as alkali in extraction. They are strong bases and can effectively increase the pH of the aqueous phase.
4. How much alkali should be added before extraction?
The amount of alkali to be added depends on the acidity of the organic compounds in the mixture. A small amount of alkali is typically added at a time and the pH is checked using a pH indicator. The goal is to reach a pH where the organic compounds are soluble in water but not completely deprotonated.
5. Can alkali be used in all types of extractions?
No, alkali is only used in extractions where the organic compounds are acidic and need to be deprotonated. In cases where the organic compounds are basic, an acid is used instead to protonate them and make them more water-soluble.
  • Quantum Interpretations and Foundations
9K
  • New Member Introductions
  • Art, Music, History, and Linguistics
