Current in Seawater (Purcell 7.12)
In summary, the conversation discusses the calculation of current induced by seawater moving at a velocity of 1 meter/second and a vertical B-field of .35 gauss, with a conductivity of .04 (1/ohm*cm). The solution involves using the equation E=(v/c)B and J=σE, resulting in a current of 1.4e-4 Amps/m^2. The second part of the conversation raises the question of whether there would be a current induced if the water was in a bottle, to which the response suggests that a circuit is required for a current to flow.
NullSpace0
25
This is Purcell 7.12. Seawater moves at 1 meter/second, there is a vertical B-field of .35 gauss, and the conductivity of water is .04 (1/ohm*cm). What is the current in Amps/meter/meter? If you moved water in a bottle at this speed, would there be a current induced?
I used E=(v/c)B since I know that the induced electric field comes from velocity and B-field which are perpendicular to one another... can you talk of induced electric fields like this?
Then I get E=(35/c) esu/cm^2. J=σE, so J=42.4 esu/sec/cm^2. This converts to 1.4e-4 Amps/m^2. Is that the right number?
I'm not sure how to answer the second part... why would it matter is the water is in a bottle or in a large body of water? All that matters it the conductivity and relative motion, so the current would flow, yes?
A current requires a circuit. Where's the return path in each case?
Presumably the current in the ocean would return at some point on the surface of the water or maybe below the surface of the water?
I guess for a bottle of water there would be no path for the current to return on, though.
Or even through the ocean floor.
I would like to clarify the units and calculations used in this problem. First, the unit of velocity used is meters per second, not centimeters per second. This affects the calculation of the induced electric field, which should be E=(v/c)B = (1/299792458) * 0.35 = 1.17e-9 V/m.
Secondly, the units for conductivity should be in siemens per meter, not ohms per centimeter. This affects the calculation of current, which should be J= σE = (0.04 S/m) * (1.17e-9 V/m) = 4.68e-11 A/m^2.
As for the second part of the question, the size of the container does not affect the induced current as long as the water is moving at the same velocity and the conductivity remains constant. However, the shape and material of the container can affect the strength and direction of the induced current. For example, a conductive container can act as a Faraday cage, shielding the contents from external electric fields.
Related to Current in Seawater (Purcell 7.12)
What is Current in Seawater?
Current in seawater refers to the movement of ocean water caused by a combination of factors such as wind, temperature, salinity, and the Earth's rotation. It is an important physical process that helps regulate the Earth's climate and plays a vital role in the distribution of nutrients and organisms in the ocean.
How is Current in Seawater Measured?
Current in seawater is measured using various instruments such as drifters, buoys, and satellites. These instruments track the movement of ocean water and provide information on the direction, speed, and depth of the current. Additionally, scientists also use mathematical models to simulate and predict ocean currents.
What Factors Affect Current in Seawater?
Several factors influence the movement of ocean water, including wind, temperature, salinity, and the Coriolis effect. Wind is a major driver of surface currents, while temperature and salinity differences cause vertical currents. The Earth's rotation also plays a significant role in the direction of ocean currents.
Why is Understanding Current in Seawater Important?
Understanding current in seawater is crucial for various reasons. It helps us understand the Earth's climate and weather patterns, which can have significant impacts on human activities such as fishing, shipping, and oil exploration. It also plays a vital role in the distribution of heat, nutrients, and marine life, making it essential for ocean conservation and management.
How Does Current in Seawater Affect Marine Life?
Current in seawater has a significant impact on marine life. It helps transport nutrients and organisms, allowing for the distribution of food and reproduction of species. Ocean currents also play a role in the migration patterns of marine animals and can affect the dispersal of larvae. Changes in ocean currents can have detrimental effects on marine ecosystems and can lead to the loss of biodiversity.
