Can heat (Phonons) generate an electric field in Piezocrystals?
In summary, the phenomenon of pyroelectricity occurs when a piezocrystal is heated and causes it to vibrate, creating a small stress and shifting its electron density, resulting in an electric field. However, not all piezoelectric crystals exhibit this phenomenon, as it depends on the symmetry of the material. Additionally, pyroelectric crystals only produce an electric field during changes in temperature, whereas piezoelectric crystals can produce it from a constant temperature. The difference between piezoelectricity and pyroelectricity lies in the way the electric dipole is induced, with piezoelectric materials being more symmetrical than pyroelectric materials.
miniconfusion
I was thinking. Since phonons are lattice vibrations, and are affected by the temperature of the lattice, can heating a piezocrystal cause it to vibrate and therefore put a small stress on it, causing it's electron density to shift, creating an electric field?
Yes, the phenomenon is known as pyroelectricity http://en.wikipedia.org/wiki/Pyroelectricity.
But then why aren't all piezoelectric crystals pyroelectric crystals? Also, pyroelectric crystals only produce an electric field during changes in temperature, and not in the presence of a continued temperature. If piezoelectric crystals could produce an electric field from a temperature, the temperature would not have to be changing, but rather, that electric field would simply occur form a constant temperature.
The reason the voltage disappears over time is because there are leakage currents, not because the temperature stops changing.
The difference between piezoelectricity and pyroelectricity, broadly speaking, is that both involve inducing an electric dipole pointing in a particular direction, and so only exist if the material is not too symmetrical. But when you squeeze a material, in some sense you choose a direction (the direction you squeeze it in!), whereas when you change the temperature, you don't affect any direction preferentially. Thus materials can be more symmetrical and still be piezoelectric than they can and be pyroelectric. (Of course there are mathematical ways of formalising this distinction – google for crystallographic point groups if you're interested.)
Related to Can heat (Phonons) generate an electric field in Piezocrystals?
What is a piezocrystal?
A piezocrystal is a type of crystal that can generate an electric field when subjected to mechanical stress or pressure. This phenomenon is known as the piezoelectric effect.
How is an electric field generated in piezocrystals?
The piezoelectric effect in piezocrystals is caused by the displacement of positive and negative ions within the crystal lattice in response to mechanical stress. This displacement creates an electric field within the crystal.
Can heat also generate an electric field in piezocrystals?
Yes, heat can also generate an electric field in piezocrystals through the production of phonons. Phonons are collective vibrations of atoms within a crystal lattice that can carry energy and create an electric field when they interact with the crystal's charges.
What factors affect the generation of an electric field in piezocrystals?
The strength of the electric field generated in piezocrystals is affected by the intensity and direction of the mechanical stress, the properties of the crystal itself (such as crystal orientation and symmetry), and the temperature of the crystal.
What are the potential applications of heat-generated electric fields in piezocrystals?
The ability to generate electric fields in piezocrystals through heat can be useful in various applications, such as energy harvesting, sensing, and actuation. It can also be utilized in the development of new technologies, such as piezoelectric generators and sensors for high-temperature environments.
  • Atomic and Condensed Matter
