Application of Gauss's Law to Charged Insulators
In summary, a cylindrical shell with a radius of 7.00 cm and length of 240 cm has a uniformly distributed charge on its curved surface. The electric field at a point 19.0 cm from the axis is 36.0 kN/C. Using approximate relationships, the net charge on the shell can be found, as well as the electric field at a point 4.00 cm from the axis. However, using the equation Flux = Q/e = E*2pi*r*l may not work because it may lack enough independent equations.
EngineerHead
A cylindrical shell of radius 7.00 cm and length 240 cm has its charge uniformly distributed on its curved surface. The magnitude of the electric field at a point 19.0 cm ra- dially outward from its axis (measured from the midpoint of the shell) is 36.0 kN/C. Use approximate relationships to find (a) the net charge on the shell and (b) the electric field at a point 4.00 cm from the axis, measured radially outward from the midpoint of the shell.
Could someone please explain to me why this does not work:
Where I am thinking of Q in terms of an average AREA charge density * the area, and not a line density * a length.
-- Is it because it lacks enough independent equations?
Why do you think that doesn't work?
Because I am currently getting a different answer than that given by the book - which is:
+913 nC
Okay it works... I've been using an incorrect value for e when solving from k - apologies.
There are a few reasons why this approach may not work:
1. Gauss's Law applies to closed surfaces, not just curved surfaces. In this problem, we are only given information about the electric field at a single point, so it is not possible to use Gauss's Law to directly calculate the net charge on the shell.
2. The formula you are using, Flux = Q/e = E*2pi*r*l, assumes that the electric field is constant over the entire surface. However, in this problem, the electric field is only given at a single point. This formula would only be applicable if the electric field was constant over the entire surface, which is not the case here.
3. The formula you are using, Flux = Q/e = E*2pi*r*l, also assumes that the electric field is perpendicular to the surface at every point. In this problem, we are given the magnitude of the electric field at a point that is not necessarily perpendicular to the surface. In order to use Gauss's Law, we would need to know the direction of the electric field at every point on the surface.
Overall, in order to use Gauss's Law to solve this problem, we would need more information about the electric field on the surface, such as its direction and how it varies over the surface. Without this information, it is not possible to use Gauss's Law to directly calculate the net charge on the shell.
Related to Application of Gauss's Law to Charged Insulators
1. How does Gauss's Law apply to charged insulators?
Gauss's Law is a fundamental principle in electromagnetism that relates the electric flux through a closed surface to the charge enclosed by that surface. This law applies to all types of materials, including insulators. It states that the net electric flux through a closed surface is equal to the total charge enclosed by that surface divided by the permittivity of the material.
2. Can Gauss's Law be used to determine the electric field inside a charged insulator?
Yes, Gauss's Law can be used to determine the electric field inside a charged insulator. By choosing a closed surface that encloses the insulator, the electric flux through that surface can be calculated. Then, by applying Gauss's Law, the electric field inside the insulator can be determined.
3. Are there any limitations to using Gauss's Law on charged insulators?
Yes, there are some limitations to using Gauss's Law on charged insulators. One limitation is that the surface chosen must be a closed surface that encloses the insulator and does not intersect any other charges. Additionally, Gauss's Law assumes that the insulator is a continuous material and does not account for any discontinuities or imperfections in the material.
4. How does the charge distribution of an insulator affect the application of Gauss's Law?
The charge distribution of an insulator has a significant impact on the application of Gauss's Law. In order for the law to accurately predict the electric field inside the insulator, the charge distribution must be known. This can be challenging for insulators with complex or irregular shapes, as the charge distribution may not be uniform.
5. What are some real-world applications of using Gauss's Law on charged insulators?
Gauss's Law has many practical applications in engineering and physics, including the design of electric field shielding for sensitive electronic devices, the calculation of capacitance in electronic circuits, and the analysis of dielectric materials in capacitors and insulators. It is also used in the study of atmospheric electricity, such as lightning strikes and the formation of thunderstorms.
