Atom or weight fraction in MOX fuel
In summary, to calculate the atom or weight fraction in MOX fuel, you need to determine the total amount of UO2 and PuO2 in the mixture, calculate the total amount of plutonium, determine the enrichment of PuO2, and then use that to calculate the atom or weight fraction of oxygen in the fuel mixture. The enrichment of PuO2 can vary and will affect the final calculations.
bkoz
Hi.
I have a problem with some calculations. I have to find atom or weight fraction in MOX fuel. MOX fuel is a mixture of UO2 and PuO2. It can be mixed with a various enrichment of PuO2. The fraction of isotopes of uranium and plutonium are as here:
U234 234,041 0,00002
U235 235,044 0,002
U236 236,046 0,00001
U238 238,051 0,99797
Pu239 239,052 0,936
Pu 240 240,054 0,059
Pu 241 241,057 0,004
Pu 242 242,059 0,001
Do you have any ideas how to count this? It have to depend on a enrichment of PuO2. I have a problem with finding atom/weight fraction of oxygen in fuel.
Thank you in advance !
There is insufficient information to determine the enrichment. Basically one has two isotopic vectors for the U and Pu, but not how much Pu vs U.
The U is depleted, and 0.99797 U-238. The Pu is 0.939 Pu-239 and 0.049 Pu-240, and traces of Pu-240 and Pu-241.
One would need to fraction of U,Pu that is Pu. I would be 0.06 Pu, 0.94 U for a commercial reactor, and one could assume a stoichiometric oxide, (U,Pu)O2. A higher enrichment in Pu would be used in a fast reactor.
Hi there,
Calculating the atom or weight fraction in MOX fuel can be a bit tricky, but here are some steps that might help:
1. Determine the total amount of UO2 and PuO2 in the fuel mixture. This can be done by multiplying the mass of each isotope by its corresponding fraction and then adding them all together. For example, for UO2, it would be (234.041 x 0.00002) + (235.044 x 0.002) + (236.046 x 0.00001) + (238.051 x 0.99797) = 238.051 grams.
2. Calculate the total amount of plutonium in the fuel mixture. This can be done by multiplying the mass of each isotope by its corresponding fraction and then adding them all together. For example, for PuO2, it would be (239.052 x 0.936) + (240.054 x 0.059) + (241.057 x 0.004) + (242.059 x 0.001) = 239.052 grams.
3. Determine the enrichment of PuO2 in the fuel mixture. This can be done by dividing the mass of PuO2 by the total mass of UO2 and PuO2. In this case, it would be 239.052 / (238.051 + 239.052) = 0.501 or 50.1%.
4. Once you have the enrichment, you can use it to calculate the atom or weight fraction of oxygen in the fuel mixture. For example, if the enrichment is 50.1%, then the atom fraction of oxygen would be 1 - 0.501 = 0.499 or 49.9%. The weight fraction can be calculated in a similar way.
I hope this helps! Let me know if you have any other questions. Good luck!
Related to Atom or weight fraction in MOX fuel
1. What is an atom or weight fraction in MOX fuel?
An atom or weight fraction in MOX fuel refers to the proportion of different isotopes of uranium and plutonium in mixed oxide (MOX) fuel. This is expressed as a percentage or decimal value and represents the relative amount of each isotope present in the fuel.
2. How is the atom or weight fraction determined in MOX fuel?
The atom or weight fraction in MOX fuel is determined through a process called isotopic analysis. This involves separating and measuring the different isotopes present in the fuel using techniques such as mass spectrometry. The resulting data is then used to calculate the atom or weight fraction for each isotope.
3. Why is the atom or weight fraction important in MOX fuel?
The atom or weight fraction is important in MOX fuel because it impacts the performance and behavior of the fuel in a nuclear reactor. The presence of different isotopes can influence factors such as reactivity, burnup, and thermal properties, which can affect the overall efficiency and safety of the reactor.
4. How does the atom or weight fraction affect the use of MOX fuel in nuclear reactors?
The atom or weight fraction can affect the use of MOX fuel in nuclear reactors in several ways. For example, a higher proportion of fissile isotopes (such as plutonium-239) can increase the fuel's reactivity and lead to a higher power output. On the other hand, a higher proportion of non-fissile isotopes (such as plutonium-240) can cause issues with neutron absorption and reduce the efficiency of the fuel.
5. Can the atom or weight fraction be adjusted in MOX fuel?
Yes, the atom or weight fraction can be adjusted in MOX fuel by changing the ratio of uranium and plutonium isotopes during the fuel fabrication process. This allows for the optimization of the fuel's properties and performance for specific reactor designs and operational conditions.
  • Nuclear Engineering
