Calculating Molecular Diameter
In summary, the problem asks you to find the number of atoms in a cube of a given material, and to determine how far apart they are. Additionally, you need to know the properties of air, which is made of 80% nitrogen and 20% oxygen. With this information, the answer is easy to find.
new90
90
How can I calculate diameter of a molecule
none
find a relationship between something with a known number of molecules and its volume
thanks, but the issue is that I don't have the number of molecules because I that's the answer of the problem
perhaps you should state the entire problem rather than us playing "twenty questions"...?
Likes DaveE and BvU
ok,sorry...
Likes hutchphd
About 1860 Maxwell sowed that the viscosity of a gas is given by η=ρνι where ρ iπs density ν mean velocity and ι mean free path.The latter quantity he had earlier shown to be ι = 1/(square root of 2)(π)(Ng)(d2)where d is diameter of a molecule.Loshmidt(1865)used the measured value of η,p(gas) and p(solid) together with Joules calculation of ν to determine Ng the number of molecules per cm3 in a gas at STP(1atm 0°C).He assumed the molecules to be hard spheres tightly ppacked ina solid.Given η = 2*10^-4 cm^-1 s^-1 for air at STP ρ(liquid)≈ 1 g cm^-3 p(gas)≈1*10^-3 g cm-3 ,and ν≈ 500 m/s-1. Calculate Ng(number of molecules)
So, what are you missing ?
the diameter of the molecule
How are you going to use this ?
Why do you think they gave you two density values, one for liquid, and one for gas?
i know because it it tighly packed the density of liquid and solid are very similar
yes, so how can you use that information?
in the problem has a sentence that said "Loshmidt(1865)used the measured value of η,p(gas) and p(solid) together with Joules calculation of ν to determine Ng the number of molecules per cm3 in a gas at STP(1atm 0°C)".
hello?
So your problem is to find d, and clearly that has something to do with the densities given, which are for air. Would the answer be different for H2 instead of air?
Notice that the density given includes mass (g) in the dimensions, but mass doesn't appear anywhere else in the equations. This needs to be resolved somehow with external information.
Also note that there is a typo as presented you (or they) have mixed up the gas density and the liquid density in the problem. Easy to resolve though, use the larger one for liquids, the smaller one for gas.
Likes new90
Here's a related problem that may help:
A 1 cm x 1cm x 1cm cube of Aluminum has a density of 2.70 g/cm3. How many Al atoms are there in the cube? How far apart are they?
what is the answer?
I don't know how to get the Al atoms
OK, a 1cm x 1cm x 1cm cube has a volume of 1 cm3. With a density of 2.70 g/cm3, this means there are 2.70 g of Al in the cube. So, how many Al atoms weight 2.70 g? What information do you need to get to solve this problem? Where/how will you get it?
Then, when you find out how many atoms there are. How far apart are they (center to center, since they will be touching each other)? Imagine carefully placing tennis balls inside a big box to get as many as possible inside.
Finally, for the original problem, you will need to know that air is composed of 80% N2 and 20% O2. A N2 molecule weighs twice as much as a N atom.
thnaks for the help we solve it
Congratulations, good work!
Related to Calculating Molecular Diameter
1. What is the purpose of calculating molecular diameter?
The purpose of calculating molecular diameter is to determine the size of a molecule, which can provide important information about its physical and chemical properties. This information can be used in various scientific fields, such as chemistry, biology, and materials science.
2. How is molecular diameter calculated?
Molecular diameter is typically calculated using the molecular weight and density of a substance. The diameter can be estimated using various equations, such as the Stokes-Einstein equation or the Van der Waals equation. These calculations take into account the size and shape of the molecule, as well as its interactions with other molecules.
3. What factors can affect the accuracy of molecular diameter calculations?
There are several factors that can affect the accuracy of molecular diameter calculations. These include the assumptions made in the equations used, the purity of the substance being studied, and the temperature and pressure conditions. It is important to carefully consider these factors and use appropriate correction factors to improve the accuracy of the calculations.
4. Can molecular diameter be directly measured?
In some cases, molecular diameter can be directly measured using techniques such as X-ray crystallography or electron microscopy. However, these methods are often time-consuming and require specialized equipment. Therefore, calculating molecular diameter using mathematical equations is a more practical and widely used approach.
5. How is molecular diameter used in practical applications?
Molecular diameter is used in a variety of practical applications. In chemistry, it can help determine the solubility and reactivity of a substance. In biology, it can aid in understanding the structure and function of biomolecules. In materials science, it can be used to design and optimize the properties of new materials. Additionally, knowing the molecular diameter of a substance can also be useful in quality control and manufacturing processes.
