Calculate speed from elastic and inelastic collisions? (momentum)
In summary, the conversation discusses a question about calculating the speed of a trolley after a collision, with different scenarios of an elastic and inelastic collision. The equations for calculating the velocities in both cases are provided, leading to the conclusion that the first cart would not stop in an elastic collision due to unequal masses. The possibility of an error in the question is also mentioned.
OscarF
Question:
Trolley A, of mass 180 g, is moving at a velocity of 4 m/s towards trolley B which is stationary and has a mass of 120 g. Trolley A then collides with trolley B.
Calculate the speed of trolley B if:
i the collision is elastic (trolley A stops and trolley B moves off)
ii the collision is inelastic (the two trolleys join and move off together).
momentum = mass x velocity
So to cut to the chase, I missed my class' lesson on momentum - have tried to catch up, quite successfully but am baffled about this question. I know the conservation of momentum etc. but after trying for ages it's just not happening this question so any help would be much appreciated,
Oscar.
OscarF said:
Homework Statement:: Question:
Relevant Equations:: momentum = mass x velocity
Oscar.
How much can you do? You need to show us your work.
Note that:
Is not a possible scenario. Which you may be able to prove.
Note that:
Well, from a bit more digging around I came up with these two calculations:
(For the elastic scenario)
V2f=(2m1/(m1+m2))*v1i
(For the inelastic scenario)
V2f=(m1v1)/(m1+m2)
Which led me to the answers:
i) 4.8 m/s
ii) 2.4 m/s
The answer to ii) looks right.
Did you check momentum conservation for i)? What happens to the 180g cart after the collision?
Good point! Will check now, one second.
I just realized... obviously the momentum will not be the same... because for trolley B pre-collision the momentum would be 0 and afterwards it will be whatever 120*4.8 is...
Hmm... I personally wouldn't expect such a twist in a homework like this... Do you think the solution would be to write something like this event isn't possible because...
As I understand it, you are using a formula for the velocity of the second cart in an elastic collision. You must have a similar formula for the velocity of the first cart.
Perhaps whoever set the question made a mistake. In an elastic collision the moving cart only stops if the two carts have equal mass; otherwise, both carts are moving after the collision.
I do have an equation for the first cart - let me just check what that gives as a result in this instance
Hmm... The output results as 0.8 m/s if I do that... Due to the nature of the question, it just feels unlikely that it's a mistake - but you never know - so I have a few options. Either, I just keep it as it is - the answer fine, done and dusted or I add the answer but also add a little note to the side or I can try and talk to my teacher before the homework is due. If I were to right a note about why it's impossible, what would you suggest?
It depends whether your teacher is the sort of person who can accept that he/she made a mistake!
##0.8m/s## and ##4.8m/s## are definitely correct.
They didn't make the worksheet - It's an AQA physics gcse practice question. My teacher's a nice person though - would be fine if I wanted to contest the question!
Likes PeroK
OscarF said:
Homework Statement:: Question is below
Background:
Unfortunately, I missed my class' lesson on momentum. I've watched this video: https://www.khanacademy.org/science...lisions-ap/v/elastic-and-inelastic-collisions. To try and help me with the following homework - it helped but I still can't really get the answer.
Question:
Any help would be much appreciated,
Oscar.
You just need two general facts:
There being no external horizontal forces on the two trolley system, their total momentum is conserved. Just remember that velocity and momentum are vectors, so direction matters.
If the collision is elastic, total kinetic energy is conserved.
In case ii, KE is not conserved, but you know instead that the two have the same final velocity.
This is enough to find the final velocities. For any further help you must show some attempt.
Related to Calculate speed from elastic and inelastic collisions? (momentum)
What is momentum and how is it related to collisions?
Momentum is a measure of an object's motion and is calculated by multiplying its mass and velocity. In collisions, momentum is conserved, meaning that the total momentum before the collision is equal to the total momentum after the collision.
What is an elastic collision?
An elastic collision is a type of collision where the total kinetic energy of the system is conserved. This means that the objects involved bounce off each other without any loss of energy.
What is an inelastic collision?
An inelastic collision is a type of collision where the total kinetic energy of the system is not conserved. This means that some of the energy is lost during the collision, usually in the form of heat or sound.
How do you calculate the speed of an object after an elastic collision?
To calculate the speed of an object after an elastic collision, you can use the equation: v2 = (m1v1 + m2v2) / (m1 + m2), where m1 and m2 are the masses of the objects and v1 and v2 are their respective velocities before the collision.
How do you calculate the speed of an object after an inelastic collision?
To calculate the speed of an object after an inelastic collision, you can use the equation: v2 = (m1v1 + m2v2) / (m1 + m2), where m1 and m2 are the masses of the objects and v1 and v2 are their respective velocities before the collision. However, in an inelastic collision, some energy is lost, so the final velocity will be less than the calculated value.
