Definition of coordinate system
In summary, the conversation discusses the definition of a coordinate system and whether polar coordinates on ##\mathbb R^2## can be considered a coordinate system. The participants agree that polar coordinates are not everywhere bijective to Cartesian coordinates and that the origin needs to be defined separately. It is also noted that most coordinate systems are defined locally, except for those that are isomorphic to the space they are embedded in.
kent davidge
933
56
In light of the modern definition of what is a coordinate system, namely it's a pair (U, f) with U a region of a m-dimensional manifold, and f a bijection from U to ##\mathbb R^m##, can we say that the polar coordinates on ##\mathbb R^2## are a coordinate system?
I was thinking about this and the answer sounds to be a no, because the polar coordinates are not everywhere bijective to the cartesian coordinates, which we know, is a coordinate system that spans ##\mathbb R^2##.
Your definition on a manifold is called a chart (##f(U)##) or a coordinate chart ##(U,f)##.
The usual coordinates, are the Cartesian coordinates.
Polar, or cylindrical coordinates are also coordinates, even though not Cartesian.
In general, coordinates are any system which allows to uniquely specify a point in some space.
Likes Klystron
But do the polar coordinates uniquely specify a point in ##\mathbb R^2##? I think there's a issue when ##r = 0##.
Yes, the origin has to be assigned separately by a definition. ##r=0## is o.k. but it has no angle, but we can simply require ##0:=(0,0)## and have a unique system again. ##(0,\varphi)## with ##\varphi > 0## will then be undefined. But this is more of a debate for logicians (or linguists), and I'm neither.
Yes, coordinate systems can be locally- or globally- defined. In the Polar case, they are defined only locally. EDIT: Most coord systems are locally, otherwise the manifold is isomorphic to the space where it is embedded, i.e., local homeos become global ones.
Likes kent davidge
Related to Definition of coordinate system
1. What is a coordinate system?
A coordinate system is a mathematical framework used to define and locate points in space or on a surface. It consists of a set of reference axes, a unit of measurement, and a set of rules for determining the coordinates of a point.
2. What are the different types of coordinate systems?
There are several types of coordinate systems, including Cartesian coordinates, polar coordinates, spherical coordinates, and cylindrical coordinates. Each type has its own set of reference axes and rules for determining coordinates.
3. How do you define a coordinate system?
A coordinate system is defined by choosing a set of reference axes and a unit of measurement. The reference axes are usually perpendicular to each other and intersect at a point called the origin. The unit of measurement is used to determine the distance between points along each axis.
4. What is the purpose of a coordinate system?
The purpose of a coordinate system is to provide a standardized way of locating and describing points in space or on a surface. This allows scientists and mathematicians to communicate and work with precise and consistent measurements.
5. How is a coordinate system used in science?
Coordinate systems are used in various scientific fields, such as physics, astronomy, and geography. They are essential for accurately measuring and describing the position, movement, and relationships of objects and phenomena in the physical world.
  • Differential Geometry
