How Are Velocity and Angle Calculated When Crossing a River?
  • Thread starter Adeopapposaurus
  • Tags
    Boat River
In summary: Velocity of what upstream? If the boat points directly upstream then its velocity relative to the bank will be 2m/s, but it will never make progress across the river.arccos = (2/3)What angle is this supposed to be? You seem to be imagining a right angled triangle with hypotenuse 3 and a side 2, but the given 3 and calculated 2 are in the same direction.√3^2 - 2^2 = 6m/swhere does the √3 come from?What are the values of √3^2 and 2^2 ? What do you get from
Adeopapposaurus
The speed of the boat on the water without stream is v_1 = 5 m/s. The water flows in the river parallel to the shore at a speed of v_2 = 3 m/s.
How should the boat be directed to cross the river in a direction perpendicular to the shores (What should be the angle between the boat and the shore)?
How long it takes for the boat across the river which is 80 meters wide?
arccos = (vr/vu)
a^2+b^2+c^2
v upstream = 5 - 3 =2
v of the water = 3
arccos = (2/3) = 48.19
v across the river = c^2 - a^2 = b^2
√3^2 - 2^2 = 6m/s
t = 80/6 = 13.3
can someone please point out my mistakes? am I even supposed to solve for angle like this or "perpendicular to the shores" just means that the angle is supposed to be 90 degrees?
Adeopapposaurus said:
Homework Statement:: The speed of the boat on the water without stream is v_1 = 5 m/s. The water flows in the river parallel to the shore at a speed of v_2 = 3 m/s.
Relevant Equations:: arccos = (vr/vu)
a^2+b^2+c^2
v of the water = 3
√3^2 - 2^2 = 6m/s
t = 80/6 = 13.3
You need to explain to yourself and us what you are doing. In particular, you need a clear vector diagram of the motion of the boat relative to the shore.
A speed of ##6m/s## for motion across the river must be too high. It can't be greater than the ##5m/s## it would be without any current.
v upstream = 5 - 3 =2 ❌
v of the water = 3
Do you know how to do a vector addition?
If not yet, please, see:
http://hyperphysics.phy-astr.gsu.edu/hbase/vect.html#vec1
Note that given ##V_1## is referenced to the water, while ##V_2## is referenced to the ground.
I believe that the problem asks about the trajectory corrections that the captain of that boat should do to travel between two docks, which are joined by a line that is perpendicular to the shores of the river.
For days when ##V_2=0##, he does not need to correct that trajectory.
For days when water flows at ##V_2=3 m/s##, what would you do to reach your destination and how long would the trip would take you, if you were that captain?
v of the water = 3
√3^2 - 2^2 = 6m/s
t = 80/6 = 13.3
I count five.
arccos = (2/3)
√3^2 - 2^2 = 6m/s
What are the values of √3^2 and 2^2 ? What do you get from that subtraction?
Your equation said c^2 - a^2 = b^2, not c^2 - a^2 = b. So what did you forget to do?
Draw a diagram with a vector representing the current and a vector representing the boat's velocity relative to the current. This should point at some angle upstream. The sum of these two will be in the actual direction the boat takes. What direction does that need to be?
Likes hmmm27
Related to How Are Velocity and Angle Calculated When Crossing a River?
1. How does a boat move across a river?
A boat moves across a river by using a combination of propulsion and steering. The propulsion can come from oars, sails, or a motor, and the steering is typically done by a rudder or by adjusting the sails.
2. What factors affect the speed of a boat crossing a river?
The speed of a boat crossing a river can be affected by several factors, including the strength and direction of the current, wind speed and direction, the size and weight of the boat, and the power of the propulsion system.
3. How does the angle of the boat affect its movement across the river?
The angle of the boat can greatly affect its movement across the river. If the boat is angled too much against the current, it may struggle to make progress. On the other hand, angling the boat with the current can help it move more efficiently.
4. Can a boat cross a river without a motor?
Yes, a boat can cross a river without a motor. It can use oars or sails to propel itself across the river. However, the speed and efficiency of the crossing may be affected by the strength and direction of the current and wind.
5. How does the weight distribution on a boat affect its stability while crossing a river?
The weight distribution on a boat is crucial for maintaining stability while crossing a river. If the weight is unevenly distributed, the boat may tilt to one side, making it more difficult to steer and potentially causing it to capsize. It is important to evenly distribute weight on a boat to ensure safe and stable crossing.
