Calculate optical path in SELFOC cylindrical fiber optic
C= n0/cosγ0tan(sin-1(sin(αz/cosγ0))) - (n0/cosγ0)(1/2)(tan2(γ0)(sin-1(sin(αz/cosγ0)))2-(sin-1(sin(αz/cosγ0)))) + C= n0/cosγ0(sin(αz/cosγ0)) - (n0/cosγ0)(1/2)(tan
Bromio
62
Hi.
This is my first message in this forum. I'm not English, so sorry my spelling.
Calculate the optical path done by a meridional ray, supposing it covers a horizontal distance, d, in z-axis direction. [tex]\gamma_0[/tex] is the launch angle (with z-axis).
Optical path equation:
[tex]L = \displaystyle\int^d_0 n(\rho) dl[/tex]
Because we work with SELFOC fiber optic, refraction index is: [tex]n^2(\rho) = n^2_0\left(1-\alpha^2\rho^2\right)[/tex]
The trajectory equation is:
[tex]\rho(z) = \displaystyle\frac{\sin\gamma_0}{\alpha} \sin\left(\displaystyle\frac{\alpha z}{\cos \gamma_0}\right)[/tex]
[tex]dl = \sqrt{d\rho^2+dz^2}[/tex] (infinitesimal calculus).
I've tried to write optical path equation in function of variable z. So, the resultant integral is:
[tex]\displaystyle\int_{0}^{d}n_0\sqrt[ ]{1-\sin^2\left(\gamma_0\right) \sin^2\left(\displaystyle\frac{\alpha z}{\cos \gamma_0}\right)}\sqrt[ ]{1+\displaystyle\frac{\sin^2\gamma_0}{\cos^2\gamma_0}\cos^2\left(\displaystyle\frac{\alpha z}{\cos\gamma_0}\right)}dz[/tex]
How can I solve this integral?
Thanks!
Hello and welcome to the forum! It's great to have you here and don't worry about your spelling, we're all here to learn and help each other.
To solve this integral, we can use the substitution method. Let u = sin(αz/cosγ0) and du = (α/cosγ0)cos(αz/cosγ0)dz. Then we can rewrite the integral as:
∫n0√(1-sin2(γ0)u2)√(1+(sin2(γ0)/cos2(γ0))u2)(cosγ0/α)du
= n0/cosγ0∫√(cos2(γ0)-sin2(γ0)u2)√(cos2(γ0)+sin2(γ0)u2)du
= n0/cosγ0∫√(cos2(γ0)-sin2(γ0)u2)√(1+u2)du
= n0/cosγ0∫√(1-(sin2(γ0)/cos2(γ0))u2)√(1+u2)du
Now we can use the trigonometric substitution method to solve this integral. Let u = tanθ, then du = sec2θdθ. Substituting this in, we get:
n0/cosγ0∫√(1-tan2(γ0)θ2)√(1+tan2θ)sec2θdθ
= n0/cosγ0∫√(1-tan2(γ0)θ2)secθsecθdθ
= n0/cosγ0∫sec2θdθ - n0/cosγ0∫sec2θtan2(γ0)θ2dθ
= n0/cosγ0tanθ - (n0/cosγ0)(1/2)(tan2(γ0)θ2-θ) + C
= n0/cosγ0tan(tan-1u) - (n0/cosγ0)(1/2)(tan2(γ0)(tan-1u)2-(tan-1u)) + C
= n0/cosγ0tan(tan-1(sin(αz/c
Related to Calculate optical path in SELFOC cylindrical fiber optic
1. What is the optical path in SELFOC cylindrical fiber optic?
The optical path in SELFOC cylindrical fiber optic is the length of the fiber optic through which light travels. It is a measure of the distance light travels within the fiber optic and is typically measured in meters or millimeters.
2. How is the optical path calculated in SELFOC cylindrical fiber optic?
The optical path in SELFOC cylindrical fiber optic can be calculated using the formula: Optical Path = Refractive Index x Length of the Fiber Optic. The refractive index is a measure of how much a material can bend light and is typically provided by the manufacturer. The length of the fiber optic can be measured using a ruler or other measuring device.
3. What factors can affect the optical path in SELFOC cylindrical fiber optic?
Several factors can affect the optical path in SELFOC cylindrical fiber optic, including the material and design of the fiber optic, the wavelength of the light being transmitted, and any bends or twists in the fiber optic.
4. How does the optical path in SELFOC cylindrical fiber optic impact signal transmission?
The optical path in SELFOC cylindrical fiber optic can impact signal transmission by affecting the amount of light that reaches the end of the fiber optic. A longer optical path can result in more attenuation (loss) of the light signal, leading to a weaker signal at the end of the fiber optic.
5. Are there any tools or methods available to measure the optical path in SELFOC cylindrical fiber optic?
Yes, there are several tools and methods available to measure the optical path in SELFOC cylindrical fiber optic. These include using an optical time domain reflectometer (OTDR), which sends a pulse of light into the fiber optic and measures the time it takes to reflect back, or using a fiber optic power meter to measure the amount of light transmitted through the fiber optic.
