Can "extremal" strain tensors be in the interior of the body
In summary, the conversation discusses the possibility of exceeding the elastic limit in the interior of a body while staying below the limit on the surface. This question arises in the context of optimizing the elastic deformation of a body while maintaining the constraint of never reaching the elastic limit. The conversation also mentions the use of analytic methods and FEA to test optimization procedures on objects with simple and complex geometries.
Chevallier
I am new to elastic theory. I have a question about elasticity. We assume we have a body with no internal forces. Surface forces are applied on the border. Can we leave the elastic domain (reach the yield surface) in an interior point without leaving the elastic domain on the boundary?
If no, is there a reference in the literature which shows that from the equations?
Thank you.
I have no idea what you are asking. Are you asking if the strain tensor is continuous across a boundary between two materials
Thanks for asking. I'll try to be more precise:
-Let Omega be a homogeneous and isotropic body.
-This body occupies a part of the space R^3, its border is a surface dOmega.
-We apply forces on dOmega. We don't consider other forces.
At a point in the body when local forces are small, the local deformation is elastic. When the forces get too big, the local deformation leaves the elastic domain.
The question is:
Can we find external forces such that we leave the elastic domain at a point in the interior of the body, without leaving the elastic domain on any point of the bordrer dOmega?
I still don't follow what you are asking, but here's my interpretation:
Is it possible to impose a load distribution on the surface of an object such that the elastic limit is exceeded on all parts of the surface while, in the interior of the object, there is a region in which the elastic limit is not exceeded?
Does that come anywhere close to what you are asking?
Possibly question is : Can there be a situation where externally applied forces create stresses below yield in the surface layers of an object but above yield in the interior of the object .
Chestermiller, it's almost that, just the other way around, as Nidum said. Is it possible to exceed the elastic limit at an interior point, while everywhere on the surface the elastic limite is not exeeded?
I would be a bit surprised if it was possible. If it's not, i am interested in how to show that from the equations.
I don't think it's possible, but I don't know how to prove it mathematically. What is the motivation for asking this question?
i would like to optimize over elastic deformation of a body (finding the best deformation in some sens), under the constraint that we never reach the elastic limit. In the optimization procedure, i am wondering if i should go over all points of the body and check if the constraint is verified, or if it is sufficient to check on the surface. This would reduce the computational complexity of the optimization.
Just checking the surface stress levels could be very unreliable when applied to complex shaped objects and especially to objects with holes in them .
Think about the simple example of a rectangular plate with a hole in it . With suitable loading this plate could have stresses below the elastic limit generally but above the elastic limit around the hole . Do you think that your proposed method would work in this case ?
You can always test any optimisation procedure using analytic methods on objects with simple geometry and FEA on objects of more complexity .
Can you tell us what type of objects you are trying to optimise the design of ?
Your interest is appreciated. For now i don't have a precise idea of a specific application case (I just started studying the problem). But i thought that the question "can you be above the elastic limit inside while being above the elastic limit on the border?", would be clearly answered by the equilibrium equation of elasticity. I am surprised that the answer seems not so easy to give...
Related to Can "extremal" strain tensors be in the interior of the body
1. Can "extremal" strain tensors occur in the interior of the body?
Yes, "extremal" strain tensors can occur in the interior of the body. In fact, they are common in areas where there is high stress or strain, such as near joints or in areas affected by external forces.
2. What are "extremal" strain tensors?
"Extremal" strain tensors are a type of tensor that represents the maximum or minimum strain experienced in a particular area of a body. They provide valuable information about the stress and strain distribution within a material.
3. How are "extremal" strain tensors measured?
"Extremal" strain tensors are typically measured using strain gauges or other sensors that can detect changes in deformation or strain within a material. These measurements are then used to calculate the tensor components.
4. What factors can affect the occurrence of "extremal" strain tensors?
The occurrence of "extremal" strain tensors can be affected by various factors, including external forces applied to the body, the material properties of the body, and the geometry of the body. These factors can influence the stress and strain distribution within the body, resulting in the formation of "extremal" strain tensors.
5. How are "extremal" strain tensors used in scientific research?
"Extremal" strain tensors are used in various fields of scientific research, such as materials science, biomechanics, and structural engineering. They provide important information about the mechanical behavior of materials and can help researchers better understand the effects of external forces on the body or structure being studied.
  • Science and Math Textbooks
  • Other Physics Topics
  • General Engineering
10K
  • Electromagnetism
  • Mechanical Engineering
