Definition of transient absorbtion
In summary, transient absorption is a process in which a sample is excited with a source and then measured for absorbance over time. It is used to study short-lived states in materials, with time scales of approximately 10^-16 seconds. There are also slower types of transient absorption, such as spectral holeburning, which can have time scales of minutes. Wide spectra light is often used to reset the system in this process.
prehisto
115
Hi, could someone help me to define what is transient or in other words short-lived absorbtion?
Maybe the general defintion could sound something like: In transient absorbtion the sample is excited with some kind of source(electrons, laser ,x-ray and so on) and then flashed with wide spectra light.
And then absorbtion is measured as a function of time.
The absorbance of a substance may vary over time ... thus the value would be "transient".
Junior physics is almost entirely kept to the steady state situation - before a system reaches steady state it passes through transient states that are usually very short lived. The time-scales involved in transient spectroscopy are of order ##10^{-16}##s.
There are also other slower types of transient absorption, for example as a result of what is called spectral holeburning. This process happens often in materials that have several long lived ground states, and as you excite one of the levels it may fall down to another of the ground states and if those are outside the frequency width of the laser it will stay there, thus no longer contributing to absorption. In this process the time scales are given by the ratio of the pumping power vs the relaxation rate of the upper level and between the ground states respectively, and this can be very slow, even minutes.
The wide spectra light you mentioned are often used in this situation, in order to force a "reset" of the system, since wide spectra implies that you would target all ground states, thus refilling the spectral hole again.
Related to Definition of transient absorbtion
1. What is the definition of transient absorption?
Transient absorption refers to the phenomenon in which a material absorbs light or energy at a certain wavelength, causing a temporary change in its electronic or vibrational state.
2. How is transient absorption measured?
Transient absorption is typically measured using a technique called pump-probe spectroscopy, in which a short pulse of light (pump) is used to excite the material, followed by a delayed probe pulse to measure the resulting changes in absorption.
3. What types of materials exhibit transient absorption?
Many types of materials can exhibit transient absorption, including semiconductors, organic molecules, and nanoparticles. It is most commonly observed in materials with highly conjugated electronic structures, such as dyes or pigments.
4. What are the applications of transient absorption?
Transient absorption is used in a wide range of applications, including studying photochemical reactions, monitoring the dynamics of excited states in materials, and characterizing the optical properties of semiconductors and other materials.
5. Can transient absorption be used for time-resolved measurements?
Yes, transient absorption is a powerful tool for time-resolved measurements, as it can provide information about the dynamics of a material on a femtosecond to nanosecond timescale. This is especially useful for studying fast processes such as energy transfer and electron transfer reactions.
  • Astronomy and Astrophysics
  • Atomic and Condensed Matter
  • Electrical Engineering
