Chemical water treatment: Acid base reaction
In summary, the conversation discusses a hypothetical waste system that uses nanotechnology to process waste. The system has an initial filter to catch solid waste, while urine and other liquid waste are passed through a series of filters. However, the system still has a problem with HCl, which is small enough to pass through all filters. The proposed solution is to add NaOH to neutralize the HCl, but this could create toxic salts. The conversation then explores the possibility of using electronic pH meters to constantly monitor and adjust the pH levels, but there are concerns about the accuracy and cost of this solution.
caters
229
I was thinking of a hypothetical waste system that uses nanotechnology to its advantage.
At the individual level, waste just passes through into pipes when flushed like it normally does.
But once it reaches the water treatment plant there is an initial filter to catch solid waste(in other words poop) and divert it to a different part of the system where it gets dried and eventually ground into a biosolid that can be used as fertilizer.
Meanwhile all the urine, vomitus, blood, and any diarrhea that didn't get caught by the initial filter is passed through a series of filters to catch smaller and smaller waste products from cells all the way to molecules like urea being blocked with a nanofilter. Only a few compounds besides water are left. Yes there are still small ions like potassium and this might actually pose a problem.
But the real threat is that [itex]HCl[/itex] is still in the water. Pepsin and other enzymes have been blocked by the nanofilters but [itex]HCl[/itex] is still small enough to pass through all of the filters. A nanofilter that can block [itex]HCl[/itex] is so impractical that it would most likely block the water itself until either the water treatment system or the microfilters and nanofilters burst from pressure and you end up with a critical failure either way.
So there has to be a chemical reaction that either deactivates the [itex]HCl[/itex] and thus renders it harmless or a reaction that leaves no trace of [itex]HCl[/itex] .
I was thinking that to render the water safe, [itex]NaOH[/itex] should be added to increase the amount of saltwater and totally get rid of the [itex]HCl[/itex]. But then I realized that with potassium and other ions besides sodium and chloride still in the water this could make the water toxic due to toxic salts forming.
Potassium chloride is the least harmful of all the salts that could form besides sodium chloride. Other than the bitter taste, there is basically nothing wrong with using potassium chloride. Similar for calcium chloride. Magnesium chloride though could cause diarrhea due to the magnesium(I know at least part of that diarrhea is from magnesium because the magnesium supplement I take helps to prevent constipation). I am not as worried about hydroxides because those would react with hydrogen ions to produce water.
But those salts are not the only problem. The other problem is how much [itex]NaOH[/itex] to add.
I mean to get [itex]HCl[/itex] down to 0 every time, there would have to be sensors to not only know the volume of water but also the concentration of [itex]HCl[/itex] and a relatively complicated math problem like this:[tex][HCl]∗x=a mol HCl=a mol NaOH=[NaOH]∗y[/tex]What is complicated about it? Well for one how would you sense the exact concentration of a strong acid or base without damaging the sensory equipment? And unless you regularly go to the water treatment plant with this nanotechnology, you won't know what the concentration of [itex]NaOH[/itex] is. And the concentration of [itex]HCl[/itex] will most likely vary day to day depending on factors such as these:
  • How often any given person vomits
  • Hydration level before vomiting
  • Amount of bile in the vomit
  • Dilution of stomach acid
  • Amount of blood in the vomit if any
  • Prevalence of vomiting from any cause
  • Total Volume of vomit
So basically my question is how can I have the part of the system after the filters be constantly sensing the exact concentration of [itex]HCl[/itex] , doing the math, and adding the amount of [itex]NaOH[/itex] that will get the concentration of [itex]HCl[/itex] down to exactly 0?
Likes Merlin3189
Chemistry news on Phys.org
You could put an electronic pH meter at the end of your process and test for ph7, considered to be exactly neutral.
If the meter reads a pH lower than 7 then not all of the acid is being neutralized so you need to add more of the base substance upstream
That adjustment could be made fully automated.
While there would a small amount of lag between making an adjustment and the pH returning to neutral, I don't think it would be enough lag to worry about.
Likes Merlin3189
I also think this is personal theory. Bacteria and oxygen do what you are talking about at essentially no cost compared to your proposal.
FYI- we really do not support personal theory.
Likes BillTre
Related to Chemical water treatment: Acid base reaction
What is chemical water treatment?
Chemical water treatment is the use of chemical processes to purify and improve the quality of water. This can involve the use of various chemicals to remove impurities, balance pH levels, and prevent the growth of harmful bacteria.
What is an acid base reaction in chemical water treatment?
An acid base reaction in chemical water treatment is a chemical reaction between an acid and a base that results in the formation of a salt and water. This reaction is commonly used to neutralize acidic or basic water, bringing it to a more neutral pH level.
What are the benefits of using acid base reactions in water treatment?
The use of acid base reactions in water treatment has several benefits, including balancing pH levels, removing metals and other impurities, and preventing the growth of harmful bacteria. It can also improve the taste and odor of water, making it more palatable for consumption.
What types of acids and bases are commonly used in chemical water treatment?
The most commonly used acids in chemical water treatment include sulfuric acid, hydrochloric acid, and phosphoric acid. Commonly used bases include sodium hydroxide, potassium hydroxide, and calcium carbonate.
What precautions should be taken when using acid base reactions in water treatment?
When using acid base reactions in water treatment, it is important to follow proper safety protocols and handle the chemicals with care. This may include wearing protective gear, such as gloves and goggles, and ensuring proper ventilation in the workspace. It is also important to accurately measure and mix the chemicals according to recommended guidelines to avoid any potential hazards.
  • Chemistry
  • Chemistry
