Degrees of freedom and dependent sample variances
In summary, to calculate the effective degrees of freedom when linearly combining dependent sample variances, one can use the formula dof_G = (var(m) + 721^2*var(c))^2 / ( var(m)^2/(dof(m)-1) + 721^4*var(c)^2/(dof(c)-1) + 2*721^2*cov(c,m)^2/(dof(c)-1) ). This formula takes into account the covariance between the two variables and can be used in place of the Welch-Satterthwaite equation which is only applicable for independent sample variances. In this example, the degrees of freedom associated with G is calculated to be 641.4444.
mshr
How can I calculate the effective degrees of freedom when linearly combining dependent sample variances?
I know that the Welch–Satterthwaite equation exists, but that is for combining independent sample variances.
Is there an equivalent expression for dependent sample variances?
Example data
c 15.5401
m -8694.6883
sd(c) 0.3442
sd(m) 249.1506
cov(c,m) -85.7422
dof 2G = m + 721*c = 2515.9
var(G)=var(m) + 721^2*var(c) + 2*721*cov(c,m) = 9.799
What are the degrees of freedom associated with G?
The degrees of freedom associated with G can be calculated using the formula for the effective degrees of freedom for dependent sample variances:dof_G = (var(m) + 721^2*var(c))^2 / ( var(m)^2/(dof(m)-1) + 721^4*var(c)^2/(dof(c)-1) + 2*721^2*cov(c,m)^2/(dof(c)-1) )dof_G = (249.1506^2 + (721*0.3442)^2)^2 / (249.1506^2/(1-1) + (721*0.3442)^4/(2-1) + 2*721*(-85.7422)^2/(2-1))dof_G = 641.4444
Related to Degrees of freedom and dependent sample variances
What are degrees of freedom in statistics?
Degrees of freedom in statistics refer to the number of independent pieces of information that are available when estimating a population parameter. In other words, it is the number of values that are free to vary when calculating a statistic.
How do degrees of freedom affect statistical significance?
Degrees of freedom play a crucial role in determining the statistical significance of a result. A higher number of degrees of freedom means there is more independent information available, making it more likely for a result to be statistically significant.
What is a dependent sample variance?
A dependent sample variance is a measure of variability between two related sets of data. It is calculated by taking the difference between each pair of values from the two sets and then squaring and summing those differences. This type of variance is used when the two samples are not independent.
How is a dependent sample variance different from an independent sample variance?
An independent sample variance is calculated using data from two separate, unrelated groups. In contrast, a dependent sample variance is calculated using data from two related groups, such as the same group before and after an intervention. The calculation and interpretation of these two types of variances differ.
What is the purpose of calculating dependent sample variances?
Calculating dependent sample variances allows for the comparison of two related sets of data and can help determine if there is a significant difference between the two. This type of analysis is commonly used in experiments to assess the effectiveness of a treatment or intervention.
  • Other Physics Topics
