Could Radioisotope Thermoelectric generators power electric cars?
In summary, using radioisotope thermoelectric generators to extend the range of electric cars is not a practical solution due to concerns about radioactivity, low power densities, and high costs. Additionally, the continuous decay of the radioactive source would require constant management of the excess heat. Overall, it is not a viable option for mass transportation.
nite owl
TL;DR Summary
RTG for electric cars.
Could electric cars be given longer range by radioisotope thermoelectric generators like they use to power spacecraft in deep space?
The last thing you want on a vehicle is an inefficient radioactive power source just waiting to be cracked open by a collision. Or by inept mechanics, ignorant owners, or terrorists.
Likes anorlunda
Aside from the concern about radioactivity that @Drakkith raises, I believe these generators are too low power to be useful for an electric vehicle.
Likes russ_watters and anorlunda
nite owl said:
Summary: RTG for electric cars.
Complementing concerns raised by Drakkith and PeterDonis, indeed the power densities are too low to be practical for mass transportation/propulsion.
https://en.wikipedia.org/wiki/Radio..._generator#Criteria_for_selection_of_isotopes
Pu-238 is chosen for its relatively long half-life, much longer than typical missions. Its power density is ~
0.54 W/g or 0.54 kW/kg. Taking the power for a 2016 Honda Civic (158 - 174 hp / 118 - 130 kW), this would require 218 to 240 kg Pu-238, which is a fair amount of mass for a car. Other isotopes with higher power density, e.g., Po-210, would require much less mass, but the half-life is relatively short, e.g., 138 days, so the power level decreases fairly quickly.
Radio-isotopes are quite expensive! Pu-238 costs ~$8 million per kilogram.
https://ne.oregonstate.edu/rebuilding-supply-pu-238
A major disadvantage of a radioactive source is the fact that they decay continuously, so they are always on. When not driving, one would have to plug the generator into the grid to dump the power, or otherwise remove the heat. It would be a great heat source in winter.
Related to Could Radioisotope Thermoelectric generators power electric cars?
1. Can Radioisotope Thermoelectric Generators (RTGs) be used to power electric cars?
Yes, RTGs can potentially be used to power electric cars. However, there are several challenges and limitations that need to be addressed before this can become a viable option.
2. How do RTGs work?
RTGs use the heat generated from the decay of radioactive materials to produce electricity through the Seebeck effect. This effect converts the temperature difference between two materials into an electric voltage.
3. What are the advantages of using RTGs to power electric cars?
One of the main advantages of RTGs is their long lifespan, as they can continue to generate electricity for decades without needing to be refueled. They also do not rely on external factors such as weather or sunlight, making them a reliable source of power.
4. What are the limitations of using RTGs for electric cars?
One major limitation is the high cost of producing RTGs and the radioactive materials used in them. There are also concerns about the safety and environmental impact of using radioactive materials in such a widespread manner.
5. Are there any current efforts to use RTGs for electric cars?
There have been some research and development efforts to explore the use of RTGs for electric cars, but currently, there are no commercially available options. The technology is still in its early stages and requires further advancements and testing before it can be implemented on a larger scale.
  • Nuclear Engineering
  • Astronomy and Astrophysics
  • Electrical Engineering
