Camera Lens works as a Polarizer or not?
In summary, Maxwell's theory explains how an electric field can polarize dielectrics, causing the charges within to shift from their equilibrium distribution. This is different from the polarization of light, which refers to the orientation of the electromagnetic field. However, both effects are used in liquid crystal displays, where electric fields are used to physically move liquid crystal structures and create different polarizations that interact with fixed polarizers to display images.
Mustafa Umut
34
I read maxwell says electric field polarizes the dielectrics.
Does it mean above effect used at photographic camera lens design to make that lens sometimes works like polarizer filter ?
Mustafa Umut Sarac
Istanbul
No, they are different effects that share the same name.
I believe the effect that you are referring to Maxwell about is the polarization of a dielectric due to an external electric field. This just means that the charges in the dielectric are displaced from their equilibrium distribution by the external E-field.
Polarization of light (and other frequencies of EM radiation) refers to the majority of the EM E-field's orientation in space. Passing unpolarized light through a polarizing filter attenuates the light that is not oriented with the axis of the polarizing filter, and only let's the light through that has an AC EM E-field oriented with the axis of the filter.
I'll see if I can find a few references for further reading for you to help clear this up. Will post them in a few minutes... :smile:
thank you , I will.
Likes berkeman
By the way, there is an application that uses both of those effects at the same time, and you are probably reading this reply on one of those devices right now -- a Liquid Crystal Display. :smile:
https://en.wikipedia.org/wiki/Liquid-crystal_display
Electric fields are used to polarize and physically move mobile liquid crystal structures to create different kinds of polarizers (generally switching between random polarization and circular polarization) rotations of the plane of the polarized light (RPPL) in the liquid crystal. This varying polarization rotation in the liquid crystal interacts with fixed polarizers on the glass display to gate light through the pixels in the display. It's an interesting technology that has matured a lot over the last 30 years or so, and has brought us the most common high-resolution video displays that we use today in so many applications. :smile:
EDIT -- Fixed up my brief explanation about how polarization is used in LCDs (RPPL is the key).
EDIT / ADD -- here is a nice diagram showing the layers of a typical LCD screen:
http://www.mmt.io/wp-content/uploads/2015/08/LCD-Panel-FunctionalityInfographic-English_580px.jpg
Likes Asymptotic, jim hardy and dlgoff
Related to Camera Lens works as a Polarizer or not?
1. How does a camera lens work as a polarizer?
A camera lens works as a polarizer by only allowing light waves that vibrate in a specific direction to pass through. This results in reduced glare and reflections in photos, as well as more saturated colors and enhanced contrast.
2. Can any camera lens be used as a polarizer?
No, not all camera lenses have polarizing capabilities. Only specific types of lenses, such as circular polarizing lenses, have the ability to rotate and adjust the polarization of light passing through them.
3. What kind of light does a polarizing lens work best with?
Polarizing lenses work best with natural, unpolarized light, such as sunlight. They are less effective with artificial light sources, such as indoor lighting.
4. Do polarizing lenses affect image quality?
Yes, polarizing lenses can affect image quality in some ways. They can reduce the amount of light entering the camera, resulting in slightly darker photos. They can also cause a slight color shift in the image.
5. Are there any disadvantages to using a polarizing lens?
One potential disadvantage of using a polarizing lens is that they can create a dark, uneven sky in photos. This can be minimized by adjusting the angle of the lens. Additionally, polarizing lenses can be more expensive than non-polarizing lenses.
  • Electrical Engineering
12K
  • Computing and Technology
  • Mechanical Engineering
