Change in velocity of air due to fan
In summary, the conversation discusses the problem of finding the velocity of air at different distances from the tip of a nozzle. The person is designing a toy for a class and is trying to create an engineering model for a fan that levitates a ball. They have been able to model the drag force at the tip of the nozzle, but are struggling with different heights above it. They discuss using a nozzle as a flow meter and calculating the drag force using assumptions such as air density and drag coefficient. The conversation also mentions the use of an axisymmetric jet equation and the concept of the jet thickness growing linearly.
danield
38
Ok i have the following problem, I have a fan connected to the nozzle, i am given the nozzle area and the volumetric flow rate generated by the fan. How can i find the velocity of the air at different distances from the tip of the nozzle?
any help is greatly appreciated
if it is not too much to ask can you help me understand the equation? i am completely lost just from watching it..
Im assuming Umax is the velocity at the tip of the nozzle, and Function U is the velocity at certain distance away from the tip of the nozzle... I am also assuming rho is the density of the fluid (in this case air) but other than that I am lost with the symbols
If the flow is incompressible and one-dimensional, you can use the 1-D mass flow rate equation and cancel out the density.
Not really. He wants at distances past the nozzle.
Sure, actually, I'm sorry that's actually incorrectly a plane jet; you really want an axisymmetric jet (I actually think I put a wrong equation in there).
OK, basically you can get the velocity at the nozzle area by simply using the definition of volumetric flow rate
[tex]
Q = VA
[/tex]
So
[tex]
V = \frac{Q}{A}
[/tex]
So, let's denote the velocity at that section [tex]V_{max}[/tex] and the axial distance as 0.
From there, it can be shown that velocity drops off as [tex]x^{-1}[/tex] If you would like the derivation, I can post it, although it involves a similarity solution which may be a little over your head.
Note that there are a lot of constraints in there, and if you are off-axis or anything like that, then the equations don't work; you'll need the entire thing.
What is your application here?
we are designing a toy for a class, and now we are doing engineering models. I am supposed to do an engineering model on a fan that is supposed to levitate a ball. I was able to model the drag force generated at the tip of the nozzle, but i haven't been able to do so for different heights above it. Basically the part of the toy i am in charge of is a bernoulli ball levitation...
I misread the problem. Care to cite a reference for your axisymmetric jet equation? I would be hesitant to apply it without knowing more about the problem.
Viscous Fluid Flow, Frank White, Chapter 4, Section 10.6, The Narrow Axisymmetric Jet.
The full axial jet velocity is:
[tex]
u = \frac{3J}{8\pi\mu x}\left( 1 + \frac{C^2 \eta^2}{4}\right)^{-2}
[/tex]
Where J is the integral of momentum of the jet, and the constant C is determined from that. \eta is r/x. I can post the full similarity solution if needed.
So, on-axis, you're velocity will drop off by 1/x. There have been a couple of posts so far on this very topic. Danield, what have you found as far as drag on a ball?
A nozzle makes a wonderful flow meter. Can you simply put a throat pressure tap and an upstream tap to measure the pressure? Then it is pretty easy to calculate the actual flow. The fan will most likely not put out the same flow with a different back pressure on it.
well what i did was the following, i was given the area of the fan and the volumetric flow rate, so then i assumed the nozzle will operate at steady state so A1V1=A2V2 and A1V1 is equal to the volumetric flow rate so i divided this by the area of the nozzle tip giving me the velocity at that point.
Then to calculate the drag force i had to make a couple of assumptions such as standard air density, drag coefficient to be .4 (rough sphere), then the area is 2*Pi*R^2 (of the sphere)and with the velocity i found from the previous equation i got the drag force at that point... now what I am trying to find is how to calculate the force or velocity of air at distance Y from the tip of the nozzle... if it drops by 1/x what happens if the x is less than a meter wouldn't that say it increases?
This...is a good point. Looking back through the plane jet solution, that one is divided by x as well [tex]x^{1/3}[/tex] actually.
Going back through though, the axial variable, x, is merely arbitrary and used for similarity (i.e. [tex]\eta = r/x[/tex]. Moreso, it only shows up when the similarity variable is resubstituted back into the equations.
Most importantly, it is linear, so I would argue that you can define your x anywhere you want. It might be helpful to say that x=1 is at the exit of the nozzle. Then the jet thickness grows linearly as desired.
i am still confused as how to do this... should i use Vat nozzle divided by height and that should be the answer?
Related to Change in velocity of air due to fan
1. How does a fan change the velocity of air?
A fan changes the velocity of air by creating a pressure difference between the front and back of the fan blades. This pressure difference causes the air to move from areas of high pressure (front of the fan) to areas of low pressure (back of the fan), resulting in a change in velocity.
2. What factors affect the velocity of air from a fan?
The velocity of air from a fan is affected by several factors, including the size and shape of the fan blades, the speed at which the blades rotate, and the power of the motor driving the fan. The surrounding environment, such as obstacles or air resistance, can also impact the velocity of air from a fan.
3. How can the velocity of air from a fan be measured?
The velocity of air from a fan can be measured using an anemometer, which is a device that measures the speed and direction of airflow. Another method is to use a smoke test, where smoke is introduced into the airflow and the movement of the smoke particles is observed to determine the velocity of the air.
4. Can the direction of the fan affect the velocity of air?
Yes, the direction of the fan can affect the velocity of air. When a fan is facing towards a surface, such as a wall or ceiling, the air bounces off and creates a circulation pattern, resulting in a change in velocity. If the fan is facing towards an open space, the air can flow more freely, resulting in a higher velocity.
5. How does the velocity of air from a fan impact room temperature?
The velocity of air from a fan can impact room temperature by creating a wind chill effect. This is when the moving air increases the rate of evaporation from the skin, making it feel cooler. However, fans do not actually change the temperature of the air, so once the fan is turned off, the room will return to its original temperature.
  • Mechanical Engineering
  • Other Physics Topics
