Deriving Avogadro's Number without using "mol"
  • Thread starter Moondog
  • Tags
    deriving
In summary: Of course it does. Avogadro’s number is the number of particles per mole. There is simply no possible way to talk about Avogadro’s number without talking about moles.
  • #36
The SI system is system of units geared towards engineering. In this respect, the mole makes sense, as, other than with the dozen, a chemist (and most physicists either) have no means to count the atoms or molecules inside the amount of substance they are working with, neither would they have any reason to do so.
Furthermore, the macroscopic concept of "substance" is emergent. A litre of water behaves differently than an imagined collection of isolated water molecules. It makes sense to speak of one mole of liquid water, but not to speak of two atoms of liquid water.
Personally, I have a rather relaxed relation as far as units are concerned. Is it useful to distinguish between Hertz and Becquerel, although both are formally 1/s? Is it useful to distinguish between Gray and Sievert although both are J/kg? Should we really go on to use metres after Einstein?
Likes dextercioby and Dale
Chemistry news on Phys.org
  • #37
Here another attempt of an answer:
I think the main question is how people did know let say how many grams of e.g. silver correspond to 1 mole without being able to count the number of atoms.
The point is that chemists observed already in the 18th century, the law of constant proportions, e.g. that the ratio of the masses of hydrogen and oxygen in a compound like water is a constant.
See the article on the law of definite proportions:
https://en.wikipedia.org/wiki/Law_of_definite_proportions
Comparing the ratios of thousands of compounds, they worked out the smallest consistent set of coefficients, which led to the assignment of molar masses "gram atom" and of stochiometric molecular formulas like H2O for water. This process predated the atomic hypothesis and led at the same time to its formulation and acceptance. However, the atomic hypothesis was still not completely accepted even at the end of the 19th century (specifically by positivists like Ernst Mach). Once the atomic hypothesis was accepted, the masses of the elements containing the same amount of atoms where known precisely although the absolute number of atoms was not well known (order of magnitude estimates were first derived in 1865 by Josef Loschmidt).
Specifically, it was known that e.g. the charge of electrons, necessary to deposit 1 mole of Silver (which was known to weigh 107,9 g), is 96485 Coulomb, the Faraday constant, and that therefore 1 mole of electrons corresponds to 96485 Coulomb.
Likes dextercioby
32K
  • Materials and Chemical Engineering
  • Classical Physics
