Aircraft Simulation for beginners
In summary: Moment of inertia can be approximated with the sum written above. It is the product of a mass's weight and the distance from the center of mass to that mass.
eaglestrike
Hello everyone
For the past 2 years I have slowly and agonisingly tried to make a flight simulator in http://www.blender.org" . I've gotten as far as this (regarding physics):
- got the Lift and Drag calculations
- got the thrust calculations
- got some REALLY basic roll calculations.
It is the the steering physics and flight dynamics I need help with now. I read that ailerons cause roll by deflecting air in certain directions. This causes the net lift to change and makes the aircraft rotate around its longitudinal axis. So I've come up with a whole lot of calculations that calculate the lift on different parts of the wing and calculate the difference in lift, and then use that to create torque. This works. But as I know, this isn't the only variable in aircraft roll... I know inertia is another one, but not much else (http://en.wikipedia.org/wiki/Flight_dynamics). What I need is some very simple but applicable roll calculations that can be used. I'm assuming at the moment that the same calculations can be adapted to work for the elevators and rudder. And as a note I would like to say that I am an eleventh grader with some common sense (hopefully!).
My current resources are:
http://www.auf.asn.au/groundschool/umodule4.html
http://www.av8n.com/how/#contents
Thanks.
Sorry to be of relatively little help, but here is a suggestion. You'll need the mass of the object and its moment of inertia. Moment of inertia, I, can be approximated by [tex]I = sum(m_i * r_i ^2, i, 1, N) [/tex] .
This only applies to rigid bodies, and even then, it's an approximation if the shape of the object is complex enough.
I is analogous to mass as rotational kinematics is to linear kinematics. Perhaps it would be accurate enough to approximate I with the sum written above. Chop the plane up into areas of known mass and center of mass. Then calculate the distance to the center of mass of the plane.
I was going to add that. Can you please explain the equation (as what mi is) ... also, will I have to integrate the different centres of the aircraft? as will the centre of lift have to be different altogether than the centre of gravity, or can I balance it with trig??
[tex]m_i[/tex]
The subscript i is for index. That means you sum up the each section's mass times distance from the plane's center of mass squared for as many sections of the plane as you want. You then repeat this for each section and add together all the results. You must do the whole plane though, and taking a very small number of sections can be quite inaccurate.
Hello, thank you for sharing your progress on creating a flight simulator using Blender. It's great to see people taking an interest in aircraft simulation and trying to understand the physics behind it. I would like to provide some feedback and suggestions for your project.
Firstly, it's important to note that creating a realistic flight simulator involves a complex combination of aerodynamics, physics, and computer programming. It's not an easy task, and it's commendable that you have made progress in understanding the lift, drag, and thrust calculations.
However, as you have mentioned, there are many other factors that contribute to aircraft roll, such as inertia, weight distribution, and control inputs. To create a more accurate simulation, you will need to incorporate these variables into your calculations. I would recommend studying the principles of flight dynamics and aerodynamics in more depth to gain a better understanding of these concepts.
Additionally, it might be helpful to consult with experts in the field of aircraft simulation or seek guidance from online resources and forums dedicated to flight simulation. These resources can provide you with more specific and applicable calculations for the steering physics and flight dynamics of an aircraft.
As an eleventh grader, you have a great opportunity to learn and explore the world of aircraft simulation. Keep up the good work and continue to seek out knowledge and resources to improve your project. Best of luck!
Related to Aircraft Simulation for beginners
1. What is aircraft simulation?
Aircraft simulation is the process of creating a virtual environment that mimics the behavior and characteristics of a real aircraft. It involves using computer software and hardware to simulate flight conditions and the different systems and controls of an aircraft.
2. Why is aircraft simulation important for beginners?
Aircraft simulation allows beginners to practice and familiarize themselves with the controls and procedures of flying without the risks and costs associated with real flight. It also helps in developing skills and knowledge that are necessary for safe and efficient flight.
3. What are the benefits of using aircraft simulation for beginners?
Using aircraft simulation for beginners has several benefits, such as providing a safe and controlled environment for learning, allowing for repetitive practice and skill development, and helping to build confidence and decision-making abilities before flying a real aircraft.
4. What are the different types of aircraft simulation available for beginners?
There are various types of aircraft simulation available for beginners, such as desktop simulators, flight training devices, and full-flight simulators. These differ in terms of their level of realism and the type of aircraft they simulate.
5. Is aircraft simulation for beginners a substitute for real flight training?
No, aircraft simulation for beginners is not a substitute for real flight training. While it can provide a valuable learning experience, it cannot replicate the physical and psychological challenges of flying a real aircraft. It should be used as a supplement to, not a replacement for, real flight training.
  • Classical Physics
  • Other Physics Topics
21K
14K
  • Mechanical Engineering
