Confusion with Disconnected sets
In summary, the question is: How can a set X = (0,1] u (1,2) be connected under the usual metric topology of the reals? The definition being used is that a set A is disconnected if there exist two open sets G and V where A intersect G ≠ ∅, A intersect V ≠ ∅, A is a proper subset of the union of G and V, and the intersection of G and V is empty. However, the suggested sets (0, 1] and (1, 2) do not work because (0, 1] is not open and (0, 1]\cup (1, 2)= (0, 2).
Mr-T
Hello,
I am having some difficulties understanding why a subset under the usual metric topology of the reals is connected.
How can a set X = (0,1] u (1,2) be connected?
The definition I am using is:
A is disconnected if there exists two open sets G and V and the following three properties hold:
(1) A intersect G ≠ ∅
A intersect V ≠ ∅
(2) A is a proper subset of the union of G and V.
(3) the intersection of G and V is the empty set.
Thanks
And you also want ##G## and ##V## to be open. No?
Yea, that would be more correct.
Okay, so can you find two such open sets for [itex](0, 1]\cup (1, 2)[/itex]? (0, 1] and (1, 2) will not do because (0, 1] is not open. (And, did you notice that [itex](0, 1]\cup (1, 2)= (0, 2)[/itex]?)
for your question. It is understandable to have confusion about disconnected sets, as the concept can be counterintuitive at first. However, let me try to explain why the set X = (0,1] u (1,2) is actually connected.
First, let's review the definition of a connected set. A set is connected if it cannot be divided into two non-empty subsets that are both open and disjoint. In other words, there is no way to separate the set into two open sets that do not intersect.
Now, let's look at the set X = (0,1] u (1,2). This set consists of two disjoint open intervals, (0,1] and (1,2), which are connected to each other by the point 1. This means that no matter how we try to divide X into two open sets, at least one of those sets will have to include the point 1, thus making them intersect. Therefore, X cannot be divided into two non-empty, disjoint open sets, and is therefore connected.
I hope this explanation helps clarify the concept of connected sets for you. If you have any further questions or need more clarification, please don't hesitate to ask. As scientists, it is important for us to have a clear understanding of mathematical concepts in order to accurately interpret and analyze data. Keep up the good work in trying to understand these concepts!
Related to Confusion with Disconnected sets
1. What are disconnected sets?
Disconnected sets are two or more sets that have no common points or overlap with each other. This means that there is no way to connect the elements of one set to the elements of another set.
2. How are disconnected sets different from connected sets?
Connected sets have at least one point in common, meaning that there is a way to connect the elements of one set to the elements of another set. Disconnected sets, on the other hand, have no points in common and cannot be connected in any way.
3. Can disconnected sets be separated by a continuous line or curve?
No, disconnected sets cannot be separated by a continuous line or curve. This is because a continuous line or curve would need to pass through both sets, which is not possible since they have no common points.
4. How do we identify if two sets are disconnected?
To identify if two sets are disconnected, we can use the concept of separation. If we can find two open subsets of the sets that are disjoint (have no points in common) and cover the entire sets, then the sets are disconnected. If not, the sets are connected.
5. What is the significance of disconnected sets in mathematics?
Disconnected sets are important in mathematics because they help us understand the concept of continuity. If a set is disconnected, then it is not continuous, meaning there are gaps or breaks in the set. This can have implications in various mathematical fields such as analysis, topology, and geometry.
  • Topology and Analysis
