- #36
PeterDonis
Mentor
- 45,825
- 22,744
@JD23 where are all these diagrams in your posts coming from?
PF is not for discussing or pursuing personal research.JD23 said:I would gladly discuss and generally am searching for collaboration in these topics, especially access to ring laser to test
Obviously such a setup would indeed split the laser beam, so I don't know what to tell you.JD23 said:Exactly - that's my point: if in both perspectives symmetric ring laser would produce the same amount of photons (and there are no other sources), the fact that they are the same system requires that "photons go straight through beamsplitter" - cannot turn up/down.
I have seen such a statement in a few articles, e.g. "Faraday effect that breaks the time-reversal symmetry" in https://www.nature.com/articles/s41566-018-0127-2 so I assumed it is true ... indeed with some internal conflict I should explore as electromagnetism alone is T symmetric and there is nearly no way to get out of EM here (hyperfine interactions with nucleus?)Vanadium 50 said:No it does not. (A common error is to ignore the effect of T on the magnetic field)
In electronic and hydrodynamic analogs the statistics of split is changed by negative pressure - as equations are nearly the same, why it cannot be still true for split of light analog by negative radiation pressure?Drakkith said:Obviously such a setup would indeed split the laser beam, so I don't know what to tell you.
As has been said already, light doesn't interact with itself hardly at all. As far as the light is concerned, there is no radiation pressure at all on itself. This is unlike physical flows like water or electric current where the flow is highly interacting with itself.JD23 said:In electronic and hydrodynamic analogs the statistics of split is changed by negative pressure - as equations are nearly the same, why it cannot be still true for split of light analog by negative radiation pressure?
CPT theorem suggests it should work, it would be great to test it experimentally ...
Irrelevant. Light does not interact with itself enough either way you look at it.JD23 said:But thinking about EM waves not individual photons
Again, irrelevant.JD23 said:the equations are practically the same as for superfluids
That depends entirely on what you mean by 'very different'. And on how deep you look into things.JD23 said:So what about intermediate picture - microwaves in waveguides?
Would such EM wave be mathematically very different from superfluid?
No. Radiation pressure acts on matter, not on light.JD23 said:If so, could split behavior be controlled also by negative (radiation) pressure like in hydrodynamical analog?
Enough with the analogies. Either talk specifically about your optical setup, using optical terminology, or I will lock this thread. Things like 'recreation of circulation with pump' add an unnecessary step that we have to work through to get to what you're actually wanting to know.JD23 said:Pressure is effective description of hidden dynamics, e.g. <E x H>/c averaged vector for radiation - so how this dynamics differs between superfluid and electromagnetism to prevent recreation of circulation with pump?
I don't think anyone here is claiming that negative radiation pressure doesn't exist (see here). We're saying that your setup probably doesn't do what you think it does.JD23 said:I agree that negative radiation pressure feels non-intuitive, but it doesn't make it nonexistant, for what I still haven't seen meritorious counterargument.
Again, I don't see any need to invoke CPT symmetry. If you provide an optical setup, it should immediately be clear what it does. Your setups provided so far do nothing exceptional. You have a ring laser and a beam splitter that splits the beam. That's it. It's a very simple setup.JD23 said:I have shown the setting in #10 and #19 here, and we have discussed that e.g. CPT theorem suggests such setting should work similarly in all settings: electronic, hydrodynamic ... so why not for e.g. EM microwaves, photons?
By itself it might, but you have other things in the system.JD23 said:Beside EM-hydro analogy, the only argument I have is that looking from CPT symmetry perspective, symmetric ring laser should produce the same amount of photons in the opposite direction.
But that's the thing. It's not the same setting. The beam splitter is at a different angle relative to the oncoming beam of light in the second setup.JD23 said:In both perspectives this is practically the same setting, hence should work the same.
There is no negative radiation pressure in any of your setups and negative pressure appears to only be possible in certain types of materials.JD23 said:I understand that beamsplitters are made to have fixed proportions e.g. 50:50 (for e.g. laser beam carrying positive radiation pressure).
But was it tested in the presence of negative radiation pressure?
I think you've forgotten the P in CPT. A parity transform of the system would appear to solve the issues I've brought up.JD23 said:- what is wrong with the above CPT symmetry-based argument?
A great many things. Light can't stop moving, for example. It doesn't interact with itself hardly at all. It's uncharged. It's massless. It's fundamentally different from any superfluid.JD23 said:- what is the mathematical difference between EM and superfluid allowing circuit with pump for exactly one of them?
Drakkith said:By itself it might, but you have other things in the system.
Not having other photon sources, to make it more symmetric we can rotate the beamplitter 90 degrees toward us (up/down -> to/from us) - this way in both perspectives (with/without CPT) it would be practically the same situation.Drakkith said:But that's the thing. It's not the same setting. The beam splitter is at a different angle relative to the oncoming beam of light in the second setup.
Indeed for optical photons it is less intuitive, so I have suggested intermediate picture: microwaves in waveguides - which is more "pure EM" governed by nearly the same equations as superfluid - would such reduction of flow down the split by negative radiation pressure be possible for microwave setting?Drakkith said:A great many things. Light can't stop moving, for example. It doesn't interact with itself hardly at all. It's uncharged. It's massless. It's fundamentally different from any superfluid.
The only beam splitters I've seen are cube-like with the internal diagonal joining the two pieces as the reflecting surface. There is no way to orient this such that it will reflect the two beams the same way.JD23 said:Not having other photon sources, to make it more symmetric we can rotate the beamplitter 90 degrees toward us (up/down -> to/from us) - this way in both perspectives (with/without CPT) it would be practically the same situation.
No, not as far as I know.JD23 said:Indeed for optical photons it is less intuitive, so I have suggested intermediate picture: microwaves in waveguides - which is more "pure EM" governed by nearly the same equations as superfluid - would such reduction of flow down the split by negative radiation pressure be possible for microwave setting?
