Altering the shape of a flasks walls
  • Thread starter aspodkfpo
  • Tags
    Shape
In summary: Overall the force on the base is unchanged. The depth also remains unchanged, so the force per unit area is unchanged too.
aspodkfpo
148
13 b) i) https://www.asi.edu.au/wp-content/uploads/2015/03/2011-Physics-exam-solutions.pdf
On page 13 of pdf
n/a
" For the conical vessel, we note that pressure is a local force, and so must be independent of conditions far away. Hence altering the shape of the flasks walls while keeping local conditions constant will not change the pressure locally, and so F = (ρgh+Pa)πr2 also holds for this flask "
Can someone expand on this and the theory behind it? My intuition is lower mass, lower force, but this is countered in the next part of this problem.
aspodkfpo said:
Homework Statement:: 13 b) i) https://www.asi.edu.au/wp-content/uploads/2015/03/2011-Physics-exam-solutions.pdf
On page 13 of pdf
Relevant Equations:: n/a
Consider first a rectangular tank.
If you increase the weight by increasing the width then the force per unit area stays the same. If you increase the depth instead then the force per unit area increases in proportion.
Now let the tank have sides that lean outwards. Some of the weight is taken by those sides, and it turns out that the force per unit area at the base still only depends on depth.
If we make the sides lean in, as in the example, the fluid exerts pressure on those sides, and the reaction force has a downward component. This makes up for the fact that there is less water near the top.
Related to Altering the shape of a flasks walls
1. How can altering the shape of a flask's walls affect its function?
Changing the shape of a flask's walls can impact its function in several ways. For example, a wider flask with a larger surface area may allow for faster heat transfer, while a narrower flask with a smaller surface area may be more suitable for mixing or stirring reactions.
2. What are some common shapes used for flasks and their purposes?
Some common shapes used for flasks include round-bottom flasks, Erlenmeyer flasks, and flat-bottom flasks. Round-bottom flasks are often used for heating and distillation, while Erlenmeyer flasks are more suitable for mixing and stirring reactions. Flat-bottom flasks are commonly used for storage and titrations.
3. Can altering the shape of a flask's walls affect the accuracy of measurements?
Yes, changing the shape of a flask's walls can affect the accuracy of measurements. For example, a conical flask may have a larger meniscus, making it more difficult to accurately read the volume. It is important to consider the shape of the flask when making precise measurements.
4. How does the material of the flask's walls impact its shape?
The material of a flask's walls can impact its shape in several ways. For instance, glass flasks can withstand high temperatures and are often used for heating, while plastic flasks may not be suitable for heating but can be more flexible for certain applications. The material can also affect the thickness and overall shape of the flask.
5. Are there any safety concerns when altering the shape of a flask's walls?
Yes, there are some safety concerns to consider when altering the shape of a flask's walls. For instance, if the walls are made thinner, the flask may be more prone to breakage under high temperatures or pressure. It is important to carefully consider the material and intended use of the flask when making any alterations to its shape.
15K
  • Materials and Chemical Engineering
  • STEM Academic Advising
  • Quantum Interpretations and Foundations
