goku3240
- 4
1) Given an integer variable strawsOnCamel , write a statement that uses the auto-increment operator to increase the value of that variable by 1.
2) Given an integer variable timer , write a statement that uses the auto-decrement operator to decrease the value of that variable by 1.
3) Given an int variable k that has already been declared, use a while loop to print a single line consisting of 97 asterisks. Use no variables other than k .
4) Given an int variable n that has already been declared and initialized to a positive value, and another int variable j that has already been declared, use a while loop to print a single line consisting of n asterisks. Thus if n contains 5, five asterisks will be printed. Use no variables other than n and j .
5)
Given int variables k and total that have already been declared, use a while loop to compute the sum of the squares of the first 50 counting numbers, and store this value in total . Thus your code should put 1*1 + 2*2 + 3*3 +... + 49*49 + 50*50 into total . Use no variables other than k and total .
Instructor's notes: You must initialize the value of the variables total and k prior to your loop.
6) Given an int variable n that has been initialized to a positive value and, in addition, int variables k and total that have already been declared, use a while loop to compute the sum of the cubes of the first n counting numbers, and store this value in total . Thus if n equals 4, your code should put 1*1*1 + 2*2*2 + 3*3*3 + 4*4*4 into total . Use no variables other than n , k , and total . Do NOT modify n .
7) Given an int variable k that has already been declared, use a do...while loop to print a single line consisting of 97 asterisks. Use no variables other than k .
8) Given an int variable n that has already been declared and initialized to a positive value, and another int variable j that has already been declared, use a do...while loop to print a single line consisting of n asterisks. Thus if n contains 5, five asterisks will be printed. Use no variables other than n and j .
9) Given int variables k and total that have already been declared, use a do...while loop to compute the sum of the squares of the first 50 counting numbers, and store this value in total . Thus your code should put 1*1 + 2*2 + 3*3 +... + 49*49 + 50*50 into total . Use no variables other than k and total .
10)Given an int variable k that has already been declared, use a for loop to print a single line consisting of 97 asterisks. Use no variables other than k .
11)Given an int variable n that has already been declared and initialized to a positive value, and another int variable j that has already been declared, use a for loop to print a single line consisting of n asterisks. Thus if n contains 5, five asterisks will be printed. Use no variables other than n and j .
12)
Given int variables k and total that have already been declared, use a for loop to compute the sum of the squares of the first 50 counting numbers, and store this value in total . Thus your code should put 1*1 + 2*2 + 3*3 +... + 49*49 + 50*50 into total . Use no variables other than k and total . Given that two int variables, total and amount, have been declared, write a loop that reads integers into amount and adds all the non-negative values into total. The loop terminates when a value less than 0 is read into amount. Don't forget to initialize total to 0.
14)Assume that the int variables i , j and n have been declared, and n has been initialized. Write code that causes a "triangle" of asterisks to be output to the screen, i.e., n lines should be printed out, the first consisting of a single asterisk, the second consisting of two asterisks, the third consisting of three, etc. The last line should consist of n asterisks. Thus, for example, if n has value 3, the output of your code should be (scroll down if necessary):
use repitation if else control structures
got like 5 of em rest have weird logic
