Canonical momentum ##\pi^\rho## of the electromagnetic field
In summary, the correct expression for the canonical momentum ##\pi^0##, as given by David Tong in his QFT notes, is ##\pi^0 = F^{00} - \partial_\nu A^\nu##. The discrepancy between this and the incorrect expression obtained by the speaker is due to a different choice of ##\alpha## in the Lagrangian, with Tong using ##\alpha=1## while the speaker may have used a different value. However, even with a different value of ##\alpha##, the speaker's result is incorrect due to the antisymmetric nature of ##F_{\mu\nu}##, resulting in ##F_{00}=0##. A few lines of computation are shown
Riotto
23
In David Tong's QFT notes (see http://www.damtp.cam.ac.uk/user/tong/qft/qft.pdf , page 131, Eq. 6.38) the expression for canonical momentum ##\pi^0## is given by ##\pi^0=-\partial_\rho A^\rho## while my calculation gives ##\pi^\rho=-\partial_0 A^\rho## so that ##\pi^0=-\partial_0 A^0##. Is it wrong in Tong's note?
It depends on the choice of ##\alpha## in (6.37). Tong writes "We will use ##\alpha=1##." You might have been using ##\alpha=\infty##, but even then your result is wrong because ##F_{\mu\nu}## is antisymmetric so ##F_{00}=\partial_0A_0-\partial_0A_0=0##.
Can you show a few lines of computation because I cannot figure out how are you getting that result. No, I am using ##\alpha=1## .
Can you show a few lines of computation because I cannot figure out how are you getting that result. No, I am using $\alpha=1.$
So you have Lagrangian of the form(##\alpha = 1##):
$$\mathcal{L} = -\frac{1}{4}F_{\mu\nu}F^{\mu\nu} - \frac{1}{2}(\partial_\mu A^\mu)^2$$
Calculation of canonical momenta is as follows:
$$\pi^\mu \equiv \frac{\partial\mathcal{L}}{\partial \dot{A}_\mu} = -\frac{1}{2}\frac{\partial F_{\nu\rho}}{\partial\dot{A}_{\mu}}F^{\nu\rho} - \partial_\nu A^\nu\eta^{\mu 0}$$
The first term gives:
$$\frac{\partial F_{\nu\rho}}{\partial\dot{A}_{\mu}} = \frac{\partial}{\partial (\partial_0 A_{\mu})}(\partial_\nu A_{\rho} - \partial_\rho A_{\nu}) = \delta^0_\nu \delta^\mu_\rho - \delta^0_\rho \delta^\mu_\nu$$
Finally we obtain:
$$\pi^\mu = F^{\mu 0} - \eta^{\mu 0}\partial_\nu A^\nu$$
This agrees with Tong, so there you go, that's the calculation. It's just basic differentiation though, so I don't know what was the problem there.
Likes vanhees71 and Demystifier
Related to Canonical momentum ##\pi^\rho## of the electromagnetic field
1. What is the definition of canonical momentum ##\pi^\rho## of the electromagnetic field?
The canonical momentum ##\pi^\rho## of the electromagnetic field is a mathematical quantity that describes the momentum of an electromagnetic field at a specific point in space and time. It is related to the electric and magnetic fields through the Maxwell equations and is a fundamental concept in classical electrodynamics.
2. How is the canonical momentum ##\pi^\rho## of the electromagnetic field different from regular momentum?
The canonical momentum ##\pi^\rho## of the electromagnetic field is a mathematical quantity that is used in the Hamiltonian formulation of classical mechanics, while regular momentum is a physical quantity that describes the motion of an object. The canonical momentum is related to the electric and magnetic fields, while regular momentum is related to the mass and velocity of an object.
3. What is the physical significance of the canonical momentum ##\pi^\rho## of the electromagnetic field?
The canonical momentum ##\pi^\rho## of the electromagnetic field is important because it allows us to describe the energy and momentum of an electromagnetic field in a consistent and mathematically elegant way. It also plays a crucial role in the formulation of quantum electrodynamics, where it is used to describe the interactions between particles and the electromagnetic field.
4. Can the canonical momentum ##\pi^\rho## of the electromagnetic field be measured?
No, the canonical momentum ##\pi^\rho## of the electromagnetic field is a mathematical quantity that is used in theoretical models and calculations. It cannot be directly measured, but its effects can be observed through the behavior of electric and magnetic fields.
5. How does the canonical momentum ##\pi^\rho## of the electromagnetic field change in different reference frames?
The canonical momentum ##\pi^\rho## of the electromagnetic field is a relativistic quantity and therefore changes in different reference frames. This is due to the fact that electric and magnetic fields also change in different reference frames, and the canonical momentum is related to these fields. However, the overall energy and momentum of the electromagnetic field will remain the same in all reference frames, as dictated by the principles of relativity.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
