Boiling Water using Heat vs. Vacuum
In summary, during a thermo lab experiment, water boiled from the bottom of a chamber when vacuum was applied. This seems to be due to the pressure difference between the top and bottom of the chamber. Bubbles form on the bottom of the chamber, which is the surface that is the hottest.
KrisOhn
195
If you bring a pot of water to boil, you will notice that the bubbles form on the bottom surface of the pot. This seems to make sense intuitively as this is the hottest surface, so this would be where the boiling action starts.
When I was in school during a thermo lab we pulled a vacuum in a chamber filled with water to induce boiling. I noticed that when you do this the bubbles also form from the bottom surface of the chamber, leading me to think that this is maybe a phenomena caused by the pressure of the water, not from a heat source.
Can anyone shed some light on why this happens? Why does the boiling action not start from a random point in the vacuum chamber? Why does it not start from the surface?
What is the pressure at the bottom compared to the top?
Does a submarine experience more pressure as it dives deeper?
My guess:
In order to continuously boil water you have to heat it, and that heat has to come from the metal pot. As the pressure drops, water boils and its temperature drops. Then it transfers heat from the pot, to heat the water and cool the pot.
Likes KrisOhn
I think Russ already answered my question, but I'm curious as to the result of yours.
Are you implying that a submarine does not experience more pressure as it dives deeper?
The opposite; it does.Here's your question.
If the water is all at the same temperature, then you subject it to a vacuum, the water with the least pressure (i.e. near the surface) will boil first. That is not a random point.
You should also notice that the bubbles in a carbonated beverage typically rise from the bottom of the glass. My guess is that the most important factor in all of these cases is the presence of, and detachment geometry from, nucleation centers.
Likes russ_watters and berkeman
When pulling a vacuum, the water should start boiling at the top, since the hydrostatic pressure is greatest at the bottom, and least at the top.
Before the water boils the dissolved gasses will be released and escape. They will form as gas bubbles at imperfections and at sites of contamination on the container surface. That will include the scratched bottom of the container.
For shallow containers scratches may also influence the point where you first see water boiling. In a deep container, such as a 10 metre barometer, the water will boil at or close to the surface.
KrisOhn said:
When I was in school during a thermo lab...
Since you don't mention how long ago that was, I can only guess that:
a. you remember incorrectly​
b. your pressure flask had a dirty and/or rough bottom. as mentioned in the last two posts,​
c. things happened too fast to accurately describe what really happened, or​
d. a combination of the above​
In the following video, starting around 2 minutes, nucleation points can be seen from top to bottom of the thermometer, an 'artificial nucleation' device.
When I slowed the video down to its minimum speed, and zoomed in on the left hand side of the thermometer, I noticed that during the initial stages of boiling, the bubbles near the top were swept away first, leaving a blank area. At normal speed, it looks as if they aren't even there! Hence the illusion that the boiling starts at the bottom.
Likes russ_watters
This is intuitively what I would expect to be correct.
I expect it's a combination of the above. I can remember that when I was in the lab and observed the behaviour I asked the instructor about it, but he never had a good answer for it.
Thanks for all the answers everyone.
Likes 256bits
Related to Boiling Water using Heat vs. Vacuum
1. How does boiling water using heat differ from boiling water using vacuum?
Boiling water using heat involves heating the water to its boiling point, which is 100 degrees Celsius at sea level. This causes the water molecules to gain enough energy to break free from the liquid phase and form bubbles. Boiling water using vacuum, on the other hand, involves reducing the pressure around the water, which lowers its boiling point and causes it to boil at a lower temperature.
2. Which method is more efficient for boiling water?
In terms of energy usage, boiling water using heat is more efficient. This is because the energy required to heat the water to its boiling point is less than the energy required to create a vacuum and lower the boiling point. However, in certain applications, boiling water using vacuum may be more efficient, such as in industrial processes where a lower boiling point is needed.
3. Can boiling water using vacuum make the water boil faster?
Yes, boiling water using vacuum can make the water boil faster. This is because the lower boiling point means that the water will reach its boiling point at a lower temperature, and therefore, it will take less time to heat the water to that temperature.
4. Is one method safer than the other?
Both methods are generally considered safe as long as proper precautions are taken. Boiling water using heat can pose a risk of burns if the water is not handled carefully, while boiling water using vacuum can be dangerous if the vacuum is not properly maintained and there is a risk of implosion. It is important to follow safety guidelines and instructions when using either method.
5. Are there any differences in the resulting boiled water?
The resulting boiled water from both methods is essentially the same, as both methods involve heating the water to its boiling point. However, boiling water using vacuum may result in a slightly different taste due to the lower boiling point and potential changes in the water's chemical composition. This may be more noticeable in sensitive applications such as cooking or brewing.
  • Mechanical Engineering
  • General Engineering
