Can all supposed difficult problems be broken down to simple ones?
  • Thread starter Hacker Jack
  • Tags
    Broken
In summary, Nicklaus Wirth claims that by breaking down a complex solution into simpler parts, a general understanding can be attained. This is similar to the idea of stepwise refinement, which is a technique used in science to solve problems with solutions. However, the time and resources required to solve a problem can also play a role in whether or not it can be solved.
Hacker Jack
I am wondering if you take any problem you consider difficult or complex can it be broken down to be understood in simple parts and successfully understood as a whole. Is there some stuff you consider difficult and there is just no getting around it.
Is it the nature of the brain to focus on one thing at a time to understand something or is there so much more stuff going on in the background that our brain does that we don't understand?
From your username I presume an interest in computer science. Nicklaus Wirth uses the interesting term stepwise refinement: refining or decomposing a complex solution into simpler, though not necessarily discrete, solvable parts. Though sometimes confused with top-down and bottom-up approaches, the steps approach the problem space from any convenient direction.
Stepwise refinement applies to problems with solutions. Deciding whether stated problems can be solved probably requires complexity theory. Consider also the time and resources required to solve.
Likes sysprog and russ_watters
It depends on what you call "simple", but in science, we often use approximations that simplify the problem. Of course, every time you use an approximation, there are some information that is lost or things that cannot be taken into account. Nonetheless, by using approximations, you can often understand the general idea.
What's up with your avatar? Are you a pirate or into death or something? How can I take your technical questions seriously when your avatar represents bad things?
Likes Vanadium 50 and marcusl
Just as bad as this avatar:
If you could break down everything into arbitrarily simple steps you could teach calculus to a dog. How? Step by step.
I'm not even sure if the steps are the limit. It could be the current state of a problem, too: Where are we in a proof, what do we know about the objects we are working with at the moment, what do we still need to do?
If you have read some longer mathematical proofs then you probably know the feeling where you can follow every step, but in the end you don't really understand what was done because you are still missing deeper insight in the proof.
Likes russ_watters
Sorry, but we don't allow threads that ask "What if, and have no answer". Thread closed.
Likes Bystander and Tom.G
Related to Can all supposed difficult problems be broken down to simple ones?
1. Can complex problems really be simplified?
Yes, it is possible to break down complex problems into simpler ones. This approach is often used in scientific research to understand and solve complex issues.
2. How do scientists break down complex problems?
Scientists use a variety of methods to break down complex problems, such as dividing the problem into smaller parts, using mathematical models, conducting experiments, and utilizing technology and tools.
3. Are there any limitations to breaking down complex problems?
While breaking down complex problems can be effective, there may be limitations in terms of time, resources, and the level of understanding of the problem. Some problems may also be inherently complex and cannot be reduced to simpler ones.
4. Can breaking down complex problems lead to oversimplification?
Yes, there is a risk of oversimplification when breaking down complex problems. It is important for scientists to carefully consider all aspects of the problem and not overlook any important details in the process of simplification.
5. How can breaking down complex problems benefit scientific research?
Breaking down complex problems can lead to a better understanding of the underlying mechanisms and relationships involved. This can ultimately lead to more accurate and effective solutions to complex problems, and advance scientific knowledge in a particular field.
  • General Discussion
  • STEM Academic Advising
  • Quantum Interpretations and Foundations
